#define NowSec cNowTime[0]
#define NowMin cNowTime[1]
#define NowHour cNowTime[2]
#define NowDate cNowTime[3]
#define NowMonth cNowTime[4]
#define NowYear cNowTime[5]
#define SetSec cSetTime[0]
#define SetMin cSetTime[1]
#define SetHour cSetTime[2]
#define SetDate cSetTime[3]
#define SetMonth cSetTime[4]
#define SetYear cSetTime[5]
uchar Temp_Count;
uchar cSetTime[6];
uchar cNowTime[6];
void Timer_Out_Byte(uchar OutByte);
uchar Timer_In_Byte(void);
void ReadRealtime(void)
NOP;
HT1381_OUTPORT &=~Timer_SCL; //Timer_SCL=0;
NOP;
HT1381_OUTPORT |= Timer_Rest; //Timer_Rest=1;
Timer_Out_Byte(0xBF); //Read, Burst Mode
for(TimeCount=0;TimeCount<6;TimeCount++)
if (TimeCount==5)
Timer_In_Byte(); //dummy read.
cNowTime[TimeCount]=Timer_In_Byte();
//change BCD to uchar
cNowTime[TimeCount]=(cNowTime[TimeCount]/0x10)*10+(cNowTime[TimeCount]%0x10);
NOP;
HT1381_OUTPORT &=~Timer_Rest; //Timer_Rest=0;
void WriteRealtime(void)
NOP;
HT1381_OUTPORT &=~Timer_Rest; //Timer_Rest=0; //for sure to close rest.
NOP;
NOP;
Timer_Out_Byte(0x8E); //Write,Single Mode
Timer_Out_Byte(0x00); //Write, Protect Byte=0, Disable protect
NOP;
NOP;
Timer_Out_Byte(0x80); //Write,Single Mode
Timer_Out_Byte(0x00); //Write, OSC enalbe, old second distroied
NOP;
//change uchar to BCD
cSetTime[TimeCount]=(cSetTime[TimeCount]/10)*0x10+(cSetTime[TimeCount]);
NOP;
Timer_Out_Byte(0XBE); //Write,Burst Mode
Timer_Out_Byte(SetSec & 0x7F); //OSC enable for sure.
Timer_Out_Byte(SetMin);
Timer_Out_Byte(SetHour & 0x7F); //24 Hour Mode
Timer_Out_Byte(SetDate);
Timer_Out_Byte(SetMonth);
Timer_Out_Byte(SetYear);
NOP;
NOP;
Timer_Out_Byte(0x80); //Write, Protect Byte=0, enable protect
NOP;
uchar Timer_Count;
for (Timer_Count=0;Timer_Count<8;Timer_Count++)
HT1381_DIRPORT |= Timer_SDA; //output
if ((OutByte & 0x01) == 0)
HT1381_OUTPORT &=~Timer_SDA;
else
HT1381_OUTPORT |= Timer_SDA;
NOP;
HT1381_OUTPORT |= Timer_SCL;
NOP;
OutByte = OutByte >> 1;
uchar InByte,Timer_Count;
InByte=0x00;
HT1381_DIRPORT &=~Timer_SDA; //Timer_SDA=1;//input
InByte >>= 1;
NOP;
if(HT1381_INPORT&Timer_SDA)
InByte |= 0x80;
else
InByte &= 0x7F;
NOP;
return(InByte);
