NEC单片机 UPD78F9234 16位定时器使用例程(汇编) ;************************************************* ; Lable def ;************************************************* LED8_MODE EQU PM2.1 LED7_MODE EQU PM2.0 LED6_MODE EQU PM12.0 LED5_MODE EQU PM0.3 LED4_MODE EQU PM0.2 LED3_MODE EQU PM0.1 LED2_MODE EQU PM0.0 LED1_MODE EQU PM12.3 LED8 EQU P2.1 LED7 EQU P2.0 LED6 EQU P12.0 LED5 EQU P0.3 LED4 EQU P0.2 LED3 EQU P0.1 LED2 EQU P0.0 LED1 EQU P12.3
;=========================(debugresource)======================================={ ;************************************************* ; VAR DEF ;*************************************************
DATA_SEGMENT1DSEGSADDR ;(AT 0FE20H)
VAR_1: DS1
ORG 018H DB 0FFH,0FFH; ORG 07EH DB 0FFH,0FFH;
ORG 81H DB 0FFH;
ORG 01ED0H DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH ;=================================================================================
;************************************************* ;INTERRUPT VECT ;*************************************************
ORG 0000H DW START_PROGRAM
ORG 000EH DW INTTM000_VECT
;************************************************* ;CODE ;************************************************* CSEG ;(ATXXXXH) START_PROGRAM:
DI MOVW AX,#0FE20H; MOVW SP,AX;
MOV PCC,#00H; MOV PPCC,#00H;
CALL!DELAY_1MS; CALL!DELAY_1MS; CALL!DELAY_1MS; CALL!DELAY_1MS; CALL!DELAY_1MS;
MOV PMC2,#00H MOV PM2,#0FFH
; SET TM00 MOV TMC00,#00H
MOV PRM00,#02H ;31.25KHz 32us
MOVW AX,#31250;9800 ;313.6ms 15625 MOVW CR000,AX
CLR1 TMIF000 ;clear sign CLR1 TMMK000 ;allow interrupt
MOV TMC00,#0CH ;clear the CR000 when TM00=CR000
EI
CLR1LED1_MODE CLR1LED2_MODE CLR1LED3_MODE CLR1LED4_MODE CLR1LED5_MODE CLR1LED6_MODE CLR1LED7_MODE CLR1LED8_MODE
SET1 LED1 SET1 LED2 SET1 LED3 SET1 LED4 SET1 LED5 SET1 LED6 SET1 LED7 SET1 LED8
CLR1LED1
MAIN:
MOV WDTE,#0ACH;
BR !MAIN
;************************************************* ; SUB PROGRAM ;************************************************* CSEG DELAY_1MS:
MOVB,#0FFH BBBB: DBNZ B,$BBBB; RET
;************************************************* ;INTERRUPT FUNCTION ;************************************************* CSEG INTTM000_VECT:
BT LED1,$LED22 ;jump if LED1=1 SET1 LED1 CLR1 LED2 BR !backtrack
LED22: BT LED2,$LED33 SET1 LED2 CLR1 LED3 BR !backtrack
LED33: BT LED3,$LED44 SET1 LED3 CLR1 LED4 BR !backtrack
LED44: BT LED4,$LED55 SET1 LED4 CLR1 LED5 BR !backtrack
LED55: BT LED5,$LED66 SET1 LED5 CLR1 LED6 BR !backtrack
LED66: BT LED6,$LED77 SET1 LED6 CLR1 LED7 BR !backtrack
LED77: BT LED7,$LED88 SET1 LED7 CLR1 LED8 BR !backtrack
LED88: BT LED8,$INTTM000_VECT SET1 LED8 CLR1 LED1 BR !backtrack
backtrack:
RETI
END UPD78F9234产品参数: MCU 8BIT 8KB FLASH 30PIN 核心处理器:78K0S 芯体尺寸:8-位 速度:10MHz 连通性:LIN,UART/USART 外围设备:LVD, POR, PWM, WDT 输入/输出数:24 程序存储器容量:8KB (8K x 8) 程序存储器类型:FLASH EEPROM 大小:- RAM 容量:256 x 8 电压 - 电源 (Vcc/Vdd):2 V ~ 5.5 V 数据转换器:A/D 4x10b 振荡器型:内部 工作温度:-40°C ~ 85°C
