通过串口烧的信息:
>OEMInitLIb is Success
+++InitializeInterrupt()
---InitializeInterrupt()
+++OTGDEV_InitOtg
OTGDEV_SetSoftDisconnect
---OTGDEV_InitOtg
TSR START ADDRESS : 0x47700000
TSR IMAGE SIZE : 0x00080000
DOWNLOADING IS COMPLETED
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Apr 6 2011 18:41:59
+OEMPlatformInit.
Microsoft Windows CE Bootloader for the Samsung SMDKV210 Version 2.5 Built Apr 6 2011
ARGS: Initializing BSP_ARGS back to initial state.
Initialize IRQ Vector Tables
EOTG: USB DeInit 0xE59FF3D8
TOC_Read: 5
[SUN] g_ImageType: 0x8
TOC {
dwSignature: 0x434F544E
BootCfg
ConfigFlags: 0x2020
dwBootDelay: 0x5
IP: 0.0.0.0
MAC Address: 00:00:00:00:00:00
Port: 0.0.0.0
SubnetMask: 255.255.255.0
ID[0]
dwVersion: 0x20005
dwSignature: 0x544F4245
String: eboot.bin
dwImageType: 0x1
dwTtlSectors: 0x100
dwLoadAddress: 0x87700000
dwJumpAddress: 0x87700000
dwStoreOffset: 0x1
ID[1]
dwVersion: 0x0
dwSignature: 0x0
String:
dwImageType: 0x0
dwTtlSectors: 0x0
dwLoadAddress: 0x0
dwJumpAddress: 0x0
dwStoreOffset: 0x0
ID[2]
dwVersion: 0x0
dwSignature: 0x0
String:
dwImageType: 0x0
dwTtlSectors: 0x0
dwLoadAddress: 0x0
dwJumpAddress: 0x0
dwStoreOffset: 0x0
ID[3]
dwVersion: 0x1
dwSignature: 0x48534643
String: NK
dwImageType: 0x8
dwTtlSectors: 0x40B2
dwLoadAddress: 0x80020000
dwJumpAddress: 0x80027E94
dwStoreOffset: 0x0
ID[4]
dwVersion: 0x0
dwSignature: 0x0
String:
dwImageType: 0x0
dwTtlSectors: 0x877499A4
dwLoadAddress: 0x0
dwJumpAddress: 0x0
dwStoreOffset: 0x0
[Eboot] g_pBSPArgs->bDVFSDisable: 0
[EBOOT] ++OEMPMICInit
[EBOOT] this is test text
[I2CEMUL] VERSION INFO : 31
PMIC8937_SLAVE_ADDR : 91 . [EBOOT] SET OEMPMICInit------DVS_1_300
[EBOOT] --OEMPMICInit
[Eboot] ++InitializeDisplay()
[LDI]++LDI_initialize_register_address(0xb1300000, 0xb7100000, 0xb0200000)
[LDI:INF] g_pSPIReg = 0xb1300000
[LDI:INF] g_pDispConReg = 0xb7100000
[LDI:INF] g_pGPIOReg = 0xb0200000
[LDI]--LDI_initialize_register_address() : 0
[DISP]++Disp_initialize_register_address(0xb7100000, 0xb0200000, 0xb0100000, 0xa0000800, 0xb0107000)
[DISP:INF] g_pDispConReg = 0xb7100000
[DISP:INF] g_pGPIOReg = 0xb0200000
[DISP:INF] g_pCMUCLKReg = 0xb0100000
[DISP:INF] g_pBSPArg = 0xa0000800
[DISP:INF] g_pCMUMISCReg = 0xb0107000
[DISP]--Disp_initialize_register_address() : 0
[LDI]++LDI_set_LCD_module_type(7)
[LDI]--LDI_set_LCD_module_type() : 0
[LDI]++LDI_fill_output_device_information()
[LDI:INF] Output Device Type [7] = LDI_AT043TN24_RGB
[LDI]--LDI_fill_output_device_information()
[DISP]++Disp_set_output_device_information(80017b2408x)
[DISP]--Disp_set_output_device_information()
[DISP]++Disp_initialize_output_interface(0)
[DISP]++Disp_initialize_port_RGBIF(0)
[DISP]--Disp_initialize_port_RGBIF() : 0
[DISP]++Disp_initialize_RGBIF()
[DISP]++Disp_get_vclk_direction_divider(4)
[DISP:INF] MPLL_USE IS TRUE
[DISP:INF] CLK_SRC_MASK0 = 0xffffffff
[DISP:INF] CLK_SRC1 = 0x00600000
[DISP:INF] CLK_DIV1 = 0x00200400
[DISP:INF] MPLLout = (667000000 Hz)
[DISP:INF] VCLK Source = LCDCLK (222333333 Hz)
[DISP:INF] VCLKSrc = 222333333, VCLK = 0, Div = 17
[DISP:INF] VCLK Direction = Divided, Divider = 14, VCLK = 15880952 Hz
[DISP] --Disp_get_vclk_direction_divider()
[DISP]--Disp_initialize_RGBIF() : 0
[DISP]--Disp_initialize_output_interface() : 0
[DISP]++Disp_set_window_mode(3)
[DISP]++Disp_window1_initialize(3, 5, 480, 272, 0, 0)
[DISP]--Disp_window1_initialize() : 0
[DISP]--Disp_set_window_mode() : 0
[Eboot:LCD_Bpp = 16]
[DISP]++Disp_set_framebuffer(1, 0x47e00000)
[DISP]++Disp_window_registers_lock(1)
[DISP]--Disp_window_registers_lock() : 0
[DISP]++Disp_window_registers_unlock(1)
[DISP]--Disp_window_registers_unlock() : 0
[DISP]++Disp_window_onfoff(1, 1)
[DISP]--Disp_window_onfoff() : 0
[LDI]++LDI_initialize_LCD_module()
[LDI:INF] LDI_initialize_LCD_module() : Type [7] LDI_AT043TN24_RGB
[LDI]++LDI_AT043TN24_RGB_power_on()
[LDI]--LDI_AT043TN24_RGB_power_on() : 0
[LDI]++LDI_AT043TN24_RGB_initialize()
[LDI]--LDI_AT043TN24_RGB_initialize() : 0
[LDI]--LDI_initialize_LCD_module() : 0
[DISP]++Disp_envid_onoff(1)
[DISP:INF] DUALCON = 0x00000000
[DISP:INF] VIDCON2 = 0x00000000
[DISP:INF] DISPLAY_CONTROL = 0x00000002
[DISP:INF] GPOUTCON0 = 0x00000000
[DISP:INF] VIDCON0 = 0x00000357
[mDNIe:INF] CLK_SRC_MASK1 = 0xffffffff
[mDNIe:INF] CLK_SRC3 = 0x00000000
[mDNIe:INF] CLK_DIV3 = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDCON0 = 0x00000357
[DISP:INF]Disp_envid_onoff() : VIDCON1 = 0x0000e660
[DISP:INF]Disp_envid_onoff() : VIDCON2 = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDCON3 = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDTCON0 = 0x00062902
[DISP:INF]Disp_envid_onoff() : VIDTCON1 = 0x002f0f7f
[DISP:INF]Disp_envid_onoff() : VIDTCON2 = 0x000879df
[DISP:INF]Disp_envid_onoff() : VIDOSD2A = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDOSD2B = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDOSD2C = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDW02ADD0B0 = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDW02ADD1B0 = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDW02ADD2 = 0x00000000
[DISP:INF]Disp_envid_onoff() : WINCON2 = 0x00000000
[DISP:INF] CLK_GATE_IP0 = 0xffffffff
[DISP:INF] CLK_GATE_IP1 = 0xffffffff
[DISP:INF] CLK_GATE_IP2 = 0xffffffff
[DISP:INF] CLK_GATE_IP3 = 0xffffffff
[DISP:INF] CLK_GATE_IP4 = 0xffffffff
[DISP:INF] CLK_GATE_BLOCK = 0xffffffff
[DISP]--Disp_envid_onoff() : 0
[Eboot] --InitializeDisplay()
Press [ENTER] to download now or [SPACE] to cancel.
Initiating image download in 0 seconds. EOTG: USB Init
EOTG: Receive ATUD 2
EDNL: [13]Eboot version=
EDNL: boot Downloading...
EDNL: [4]Flash write RAMAddr=80200000, Length=00000003, ROMAddr=80200000
g_ImageType = IMAGE_TYPE_BOOTIMAGE
dwImageLength = 0x84000
dwNumBlocks = 0x5
++ WriteBlock 0
Checksum = bd8fb, header = 4000 0 bd8fb 0
++ FMD_WriteSector_Stepldr : 0xa0020000
-- FMD_WriteSector_Stepldr
++ FMD_WriteSector_Stepldr : 0xa0020800
++ FMD_WriteSector_Stepldr : 0xa0021000
++ FMD_WriteSector_Stepldr : 0xa0021800
++ FMD_WriteSector_Stepldr : 0xa0022000
++ FMD_WriteSector_Stepldr : 0xa0022800
++ FMD_WriteSector_Stepldr : 0xa0023000
++ FMD_WriteSector_Stepldr : 0xa0023800
End of writing Stepldr : BREAK!
-- WriteBlock
dwBytesPerBlock : 131072
++ WriteBlock 1
++ FMD_WriteSector: 1 block, 0 sector,
-- FMD_WriteSector
++ FMD_WriteSector: 1 block, 1 sector,
-- FMD_WriteSector
++ FMD_WriteSector: 1 block, 2 sector,
-- FMD_WriteSector
++ FMD_WriteSector: 1 block, 3 sector,
-- FMD_WriteSector
-- FMD_WriteSector
++ FMD_WriteSector: 1 block, 60 sector,
-- FMD_WriteSector
++ FMD_WriteSector: 1 block, 61 sector,
-- FMD_WriteSector
++ FMD_WriteSector: 1 block, 62 sector,
-- FMD_WriteSector
++ FMD_WriteSector: 1 block, 63 sector,
-- FMD_WriteSector
-- WriteBlock
++ WriteBlock 2
++ WriteBlock 4
++ FMD_WriteSector: 4 block, 0 sector,
-- FMD_WriteSector
++ FMD_WriteSector: 4 block, 1 sector,
-- FMD_WriteSector
-- FMD_WriteSector
-- WriteBlock
EDNL: Store Start address 80200000 & Length 00000003 to flash.
EDNL: ### Clear password ###
EDNL: [1000] OPENSTL cmd
EDNL: PDA Downloading...
EDNL: [4]Flash write RAMAddr=80200000, Length=000000D4, ROMAddr=80200000
EDNL: Store Start address 80200000 & Length 000000D4 to flash.
EDNL: End of command loop...
System ready!
Preparing for download...
Please send the Image through USB.
BL_IMAGE_TYPE_BIN
Download BIN file information:
[0]: Base Address=0x80020000 Length=0x358c6d0
dwStartAddr = 0x80020000
dwLength = 0x358c6d0
NK image
rom_offset=0x0.
ImageStart = 0x80020000, ImageLength = 0x358C6D0, LaunchAddr = 0x80027F34
Completed file(s):
[0]: Address=0x80020000 Length=0x358C6D0 Name="" Target=FLASH
OEMWriteFlash 0x80020000 0x358C6D0
OEMWriteFlash 0x8
Enter LowLevelFormat [0x0, 0x7ff].
Erasing flash block(s) [0x0, 0x7ff] (please wait): EraseBlocks: preserving reserved block (0x0)
EraseBlocks: preserving reserved block (0x1)
EraseBlocks: preserving reserved block (0x2)
EraseBlocks: preserving reserved block (0x3)
EraseBlocks: preserving reserved block (0x4)
EraseBlocks: preserving reserved block (0x5)
EraseBlocks: found a bad block (0x61) - skipping...
EraseBlocks: found a bad block (0x1a6) - skipping...
EraseBlocks: found a bad block (0x48c) - skipping...
EraseBlocks: found a bad block (0x54d) - skipping...
EraseBlocks: found a bad block (0x644) - skipping...
Done.
WriteMBR: MBR block = 0x6.
Done.
IsValidMBR: MBR sector = 0x180 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x1fd3f.
CreatePartition: Start = 0x1, Num = 0x6b40.
Log2Phys: Logical 0x1 -> Physical 0x181
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x6b41 after processing part 0x21.
CreatePartition: Num sectors set to 0x19080 to allow for compaction blocks.
CreatePartition: Start = 0x6b80, Num = 0x19080.
BP_SetDataPointer at 0x0
WriteData: Start = 0x0, Length = 0x358c6d0.
WriteFlashNK : Kernel 0x0 0x358C6D0 0x80020000
ROMHDR at Address 80020044h
TOC {
BootCfg
ConfigFlags: 0x2020
dwBootDelay: 0x5
IP: 0.0.0.0
Port: 0.0.0.0
ID[0]
dwVersion: 0x20005
String: eboot.bin
dwImageType: 0x1
dwTtlSectors: 0x100
dwStoreOffset: 0x1
ID[1]
dwVersion: 0x0
dwSignature: 0x0
String:
dwImageType: 0x0
dwTtlSectors: 0x0
dwLoadAddress: 0x0
dwJumpAddress: 0x0
dwStoreOffset: 0x0
ID[2]
dwVersion: 0x0
dwSignature: 0x0
String:
dwImageType: 0x0
dwTtlSectors: 0x0
dwLoadAddress: 0x0
dwJumpAddress: 0x0
dwStoreOffset: 0x0
ID[3]
dwVersion: 0x1
String: NK
dwImageType: 0x8
dwTtlSectors: 0x6B19
dwJumpAddress: 0x80027F34
dwStoreOffset: 0x0
ID[4]
dwVersion: 0x0
dwSignature: 0x0
String:
dwImageType: 0x0
dwLoadAddress: 0x0
dwJumpAddress: 0x0
dwStoreOffset: 0x87762790
A XIP region was written to the flash memory successfully.
INFO: OEMLaunch: Jumping to Physical Address 0x40027F34h (Virtual Address 0x80027F34h)...
Windows CE Kernel for ARM (Thumb Enabled) Built on Nov 3 2010 at 07:30:04
OAL Log enable : 0
OAL Log mask : 103
System Clock Info
[OAL] APLL_CLK : 800000000 Hz
[OAL] MPLL_CLK : 667000000 Hz
[OAL] EPLL_CLK : 96000000 Hz
[OAL] VPLL_CLK : 54000000 Hz
[OAL] ARM_CLK : 800000000 Hz
[OAL] HCLK_MSYS : 200000000 Hz
[OAL] PCLK_MSYS : 100000000 Hz
[OAL] HCLK_DSYS : 166750000 Hz
[OAL] PCLK_DSYS : 83375000 Hz
[OAL] HCLK_PSYS : 133400000 Hz
[OAL] PCLK_PSYS : 66700000 Hz
System Clock Info
OEM:-------------------------------------------
OEM: Normal Boot!!
DCache: 128 sets, 4 ways, 64 line size, 32768 size
ICache: 128 sets, 4 ways, 64 line size, 32768 size
+OALInterruptInit
-OALInterruptInit(rc = 1)
DMSG: DrvWAITInitialize
-OALIoCtlHalGetHWEntropy(rc = 0)
[I2C:I] I2C Channel 0 is open
[I2C:I] I2C Channel 1 is open
[I2C:I] I2C Channel 2 is open
[I2C:I] I2C Channel 3 is open
[CMM_Init] VirAddrDram_0 : 0xad480000 VirAddrDram_1 : 0xa5f00000
############################### EHCI INIT ########################
[EHCI] InitailizeEHCI
[EHCI:INF] ++InitializeEHCI(): IRQ 144 sysintr 22 for EHCI interrupt.
############################### --EHCI INIT ########################
############################### OHCI INIT ########################
[XEINT4] Set xeint4 Low.
[XEINT4] Set xeint4 High.
############################### --OHCI INIT ########################
[WAV] I2C OPEN : I2C0: SUCCESS
[WAV] ACTUAL I2C CLCOK SPEAD : 64 Khz
[CEC] DllEntry() : Process Attach
[CEC] CEC_Init()
::AttachDevice SUCCESS_HS:2000
[dm9]:[CUSTOM_BOARD_STR]
[dm9] NewOBJ-2009
[dm9] NewOBJ-2009 V2.08
[dm9] NewOBJ-2009 CUSTOM_SMDKV210
[dm9] .Send connection!
[dm9]:[DM9000_CAST_IO_ADDRESS]
[dm9]:[DM9000_CAST_DATA_OFFSET]
[dm9]:[DM9000_CAST_IRQ_NUMBER]
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_IO_BASE_ADDRESS]=0xa0000000
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_DATA_OFFSET]=0x4
[dm9] Device::AttachDevice SUCCESS_HS:2000
RetriveConfigurations:m_szConfigures[CID_IRQ_NUMBER]=0xa
[dm9] --
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_BUS_DRIVE]=0x61
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_INT]=0x1
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_TXBUFFER_NUMBER]=32
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_RXBUFFER_NUMBER]=32
[dm9] -
[dm9] m_szConfigures[CID_IRQ_LEVEL]=15
[dm9] m_szConfigures[CID_IRQ_SHARED]=1
[dm9] m_szConfigures[CID_CHECK_FOR_HANG_PERIOD]=3
[dm9] Init.TQu m_szConfigures[CID_TXBUFFER_NUMBER]=32*2
[dm9]:[ID_Custom_Init()]
[dm9]:[ID_Custom_IO_Timing()]
[CPU TO DM9000: IO Timing 0 4 d 4 0]
[CPU TO DM9000: IO Timing -Tcah PMC -0 0]
[DM9] Chip signature rate 60000/60000]
[DM9] Chip signature is 0A469000]
[DM9] -- Chip revision -- REVISION : 18 --
[dm9]:[ID_CUSTOM_READ_MAC()]
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[0]=0x20
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[1]=0x4
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[2]=0x9
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[3]=0x18
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[4]=0x0
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[5]=0x7
[dm9] -- ----------------- REG38.b[6:5] : CURR= 00 (2mA) --
[dm9] -- ----------------- REG38.b[6:5] : CURR= 11 (8mA) --
[DM9]:-- -- CURR REG38 --- 0x0 -- CURR= 00
[DM9]:-- --- INT REG39 --- 0x0
[DM9]:-- * INT REG39 * INT Active high
[dm9]:[ID_CUSTOM_INT_EN]
[DM9]:DeviceEnableInterrupt
+OALIntrEnableIrqs(10,)
[dm9] DeviceStart:[dm9] --
[31m[UART] DMA init CH:0
[0m[SDMMCCh0] SDHCControllerIst - Card is Removed!
[SDMMCCh2] SDHCControllerIst - Card is Removed!
[SDMMCCh3] SDHCControllerIst - Card is Removed!
++PHY_SetPowerDown
0x01
0x05 0x00 0xd8 0x10 0x1c 0x30 0x40 0x6b
0x10 0x02 0x52 0x1f 0x23 0x5b 0x7e 0x84
0x00 0x10 0x38 0x00 0x08 0x10 0xe0 0x22
0x40 0xf3 0x26 0x00 0x00 0x00 0x80
--PHY_SetPowerDown
[CMM] v_addr : 0xad480000 p_addr : 0x25480000 size : 0x004e0000 loc : 0
[IOCTL_CODEC_MEM_ALLOC] u_addr:0xd33c0000 CallerProcessID : 0x400002
[MFC_DRV: WARNING] MfcFWBufMemMapping: virFWBuf : d33c0000
[MFC_DRV: WARNING] MfcFWBufMemMapping: phyFWAddr : 25480000
[MFC_DRV: WARNING] MFC_Open: It is called by Power Manager
[MFC_DRV: WARNING] MFC_IOControl: POWER_CAPABILITIES : 0x11
MFC power on
[MFC_DRV: WARNING] MFCOpen++:
[31m[UFNPDD] USB_POWER : D[MFC_DRV: WARNING] MFCOpen: FirmwareVersion : 00100407
[MFC_DRV: WARNING] MFC_Open(): Instance Number : 1
[MFC_DRV: WARNING] MFC_Open(): CLK_CNTL is enabled
[MFC_DRV: WARNING] MFC_Close(): MfcCtx->InstNo : 1
[MFC_DRV: WARNING] MFCClose:
0 IN
[0m[31m[UFN[MFC_DRV: ERROR] WaitForDone: Interrupt :: MFC_R2H_CMD_ERR_RET(0x4)
[MFC_DRV: ERROR] MFCClose: closing is failed
MFC power off
PDD] USB_POWER : D0 OUT
[0m[31m[UFNPDD] USB Serial Function Class Enabled
[0mLayMgr.cpp: Layout Manager successfully initialized to 1
Maximum Allowed Error 7:
Backlight driver: GetSystemPowerStstusEx2 failed with error 0x1f.
MSIM: IM_ReadRegistry read KB 5
[BootCompleteApp] Boot Complete Event Occured
[31m[UFNPDD] USB_POWER : D0 IN
[0m[31m[UFNPDD] USB_POWER : D0 OUT
[0mUsbFnMdd!UfnMdd_Notify: Ignoring notification 0x00000001 - 0x00000003 from PDD
[dm9] .NSR.PHYoff c / BMSR 7849
[dm9] .Send disconnection!
Explorer(V2.0) taskbar thread started.
NDISPWR:: Found adapter [DM9000]
NDISPWR:: Found adapter [WWAN1]
[31m[UFNPDD] OTG Cable Attached
[0m[31m[UFNPDD] RESET Again
[0m!USBD: Could not load driver for attached device
BLUETOOTH GATEWAY:: Failed to enable device btline1. Error code 717
BLUETOOTH GATEWAY:: Failed to enable device btline0. Error code 717
kernel IOCTL_POWER_SET setting state 1
kernel IOCTL_POWER_SET setting state 0
[PWC_PM:INFO] Check LP Mode 4, 1, 0, 2, 0, 0, 0
[PWC_PM:INFO] Check LP Mode 4, 0, 0, 3, 0, 0, 0
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
[31m[UFNPDD] OTG Cable Detached
[0mUsbFnMdd!UfnMdd_Notify: Ignoring notification 0x00000001 - 0x00000000 from PDD
[31m[UFNPDD] Reset Exception
[0mUsbFnMdd!UfnMdd_Notify: Ignoring notification 0x00000001 - 0x00000002 from PDD
[0m[31m[UFNPDD] OTG Cable Detached
[0mkernel IOCTL_POWER_SET setting state 1
