Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 17 [#1]
last sysfs file: /sys/devices/virtual/vc/vcsa1/dev
Modules linked in:
CPU: 0 Not tainted (2.6.39 #1)
PC is at atmel_tasklet_func+0x110/0x69c
LR is at atmel_tasklet_func+0x10/0x69c
pc : [
sp : c7825f50 ip : c045e0bc fp : 00000000
r10: c0456a80 r9 : 0000000a r8 : 00000000
r7 : c7874568 r6 : c045e0a8 r5 : 00000100 r4 : c045dfb4
r3 : 00000002 r2 : 00000ffc r1 : 00000001 r0 : 00000001
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 0005317f Table: 27aec000 DAC: 00000017
Process ksoftirqd/0 (pid: 3, stack limit = 0xc7824270)
Stack: (0xc7825f50 to 0xc7826000)
5f40: 00000100 c7824000 00000001 00000018
5f60: 0000000a c0456a80 c7825f84 00000000 00000100 c7824000 00000001 00000018
5f80: c0456a80 c0047b70 00000006 c0047650 c0432e50 00000000 c7824000 00000000
5fa0: 00000000 c0047938 00000000 00000000 00000000 c00479a0 c7825fd4 c7819f60
5fc0: 00000000 c0058c64 c00335f4 00000000 00000000 00000000 c7825fd8 c7825fd8
5fe0: 00000000 c7819f60 c0058be0 c00335f4 00000013 c00335f4 0c200050 fc3b9beb
Code: 1a000002 e59f057c e59f157c ebfa416c (e5983000)
---[ end trace 6b8e1841ba3a56c9 ]---
Kernel panic - not syncing: Fatal exception in interrupt
Exception stack(0xc7825f08 to 0xc7825f50)
5f00: 00000001 00000001 00000ffc 00000002 c045dfb4 00000100
5f20: c045e0a8 c7874568 00000000 0000000a c0456a80 00000000 c045e0bc c7825f50
5f40:c01a4e30 c01a4f3020000013 ffffffff
通常认为,产生异常的地址是lr寄存器的值,从上面的异常信息可以看到[lr]的值是c01a4e30。
接下来,我们可以通过内核镜像文件反汇编来找到这个地址。内核编译完成后,会在内核代码根目录下生成vmlinux文件,我们可以通过以下命令来反汇编:
arm-none-eabi-objdump -Dz-Svmlinux >linux.dump
值得注意的是,arm-none-eabi-objdump的参数-S表示尽可能的把原来的代码和反汇编出来的代码一起呈现出来,-S参数需要结合arm-linux-gcc编译参数-g,才能达到反汇编时同时输出原来的代码。所以,我在linux内核代码根目录的Makefile中增加-g编译参数:
KBUILD_CFLAGS :=-g-Wall -Wundef -Wstrict-prototypes -Wno-trigraphs \
-fno-strict-aliasing -fno-common \
-Werror-implicit-function-declaration \
-Wno-format-security \
-fno-delete-null-pointer-checks
修改Makefile后,重新编译内核,在根目录中生成的vmlinux文件就会包含了原来的代码信息,因此,该文件的大小也比原来大一倍!
最后执行“arm-none-eabi-objdump -Dz-Svmlinux >linux.dump”,由于加入了-g编译参数,执行这个反汇编命令需要很长时间(本人在虚拟机上执行,花了近6个小时!),反汇编出来的linux.dump文件也比原来的44MB增大到惊人的503MB。
接下来可以用UltraEdit打开linux.dump文件,查找“c01a4e30”字符串。
最后定位到的信息是:
* tasklet handling tty stuff outside the interrupt handler.
static void atmel_tasklet_func(unsigned long data)
c01a4e20:e92d45f0 push{r4, r5, r6, r7, r8, sl, lr}
c01a4e24:e24dd01c subsp, sp, #28; 0x1c
c01a4e28:e1a04000 movr4, r0
/* The interrupt handler does not take the lock */
spin_lock(&port->lock);
if (atmel_use_pdc_tx(port))
atmel_tx_pdc(port);
else if (atmel_use_dma_tx(port))
c01a4e2c:ebfffda1 blc01a44b8
c01a4e30:e3500000 cmpr0, #0; 0x0
c01a4e34:e5943034 ldrr3, [r4, #52]
c01a4e38:0a00007b beqc01a502c
可以看出来,异常的产生位于atmel_tasklet_func函数的else if (atmel_use_dma_tx(port))一行。
估计atmel_use_dma_tx(port)的“port”参数为空指针所致!
最后,我把串口的DMA功能去掉,改为直接传送,这样做虽然效率低了点,但产生异常的现象消失了。
到后面再仔细分析为什么会产生这个异常,彻底解决这个问题。
