1.Android已经可以通过NFS在FS2410开发板上运行
二、目前缺陷
1.触摸屏没有校准
2.Android中时钟停止,结束zygote进程,系统重启,时钟更新,但再次停止不动
3.串口无法与GPRS模块通讯
三、移植步骤
一、移植Android内核到FS2410开发板上
1、从de.google.com/p/android/downloads/list">/zixunimg/eepwimg/co
2、将内核解压到用户目录,如/home/wangan/kernel.git
3、进入kernel.git文件夹,如cd ~/kernel.git/
4、修改arch/arm/plat-s3c24xx/common-smdk.c文件中的nand flash分区设置,如gedit arch/arm/plat-s3c24xx/common-smdk.c
修改static struct mtd_partition smdk_default_nand_part[]结构体为:
static struct mtd_partition smdk_default_nand_part[] = {
[0] = {
.name = "Boot Agent",
.size = SZ_256K,
.offset = 0,
[1] = {
.name = "Linux Kernel",
.offset = SZ_256K,
.size = SZ_2M - SZ_256K,
[2] = {
.name = "File System",
.offset = SZ_2M,
.size = SZ_32M - SZ_2M,
[3] = {
.name = "Other",
.offset = SZ_32M,
.size = SZ_32M,
5、在/zixunimg/eepwimg/www.codesourcery.com/gnu_toolchains/arm/portal/release644网站上下载IA32 GNU/Linux TAR。
6、将文件解压到用户目录,如/home/wangan/arm-2008q3
7、进入arm-2008q3/bin文件夹,如cd ~/arm-2008q3/bin/
8、添加当前路径进入环境变量,如export PATH=$PWD:$PATH,或修改~/.bashrc文件并重新登录
9、进入内核文件夹,如cd ~/kernel.git/
10、修改Makefile文件,如gedit Makefile
更改ARCH和CROSS_COMPILE
#ARCH ?= $(SUBARCH)
ARCH ?= arm
#CROSS_COMPILE ?= arm-eabi-
CROSS_COMPILE ?= arm-none-eabi-
11、从华清远见Linux-2.6.8.1内核压缩包中提取.config文件(注意:config前面有个“.”)放入kernel.git文件夹
12、运行make menuconfig
(1) 确保System Type ---> ARM system type ()中的内容为Samsung S3C2410, S3C2412, S3C2413, S3C2440, S3C2442, S3C2443
(2) 确保System Type ---> S3C2410 Machines ---> [*] SMDK2410/A9M2410被勾选
(3) 取消选择与Goldfish相关的内容
Device Drivers ---> Character devices ---> < > Goldfish TTY Driver
Device Drivers ---> Power supply class support ---> < > Goldfish battery driver (NEW)
Device Drivers ---> Real Time Clock ---> < > GOLDFISH (NEW)
Device Drivers ---> Graphics support ---> Support for frame buffer devices ---> < > Goldfish Framebuffer
(4) 选择S3C2410 LCD相关的内容
Device Drivers ---> Graphics support ---> Support for frame buffer devices ---> S3C2410 LCD framebuffer support
Device Drivers ---> Graphics support ---> [*] Bootup logo ---> [*] Standard black and white Linux logo
Device Drivers ---> Graphics support ---> [*] Bootup logo ---> [*] Standard 16-color Linux logo
Device Drivers ---> Graphics support ---> [*] Bootup logo ---> [*] Standard 224-color Linux logo
(5) 选中Android内核必须选项
Kernel Features ---> [*] Use the ARM EABI to compile the kernel
General setup ---> [*] Use full shmem filesystem
General setup ---> [*] Enable Androids Shared Memory Subsystem
System Type ---> [*] Support Thumb user binaries
Device Drivers ---> Android ---> [*] Android log driver
Device Drivers ---> Android ---> Binder IPC Driver
(6) 尽量选中Android内核可选选项
Device Drivers ---> Android ---> [*] RAM buffer console
Device Drivers ---> Android ---> [*] Android timed gpio driver
Device Drivers ---> Android ---> [*] On
(7) 其余CONFIG选项,如系统支持请一并选择
CONFIG_ANDROID_POWER =y
CONFIG_ANDROID_POWER_STAT =y
CONFIG_ANDROID_POWER_ALARM =y
(可以在Kconfig文件中查找ANDROID_POWER等字段进行选择,或者直接修改.config文件)
13、退出并保存.config
二、移植LCD驱动到Linux-2.6.25内核
1、 进入kernel.git文件夹,如cd ~/kernel.git/
2、 修改arch/arm/mach-s3c2410/mach-smdk2410.c文件,如gedit arch/arm/mach-s3c2410/mach-smdk2410.c
(1) 增加头文件#include
(2) 增加两给结构体
static struct s3c2410fb_display smdk2410_lcd_cfg __initdata = {
.lcdcon5 = S3C2410_LCDCON5_FRM565 |
S3C2410_LCDCON5_INVVLINE |
S3C2410_LCDCON5_INVVFRAME |
S3C2410_LCDCON5_PWREN |
S3C2410_LCDCON5_HWSWP,
.type = S3C2410_LCDCON1_TFT,
.width = 320,
.height = 240,
.pixclock = 174757,
.xres = 320,
.yres = 240,
.bpp = 16,
.left_margin = 16,
.right_margin = 59,
.hsync_len = 9,
.upper_margin = 2,
.lower_margin = 6,
.vsync_len = 16,
static struct s3c2410fb_mach_info smdk2410_fb_info __initdata = {
.displays = &smdk2410_lcd_cfg,
.num_displays = 1,
.default_display = 0,
.gpccon = 0xaa955699,
.gpccon_mask = 0xffc003cc,
.gpcup = 0x0000ffff,
.gpcup_mask = 0xffffffff,
.gpdcon = 0xaa95aaa1,
.gpdcon_mask = 0xffc0fff0,
.gpdup = 0x0000faff,
.gpdup_mask = 0xffffffff,
.lpcsel = 0xf82,
(3) 在smdk2410_init()函数中增加s3c24xx_fb_set_platdata(&smdk2410_fb_info);
三、移植触摸屏驱动到Linux-2.6.25内核(参见《基于linux-2.26.5内核的FS2410开发板触摸屏驱动移植》)并制作zImage文件,如make
这里提一下,确保已经勾选Device Drivers ---> Input device support ---> Event interface,本人曾经在这里徘徊,感谢游老师悉心教诲!
四、制作支持ARMv4的Android根文件系统
1、从/zixunimg/eepwimg/www.rayfile.com/files/d4660882-de04-11dd-af0d-0014221b798a/下载Android的ARMv4版本根文件
2、在/dev下增加null和console两个设备节点
mknod -m 660 null c 1 3
mknod -m 660 console c 5 1
3、在U-boot中修改启动参数init为/init,完整的命令行如:root=nfs nfsroot=169.254.7.118:/source/rootfs ip=169.254.7.119 console=ttySAC0,115200 init=/init
4、修改/init.rc文件,去除除mount tmpfs tmpfs /sqlite_stmt_journals size=4m之外的所有mount命令
系统制作完成,现在应该可以看到漂亮的大表了。首次启动需要创建文件,大约17分钟。然后每次启动只需要2分钟。
