下面的代码是用PS2键盘控制LED显示按键编码.按住显示的是通码.放开显示的是断码.但由于断码最后8位是通码一样(不包括多位通码).所以显示一般是一样的.
单片机P3.3接PS2按口的5为时钟CLK,P3.4接PS2接口的1为数据DA
代码如下:
#include
#include
#define ESC_CO
sbit PS2_DA
sbit PS2_CLK = P3^3; //PS2时钟线
sbit BEEP = P3^7; //蜂鸣器驱动线
unsigned char TEMP;
unsigned char KeyCode; //键盘键值
unsigned char co
0x1c,0x32,0x21,0x23,0x24,0x2b,0x34,0x33,0x43,0x3b,0x42,
0x4b,0x3a,0x31,0x44,0x4d,0x15,0x2d,0x1b,0x2c,0x3c,0x2a,0x1d,0x22,0x35,0x1a, //a-z
0x45,0x16,0x1e,0x26,0x25,0x2e,0x36,0x3d,0x3e,0x46, //0-9
0x0e,0x4e,0x55,0x5d,0x29,0x54,0x5b,0x4c,0x52,0x41,0x49,0x4a,0x71, //标点符号
0x70,0x69,0x72,0x7a,0x6b,0x73,0x74,0x6c,0x75,0x7d, //右边数字键0-9
0xff };
void delay(unsigned int x)
unsigned char i;
while(x--)
for (i=0; i<13; i++) ;
void beep()
unsigned char i;
for (i=0;i<100;i++)
delay(5);
BEEP=!BEEP; //BEEP取反
BEEP=1; //关闭蜂鸣器
unsigned char ReadPS2()
unsigned char i; //位数
while(PS2_CLK); //等待键盘把时钟第一次拉低,表示
for(i=8; i!=0; i--) // 把起始位算入
while(!PS2_CLK); //等待一个有效的下跳沿,这两条while是半个周期,主设备在下降沿读数据
while( PS2_CLK);
KeyCode >>= 1; //数据低位在前
if(PS2_DA
KeyCode |= 0x80; // 得到有效的数据位
for(i=2;i!=0;i--) //等待键盘发送效验位和终止位
while(!PS2_CLK);
while( PS2_CLK);
while(!PS2_CLK); //等待键盘把时钟线拉高
TEMP = KeyCode;
TEMP = ~TEMP;
P2=TEMP; //显示键码
return(KeyCode); //返回按键值
void PS2KEY()
unsigned char y;
for(y=0 ;y<60 ;y++) //键值变换为顺序码
if(KeyCode==TABLE_D[y])
delay(1000);
beep() ; //查找有效,蜂鸣器响一声
void main()
P2 = 0xff; //关闭所有LED
while(1)
ReadPS2();
if(KeyCode==ESC_CO
PS2KEY();
