嵌入式 > 嵌入式开发 > 详情
USB标准设备请求
发布时间:2022-05-30 发布时间:
This section describes the standard device requests defined for all USB devices. Table 9-3 outlines the standard device requests, while Table 9-4 and Table 9-5 give the standard request codes and descriptor types,
respectively.USB devices must respond to standard device requests, even if the device has not yet been assigned an address or has not been configured.
Feature selectors are used when enabling or setting features, such as remote wakeup, specific to a device,interface, or endpoint. The values for the feature selectors are given in Table 9-6.
If an unsupported or invalid request is made to a USB device, the device responds by returning STALL inthe Data or Status stage of the request. If the device detects the error in the Setup stage, it is preferred that the device returns STALL at the earlier of the Data or Status stage. Receipt of an unsupported or invalid request does NOT cause the optional Halt feature on the control pipe to be set. If for any reason, the device becomes unable to communicate via its Default Control Pipe due to an error condition, the device must be reset to clear the condition and restart the Default Control Pipe.
五大标准轻松搞定4K超高清电视选购
