一、 移植环境
主 机:VMWare-Ubuntu
开发板:飞凌OK6410 nandflash,Kernel:2.6.36.2
编译器:arm-linux-gcc-4.3.2.tgz
u-boot:u-boot-1.1.6
注:编译器和u-boot 都是飞凌开发板自带的
二、 源码获得
三、 移植步骤:
1.将Linux2.6.34.2内核源码放到工作目录文件夹下,并解压。
#tar xzvf linux2.6.36.2.tar.gz –c /
#pwd
# cd linux2.6.36.2
#SUBARCH := $(shell uname -m | sed -e s/i.86/i386/ -e s/sun4u/sparc64/
# -e s/arm.*/arm/ -e s/sa110/arm/
# -e s/s390x/s390/ -e s/parisc64/parisc/
# -e s/ppc.*/powerpc/ -e s/mips.*/mips/ )
#ARCH ?= $(SUBARCH)
#CROSS_COMPILE ?=
ARCH = arm
CROSS_COMPILE = /usr/local/arm/usr/local/arm/4.3.2/bin/arm-none-linux- gnueabi-
3添加NandFlash分区信息.
修改arch/arm/mach-s3c64xx/mach-smdk6410.c文件,添加Nand Flash的分区信息和Nand Flash的硬件信息。(蓝色字体为添加部分)
#pwd
// 注意:此处的nandflash分区信息是飞凌自带的2.6.28的内核设置,由于此处要用到uboot是飞凌的,所以分区信息也要按人家的来
添加头文件
#include
#include
#include
#include
struct mtd_partition s3c_partition_info[] = {
#if defined (CONFIG_SPLIT_ROOT_FILESYSTEM)
#endif
static struct s3c2410_nand_set s3c_nandset[]={
static struct s3c2410_platform_nand s3c_platform={
//add here…
static struct platform_device *smdk6410_devices[] __initdata = {
#ifdef CONFIG_SMDK6410_SD_CH0
#endif
#ifdef CONFIG_SMDK6410_SD_CH1
#endif
static void __init smdk6410_map_io(void){
static void __init smdk6410_machine_init(void){
5.配置内核。(arch/arm/configs/目录下是一般内核的默认配置)
支持NandFlash
Device Drivers --->
Memory Technology Device (MTD) support --->
MTD partitioning support
NAND Device Support --->
NAND Flash support for S3C/S3C SoC
device drivers ->
Caching block device access to MTD devices
(此出勾选可防止出现:VFS: Cannot open root device "mtdblock2" or unknown-block(2,0) 错误)
保存退出
复制config文件,编译内核
#pwd
#/linux2.6.34.2
#cp –f arch/arm/configs/s3c6400_defconfig .config
可以使用make menuconfig对刚刚配置的内核根据具体的情况进行修改,开始我没有进行修改直接make zImage,最后在arch/arm/boot/目录下生成zImage镜像文件。
6.编译内核 make zImage
CPU: Testing write buffer coherency: ok
s3c6400-nand: failed to claim resource 0
WARNING: at drivers/base/core.c:130 device_release+0x70/0x84()
------------[ cut here ]------------
Device s3c64xx-rtc does not have a release() function, it is broken and must be fixed.
Modules linked in:
---[ end trace 1b75b31a2719ed1e ]---
Device s3c64xx-pata.0 does not have a release() function, it is broken and must be fixed.
Modules linked in:
这个问题就是在mach-smdk6410.c 中的static struct platform_device *smdk6410_devices[] __initdata = {
}; 结构体中所有设备都找不到释放函数,经过分析,可能是这些板级设备初始化时出现问题,所以系统调用释放资源的函数,可是内核中没有这些函数(可能是没有必要吧,所以内核中没有定义!此上纯属个人胡猜,希望高手指正),所以出现如上问题,通过我大量的分析,问题在static struct resource s3c_nand_resource[](路径:arch./arm/plat-samsung) 这个机构体中,
static struct resource s3c_nand_resource[] = {
所以解决方法就是修改arch./arm/plat-samsung/dev-nand.c 中的
.end = S3C_PA_NAND + SZ_1M-1, 减去一就行了
7.再次编译内核,下载运行:
ifconfig: socket: Function not implemented
Try to bring eth0 interface up......ifconfig: socket: Function not implemented
route: socket: Function not implemented
Done
Starting Qtopia, please waiting...
Please press Enter to activate this console. touch...
说明内核已经成功引导启动文件系统,只不过现在的内核没有触摸板驱动,下一步你就可以移植一下触摸板驱动了
此教程只是本人所遇到问题的总结,一些问题只做参考,交流,并不具备通用性,如按照上述步骤遇到问题,联系我,可以帮着一起解决,本人菜鸟,教程制作仓卒,如有错误,请大家见谅,
