嵌入式 > 嵌入式开发 > 详情
STM32 通用定时器的几种配置方式
发布时间:2025-08-25 发布时间:
1、普通定时使用
#include"stm32f10x.h"
#include"time.h"
static Time_NVIC_Config(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0000);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = TIMx_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
static void Time_Config(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIMx,ENABLE);
//TIM_DeInit(TIM2);
TIM_TimeBaseInitStructure.TIM_Prescaler =(10000-1); //时钟分频系数
TIM_TimeBaseInitStructure.TIM_Period =(7200-1); //自动重装寄存器
TIM_TimeBaseInitStructure.TIM_CounterMode =TIM_CounterMode_Up; //向上计数模式
TIM_TimeBaseInitStructure.TIM_ClockDivision =0; //时钟分割,这里不涉及
#if 0
TIM_TimeBaseInitStructure.TIM_RepetitionCounter; //This parameter is valid only for TIM1 and TIM8
#endif
TIM_TimeBaseInit(TIMx,&TIM_TimeBaseInitStructure); //配置参数
TIM_ClearITPendingBit(TIMx,TIM_IT_Update); //清除中断标示位
TIM_ITConfig(TIMx,TIM_IT_Update,ENABLE); //中断配置
TIM_Cmd(TIMx,ENABLE); //启动定时器
void Time_Init(void)
Time_Config(); //定时器配置
Time_NVIC_Config(); //嵌套中断向量初始化
2、PWM输出
#include"time.h"
#if 0
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
#endif
void Time_OUT_PWM_GPIO_Config(void)
RCC_APB2PeriphClockCmd(TIMx_OUT_GPIO_RCC,ENABLE);
GPIO_InitStructure.GPIO_Pin =TIMx_OUT_Pin;
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP; //复用推免式输出
GPIO_Init(TIMx_OUT_Port, &GPIO_InitStructure);
static void Time_OUT_PWM_Config(void)
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIMx,ENABLE); //开启时钟
TIM_DeInit(TIM2);
TIM_TimeBaseInitStructure.TIM_Prescaler =(100-1); //时钟分频系数
TIM_TimeBaseInitStructure.TIM_Period =(1000-1); //自动重装寄存器 PWM频率:72M/100/1000=720Hz
TIM_TimeBaseInitStructure.TIM_ClockDivision =0; //时钟分频,这里不涉及
#ifdef Time1
#endif
TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_PWM1; //PWM1模式 OCx电平根据ARR与CCRx比较结果发生反转
TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; //输出使能通道1
#ifdef Time1
TIM_OCInitStructure.TIM_OutputNState =;
#endif
TIM_OCInitStructure.TIM_Pulse =CCR1_VAL; //占空比800/1000
TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_Low; //计数器值小于CCR值时输出高电平
#ifdef Time1
TIM_OCInitStructure.TIM_OCNPolarity =;
TIM_OCInitStructure.TIM_OCIdleState =;
TIM_OCInitStructure.TIM_OCNIdleState =;
#endif
TIM_OC1Init(TIMx,&TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIMx,TIM_OCPreload_Enable); //使能CCR1预装载
TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; //输出使能通道2
TIM_OCInitStructure.TIM_Pulse =CCR2_VAL;
TIM_OC2Init(TIMx,&TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIMx,TIM_OCPreload_Enable);
TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; //输出使能通道3
TIM_OCInitStructure.TIM_Pulse =CCR3_VAL;
TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_High;
TIM_OC3Init(TIMx,&TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIMx,TIM_OCPreload_Enable);
TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; //输出使能通道4
TIM_OCInitStructure.TIM_Pulse =CCR4_VAL;
TIM_OC4Init(TIMx,&TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIMx,TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIMx,ENABLE); //开启ARR预装载
void Time_OUT_PWM_Init(void)
Time_OUT_PWM_GPIO_Config();
Time_OUT_PWM_Config(); //定时器配置
3、输出比较模式
#include"time.h"
static void Time_OUT_PWM_GPIO_Config(void)
GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
static void Time_GPIO_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD,ENABLE);
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP; //通用推免式输出
GPIO_Init(GPIOD, &GPIO_InitStructure);
TIM_DeInit(TIM2);
#ifdef Time1
#endif
TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_Inactive; //ARR与CCRx相同时强制OCxREF为低
#ifdef Time1
#endif
TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_High; //OCx=!OCxREF _High OCx=OCxREF
#ifdef Time1
#endif
TIM_ITConfig(TIMx,TIM_IT_CC1,ENABLE); //使能OC1比较中断
TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_Active; //ARR与CCRx相同时强制OCxREF为高
TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_Low; //OCx=!OCxREF _High OCx=OCxREF
TIM_ITConfig(TIMx,TIM_IT_CC2,ENABLE);
TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_Timing; //ARR与CCRx比较结果对OCxREF无效
TIM_ITConfig(TIMx,TIM_IT_CC3,ENABLE);
TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_PWM1; //ARR与CCRx比较结果对OCxREF采用PWM1模式
//TIM_ITConfig(TIMx,TIM_IT_CC4,ENABLE); //PWM就没有必要设置中断 当然也可以在中断里面改变占空比
Time_GPIO_Config();
Time_NVIC_Config();
4、PWMI模式
#include"time.h"
关于Linux系统如何挂载数据盘
