//AVR单片机课程设计程序
//名称:电压表
//硬件:AVR-ATMEGA16 实验板 8MHz 晶振
//编写人:李春起
//修改日志:
#includeiom16v.h>
#include macros.h>//-------------位拉高宏--------------------------------------------
#define ADC0_H PORTA|=BIT(PA0) #define ADC1_H PORTA|=BIT(PA1)
#define LEDLK_H PORTA|=BIT(PA2) //流水灯选通
#define SEGLK_H PORTA|=BIT(PA3) //数码管段码选通
#define BITLK_H PORTA|=BIT(PA4) //数码管位选通//
#define 18B20_H PORTA|=BIT(PA5)
#define BEEP_H PORTA|=BIT(PA6) //蜂鸣器
#define CUSB_H PORTA|=BIT(PA7) //-------------位拉低宏-------------------------------------------
-#define ADC0_L PORTA=~BIT(PA0)
#define ADC1_L PORTA=~BIT(PA1)
#define LEDLK_L PORTA=~BIT(PA2)
#define SEGLK_L PORTA=~BIT(PA3)
#define BITLK_L PORTA=~BIT(PA4) //
#define 18B20_L PORTA=~BIT(PA5)
#define BEEP_L PORTA=~BIT(PA6)
#define CUSB_L PORTA=~BIT(PA7) //----------单独按键宏定义--------------------------------
#define S1 (PIND0X01)==0
#define S2 (PIND0X02)==0
#define S3 (PIND0X04)==0#define S4 (PIND0X08)==0
#define NOP() asm("nop")#define uchar unsigned char #define uint unsigned int//============全局变量======================================uint adc0,flag,voldata;//AD转换结果//===================数据表==============================================__flash uchar SEG[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0xff};//===============mS延时子程序============================================void delayms(uint m){uint i,j;for(i=0;im;i++){for(j=0;j1141;j++);}}//==================IO口初始化=======================================void IO_init(void){DDRA = 0Xfe;DDRB = 0Xff;DDRC = 0XFF;DDRD = 0XFF;PORTD= 0XFF;}//====================定时器T0初始化===================================void timer0_init(void){TCCR0 = 0x0c; //256分频 CTC模式TCNT0 = 0x00; //计数器清0OCR0 = 100; //187*256/8M=4.16mSTIMSK |=0x02; //使能OCIE0TIFR |=0x02; //清OCIF0中断标识位}//=================初始化======================================void init(void){IO_init();BEEP_H;timer0_init();}//===============AD转换===========================void read_adc(void) { ADMUX =0x00;//选择PA0转换通道 ADCSRA=0xE6;//开始AD转换 while ((ADCSRA 0x10)==0); //等待ad转换结束 adc0 = ADCL;adc0 |= ADCH8; }//===================消残影========================================void clear_LED(void){SEGLK_H;PORTB=0x00; SEGLK_L;}//===================显示==========================void disp(void){SEGLK_H;PORTB=SEG[adc0%10];SEGLK_L;BITLK_H;PORTB=0xdf;BITLK_L;delayms(3);clear_LED();SEGLK_H;PORTB=SEG[(adc0/10)%10];SEGLK_L;BITLK_H;PORTB=0xef;BITLK_L;delayms(3);clear_LED();SEGLK_H;PORTB=SEG[(adc0/100)%10];SEGLK_L;BITLK_H;PORTB=0xf7;BITLK_L;delayms(3);clear_LED();SEGLK_H;PORTB=SEG[adc0/1000];SEGLK_L;BITLK_H;PORTB=0xfb;BITLK_L;delayms(3);clear_LED();SEGLK_H;PORTB=SEG[0];SEGLK_L;BITLK_H;PORTB=0xfd;BITLK_L;delayms(3);clear_LED();SEGLK_H;PORTB=SEG[0];SEGLK_L;BITLK_H;PORTB=0xfe;BITLK_L;delayms(3);clear_LED();clear_LED();}//================================================//------------------------------------------------//--------------主函数----------------------------//------------------------------------------------void main(void){init();SFIOR=0X00;SREG|=0x80;adc0=1224;LEDLK_H;PORTB=0XFF;//灭掉流水灯LEDLK_L;while(1){read_adc();// disp();voldata=adc0;}}//---------------------------------------------//---------------------------------------------//=============================================//====================定时器T0中断服务子程序========================#pragma interrupt_handler Timer0_Interrupt:20void Timer0_Interrupt(void){TCNT0 = 0X00;TIFR |=0x02; //清OCIF0中断标识位clear_LED();switch(flag){case 0:{SEGLK_H;PORTB=SEG[voldata%10];SEGLK_L;BITLK_H;PORTB=0xdf;BITLK_L;flag=1;}break;case 1:{SEGLK_H;PORTB=SEG[(voldata/10)%10];SEGLK_L;BITLK_H;PORTB=0xef;BITLK_L;flag=2;}break;case 2:{SEGLK_H;PORTB=SEG[(voldata/100)%10];SEGLK_L;BITLK_H;PORTB=0xf7;BITLK_L;flag=3;}break;case 3:{SEGLK_H;PORTB=SEG[voldata/1000];SEGLK_L;BITLK_H;PORTB=0xfb;BITLK_L;flag=0;}break;default:break;}
