读写AVR单片机EEPROM实验。
先向单片机EEPROM写入254,然后读出254,
并在数码管上显示出来
#includeiom16v.h>
const unsigned char duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
const unsigned char weima[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char shu[8];
unsigned int num;
延时函数
void delay(unsigned char t)
unsigned char x,y;
for(x=t;x>0;x--)
for(y=100;y>0;y--);
显示函数
void display(void)
unsigned char i;
for(i=0;i4;i++)
PORTB =0X00;
PORTA|=0X01;
PORTA=0XFE;
PORTB =weima[i];
PORTA|=0x02;
PORTA=0XFD;
PORTB=shu[i];
PORTA|=0X01;
PORTA=0XFE;
delay(4);
写EEPROM
void write_eep(unsigned int add,unsigned int data)
{ //data为待写数据,add为某单元地址
while(EECR(1EEWE)); //等待前一次写操作完成
EEAR=add; //设定单元地址
EEDR=data; //将数据写入EEDR
EECR|=(1EEMWE); //允许EEPROM操作
EECR|=(1EEWE); //开始EEPROM操作
读EEPROM
unsigned char read_eep(unsigned int add)
{ //add为某单元地址
while(EECR(1EEWE));//等待前一次写操作完成
EEAR=add; //设定单元地址
EECR|=(1EERE); //开始EEPROM写操作
return EEDR; //返回读出的数据
数据转换子函数
void change(unsigned int i)
shu[0]=duanma[i/1000];
shu[1]=duanma[i/100%10];
shu[2]=duanma[i%100/10];
shu[3]=duanma[i%10];
端口初始化
void init_port(void)
PORTA=0XFF;
DDRA=0XFF;
PORTB=0XFF;
DDRB=0XFF;
MAIN
void main(void)
init_port();
write_eep(488,254);
delay(20);
num=read_eep(488);
delay(20);
change(num);
while(1)
display();
