* 函数名称: ADC_Configuration
* 函数功能: ADC功能设置 使用DMA总线 通道1
* 参数变量: NONE
* 全局变量: NONE
* 调用函数:
* 修改时间:
* 版 本: V1.0
* 状 态:调试完成
void ADC_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE); //使能ADC1 时钟
// ADC1 configuration ------------------------------------------------------
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC1和ADC2 独立工作
ADC_InitStructure.ADC_ScanConvMode = DISABLE;//工作于多通道
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;//工作于连续模式
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T3_TRGO;
//ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
//ADC_InitStructure.ADC_ExternalTrigConv = //ADC_ExternalTrigConv_None;//选择由软件触发
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = ADC_CH;//N个通道
ADC_Init(ADC1, &ADC_InitStructure);// ADC1 初始化
ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 1, ADC_SampleTime_7Cycles5);//GPIOA.7 电机温度
ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 2, ADC_SampleTime_7Cycles5);//GPIOB.0 轴温度
ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 3, ADC_SampleTime_7Cycles5);//GPIOB.1 环境温度
ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 4, ADC_SampleTime_7Cycles5);//GPIOA.5 震动
ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 5, ADC_SampleTime_7Cycles5);//GPIOA.6 流量
ADC_RegularChannelConfig(ADC1, ADC_Channel_14,1, ADC_SampleTime_239Cycles5);//GPIOA.6 流量
/* ADC1 Configuration (ADC1CLK = 18 MHz) -----------------------------------*/
ADC_DMACmd(ADC1, ENABLE); //使能DMA ADC1
ADC_ExternalTrigConvCmd(ADC1, ENABLE);/* Enable ADC1 external trigger */
ADC_Cmd(ADC1,ENABLE);/*Enable ADC*/
ADC_ResetCalibration(ADC1);//重置指定的ADC的校准寄存器
while(ADC_GetResetCalibrationStatus(ADC1)); // 等待重置指定的ADC的校准寄存器
ADC_StartCalibration(ADC1);//开始指定ADC的校准程序
while(ADC_GetCalibrationStatus(ADC1)); // Check the end of ADC1 calibration
ADC_SoftwareStartConvCmd(ADC1, ENABLE); // 使能或者失能指定的ADC的软件转换启动功能
* 函数名称: void NVIC_Configuration(void)
* 函数功能: 中断嵌套
* 参数变量: NONE
* 全局变量: NONE
* 调用函数:
* 作 者: 张奇
* 编写时间: 2012-8-23
* 修改时间: 2013-5-15
* 版 本: V1.0
* 状 态:调试完成
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2) ;
NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1 ;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0 ;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE ;
NVIC_Init(&NVIC_InitStructure) ;
* 函数名称: TIM3_ETR_GetDropCounts_Configuration()
* 函数功能: Time3 触发AD采样频率
* 参数变量: NONE
* 全局变量: NONE
* 调用函数:
* 作 者:张奇
* 编写时间:2012-8-23
* 修改时间: 2014-04-18
* 修改内容:计数器
* 版 本:V1.0
* 状 态:调试完成
void TIM3_ETR_GetDropCounts_Configuration(void)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //使能 TIM3 时钟
TIM_DeInit(TIM3);
/* Time Base configuration */
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Prescaler =599 ;
TIM_TimeBaseStructure.TIM_Period = 74;//采样频率计算
TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_SelectOutputTrigger(TIM3,TIM_TRGOSource_Update);
TIM_Cmd(TIM3,ENABLE);
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
