SN75LVCP412A应用电路
Two Channel SATA 3-Gbps Redriver
DEVICE IMPLEMENTATIONSN75LVCP412Adatasheet,pdf
A. Place supply capacitors close to the pin.
B. EN can be left open or tied to supply when no external control is implemented.
C. Output pre-emphasis (PE1, PE2) is shown enabled. Setting depends on device palcement relative to eSATA connector.
