AHB:advanced high-performance bus;APB: advanced peripherals bus。
static void SetSysClockTo72(void)
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------
SYSCLK 由PLL时钟,外部高速时钟,内部高速时钟获得,最大为72MHz
HCLK 由HCLK经过AHB预分频器得到,最大72MHz,至AHB总线,核心存储器和DMA
PCLK2 最大72MHz ,至APB2 外设
PCLK1 最大36MHz,至APB1外设
/* 使能高速外部晶振*/
RCC->CR |= ((uint32_t)RCC_CR_HSEON);
/* 等待外部高速时钟稳定*/
do
HSEStatus = RCC->CR & RCC_CR_HSERDY;
StartUpCounter++;
} while((HSEStatus == 0) && (StartUpCounter != HSEStartUp_TimeOut));
if ((RCC->CR & RCC_CR_HSERDY) != RESET)
HSEStatus = (uint32_t)0x01;
else
HSEStatus = (uint32_t)0x00;
if (HSEStatus == (uint32_t)0x01)
/* FLASH 存取控制寄存器配置 使能预取,两个等待周期(36MHz --72MHz为2个等待周期)*/
FLASH->ACR |= FLASH_ACR_PRFTBE;
/* Flash 2 wait state */
FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
/* 先对HCLK PCLK1 PCLK2初始化
时钟配置寄存器 上电初始化初值应为为 0 如下配置的结果是:
8M的高速内部时钟为系统时钟
HCLK = 8M
PCLK2 = 8M
PCLK1 = 4M
/* HCLK = SYSCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
/* PCLK2 = HCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
/* PCLK1 = HCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
#ifdef STM32F10X_CL
/* Configure PLLs ------------------------------------------------------*/
/* 如果定义了STM32F10x_CL 则进行如下 配置 该宏定义在编译选项中定义 */
/* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
/* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
PLL2 配置: 时钟信号输入源为PREDIV1, 8倍频后5分频
/*清零相关控制域*/
RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
/* 配置CFGR2寄存器*/
RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
/* Enable PLL2 */
RCC->CR |= RCC_CR_PLL2ON;
/* Wait till PLL2 is ready */
while((RCC->CR & RCC_CR_PLL2RDY) == 0)
/* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
RCC_CFGR_PLLMULL9);
#else
/* PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
#endif /* STM32F10X_CL */
/* Enable PLL 使能PLL*/
RCC->CR |= RCC_CR_PLLON;
/* Wait till PLL is ready */
while((RCC->CR & RCC_CR_PLLRDY) == 0)
Select PLL as system clock source
选择PLL时钟作为系统时钟,并等待稳定
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
/* Wait till PLL is used as system clock source */
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
else
{ /* If HSE fails to start-up, the application will have wrong clock
configuration. User can add here some code to deal with this error */
HSE(25MHZ)->PREDIV2(5分频)——5MHZ——>PLL2MUL(8倍频)——40MHZ——>PREDIV1SCR(选择PLL2)——40MHZ——>PREDIV1(5分频)——8MHZ——>PLLSCR(PREDIV1输入)——8MHZ——>PLLMUL(9倍频)——72MHZ——>SW(选择PLL)——SYSCLK(72MHZ).
