#include
#define uint unsigned int
#define uchar unsigned char
uchar temp,key=16;
sbit duan=P2^6;
sbit wei=P2^7;
sbit led0=P1^0;
sbit led1=P1^1;
uchar code table[]=
{0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x00};
void display(uchar);
uchar scan_key();
void delay(uchar);
void main()
wei=1;
P0=0x00;
wei=0;//位全选通
while(1)
display(scan_key());
void display(uchar x)
duan=1;
P0=table[x];
duan=0;
uchar scan_key()
P3=0xfe; //检测第一横排
temp=P3;
while(temp!=0xfe)
delay(20);
while(temp!=0xfe) //防抖检测
switch(temp)
case 0xee:{key=0;led0=0;break;}
case 0xde:{key=1;led1=0;break;}
case 0xbe:{key=2;break;}
case 0x7e:{key=3;break;}
default:break;
while(temp!=0xfe) //松手检测
temp=P3;
P3=0xfd; //检测第二横排
temp=P3;
while(temp!=0xfd)
delay(20);
while(temp!=0xfd)
switch(temp)
case 0xed:{key=4;break;}
case 0xdd:{key=5;break;}
case 0xbd:{key=6;break;}
case 0x7d:{key=7;break;}
default:break;
while(temp!=0xfd)
temp=P3;
P3=0xfb; //检测第三横排
temp=P3;
while(temp!=0xfb)
delay(20);
while(temp!=0xfb)
switch(temp)
case 0xeb:{key=8;break;}
case 0xdb:{key=9;break;}
case 0xbb:{key=10;break;}
case 0x7b:{key=11;break;}
default:break;
while(temp!=0xfb)
temp=P3;
P3=0xf7; //检测第4横排
temp=P3;
while(temp!=0xf7)
delay(20);
while(temp!=0xf7)
switch(temp)
case 0xe7:{key=12;break;}
case 0xd7:{key=13;break;}
case 0xb7:{key=14;break;}
case 0x77:{key=15;break;}
default:break;
while(temp!=0xf7)
temp=P3;
return key;
void delay(uchar x)
uchar i,j;
for(i=0;i
