The MPC5125 integrates a high performance e300 CPU core based on the Power Architecture™ Technology with a rich set of peripheral functions focused on communications and systems integration.
MPC5125主要特性:
Major features of the MPC5125 are as follows:
• e300 Power Architecture processor core (enhanced version of the MPC603e core), operates as fast as 400 MHz
• Low power design
• Display interface unit (DIU)
• DDR1, DDR2, low-power mobile DDR (LPDDR), and 1.8 V/3.3 V SDR DRAM memory controllers
• 32 KB on-chip SRAM
• USB 2.0 OTG controller with ULPI interface
• DMA subsystem
• Flexible multi-function external memory bus (EMB) interface
• NAND flash controller (NFC)
• LocalPlus interface (LPC)
• 10/100Base Ethernet
• MMC/SD/SDIO card host controller (SDHC)
• Programmable serial controller (PSC)
• Inter-integrated circuit (I2C) communication interfaces
• Controller area network (CAN)
• J1850 byte data link controller (BDLC) interface
• On-chip real-time clock (RTC)
• On-chip temperature sensor
• IC Identification module (IIM)
MPC5125目标应用:
Fieldbus to Ethernet Gateways
Robotics
Industrial Networking Gateways (routers) and converters
High End Lighting Control
Fire & Alarm Supervisory Controllers
HVAC Central Management System
Digital Signage
Point of Sales Terminal
Hospital Bed Control
Smart Hospital and Tele-Health Gateways
图1.MPC5125方框图
The MPC5125 Tower System is based on Freescale’s MPC5125 microprocessor. The board provides on-board DDR2 SDRAM, NAND FLASH,CAN ports, USB 2.0, 10/100 Ethernet, HDMI,USB Debug Port.All powered from a 5 Volt wall mount power supply.
Freescale’s Tower System.
图2.MPC5125 Tower System外形图.
图3.MPC5125评估板电路图(1)
图4.MPC5125评估板电路图(2)
图5.MPC5125评估板电路图(3)
图6.MPC5125评估板电路图(4)
图7.MPC5125评估板电路图(5)
图8.MPC5125评估板电路图(6)
图9.MPC5125评估板电路图(7)
图10.MPC5125评估板电路图(8)
图11.MPC5125评估板电路图(9)
图12.MPC5125评估板电路图(10)
图13.MPC5125评估板电路图(11)
图14.MPC5125评估板电路图(12)
图15.MPC5125评估板电路图(13)
图16.MPC5125评估板电路图(14)
图17.MPC5125评估板电路图(15)
图18.MPC5125评估板电路图(16)
