下面贴出源代码,有详细注释。。。。
本程序简单实用,可拿去作简单参考。。。。
编译环境:GCC+AVR STUDIO
单片机:ATMEGA 8515
晶振: 3.6864M
#include<avr/io.h> //包含头文件
#include
#define COMMAND 1
#define DATA 0
//数据线定义:
// SI==========PB5 //
// A0==========PC0
// CS==========PC2
// RES=========PC1
// SCL=========PB7
unsigned char gushi[8][112]PROGMEM=
{0x10,0x10,0x92,0x92,0x92,0xF2,0x9E,0x92,0x92,0x92,0x92,0x92,0xFE,0x10,0x10,0x00, //君问归期未有期
0x00,0x00,0xF8,0x01,0x06,0xE0,0x22,0x22,0x22,0x22,0xE2,0x02,0x02,0xFE,0x00,0x00,
0x00,0xF8,0x00,0x00,0xFF,0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0xFC,0x00,0x00,
0x00,0x04,0xFF,0x54,0x54,0x54,0xFF,0x04,0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00,
0x40,0x40,0x48,0x48,0x48,0x48,0xC8,0xFF,0x48,0x48,0x48,0x48,0x48,0x40,0x40,0x00,
0x00,0x04,0x84,0x44,0xE4,0x34,0x2C,0x27,0x24,0x24,0x24,0xE4,0x04,0x04,0x04,0x00,
0x00,0x04,0xFF,0x54,0x54,0x54,0xFF,0x04,0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00},
{0x40,0x20,0x10,0x0C,0xFE,0x45,0x44,0x44,0x44,0x44,0x44,0x44,0xFD,0x00,0x00,0x00,
0x00,0x00,0xFF,0x00,0x00,0x03,0x02,0x02,0x02,0x02,0x03,0x40,0x80,0x7F,0x00,0x00,
0x00,0x87,0x40,0x30,0x0F,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x00,0x00,
0x42,0x22,0x1B,0x02,0x02,0x0A,0x33,0x62,0x18,0x07,0x02,0x22,0x42,0x3F,0x00,0x00,
0x20,0x20,0x10,0x10,0x08,0x06,0x01,0xFF,0x01,0x02,0x04,0x08,0x18,0x30,0x10,0x00,
0x02,0x01,0x00,0x00,0xFF,0x09,0x09,0x09,0x29,0x49,0xC9,0x7F,0x00,0x00,0x00,0x00,
0x42,0x22,0x1B,0x02,0x02,0x0A,0x33,0x62,0x18,0x07,0x02,0x22,0x42,0x3F,0x00,0x00},
{0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0x7E,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,0x00, //巴山夜雨涨池
0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,
0x04,0x04,0x84,0xC4,0x3C,0x14,0x85,0x66,0xBC,0x24,0x24,0x24,0xE4,0x24,0x04,0x00,
0x02,0x02,0xF2,0x32,0x52,0x92,0x12,0xFE,0x32,0x52,0x92,0x12,0xF2,0x02,0x02,0x00,
0x10,0x61,0x86,0x60,0xF2,0x12,0x12,0x1E,0x80,0xFF,0xA0,0x90,0x88,0x86,0x80,0x00,
0x24,0x24,0xE4,0xFC,0xA2,0x22,0x22,0x80,0x70,0x00,0xFF,0x40,0x20,0x18,0x00,0x00,
0x10,0x60,0x02,0x8C,0x60,0x80,0xF8,0x40,0x40,0xFE,0x20,0x20,0x10,0xF0,0x00,0x00},
{0x00,0x00,0x3F,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x78,0x20,0x00,
0x00,0x20,0x7F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x7F,0x00,0x00,
0x02,0x01,0x00,0xFF,0x00,0x82,0x41,0x22,0x14,0x09,0x14,0x23,0x40,0xC0,0x40,0x00,
0x00,0x00,0xFF,0x01,0x02,0x04,0x00,0x7F,0x01,0x02,0x44,0x80,0x7F,0x00,0x00,0x00,
0x04,0xFC,0x03,0x00,0x01,0x41,0x81,0x7F,0x00,0xFF,0x42,0x0C,0x30,0x60,0x20,0x00,
0x02,0x01,0x00,0xFF,0x00,0x83,0x40,0x20,0x18,0x07,0x01,0x06,0x18,0xE0,0x40,0x00,
0x08,0x08,0x7C,0x03,0x00,0x00,0x3F,0x40,0x40,0x5F,0x40,0x42,0x44,0x43,0x70,0x00},
{0x80,0x40,0xF0,0x1C,0x07,0xE2,0x24,0x24,0x24,0xE4,0x04,0x04,0xFC,0x04,0x04,0x00, //何当共剪西窗烛
0x00,0x00,0x40,0x42,0x5C,0x48,0x40,0x40,0x7F,0x40,0x50,0x4E,0x44,0xC0,0x00,0x00,
0x00,0x10,0x10,0x10,0x10,0xFE,0x10,0x10,0x10,0x10,0xFE,0x10,0x10,0x10,0x00,0x00,
0x00,0x04,0xF4,0x54,0x55,0x56,0x54,0xF4,0x04,0x04,0xE6,0x05,0x04,0xF4,0x04,0x00,
0x02,0xF2,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xF2,0x02,0x00,
0x00,0x4C,0x44,0xE4,0x54,0x44,0x64,0xD5,0x46,0x44,0x4C,0x54,0xD4,0x24,0x2C,0x00,
0x80,0x60,0x00,0xFF,0x20,0x18,0xF0,0x10,0x10,0xFF,0x12,0x10,0xF0,0x10,0x00,0x00},
{0x00,0x00,0x7F,0x00,0x00,0x07,0x02,0x02,0x02,0x07,0x20,0x40,0x3F,0x00,0x00,0x00,
0x00,0x00,0x20,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x7F,0x00,0x00,
0x02,0x02,0x82,0x42,0x32,0x1F,0x0A,0x02,0x02,0x06,0x0B,0x32,0xE2,0x42,0x02,0x00,
0x00,0x08,0x8F,0x89,0x49,0x2B,0x1D,0x0B,0x08,0x08,0x08,0x4A,0x8C,0x7B,0x00,0x00,
0x00,0x7F,0x28,0x24,0x22,0x21,0x20,0x20,0x20,0x21,0x22,0x22,0x22,0x7F,0x00,0x00,
0x00,0x00,0x00,0xFF,0x44,0x62,0x55,0x49,0x55,0x43,0x41,0x40,0xFF,0x00,0x00,0x00,
0x40,0x20,0x18,0x07,0x04,0x28,0x63,0x21,0x21,0x3F,0x11,0x15,0x1B,0x30,0x00,0x00},
{0x80,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x00,0xFE,0x02,0x02,0x02,0xFE,0x00,0x00, //却话巴山夜雨时
0x40,0x41,0x4E,0xC4,0x00,0x20,0x24,0x24,0x24,0x24,0xFC,0x22,0x22,0x22,0x20,0x00,
0x00,0xFC,0x44,0x44,0x44,0xFC,0x10,0x90,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x00},
{0x00,0x10,0x3C,0x13,0x10,0x08,0x0A,0x1C,0x08,0xFF,0x00,0x08,0x10,0x0F,0x00,0x00,
0x00,0x00,0x00,0x7F,0x20,0x10,0x00,0x7E,0x22,0x22,0x23,0x22,0x22,0x7E,0x00,0x00,
0x00,0x07,0x04,0x04,0x04,0x07,0x00,0x00,0x03,0x40,0x80,0x7F,0x00,0x00,0x00,0x00},
//发送一个字节到ST7565P并等待发送完毕
//入口:要发送的字节
//返回值:无
void SPIByte(unsigned char byte)
//将一个字节发送的ST7565P的函数
//入口参数: select ,data
//select:根据此值确定发送给ST7565P的是数据还是命令
//data: 要发送给ST7565的一个字节
//返回值:无
void LCD_SPISend(unsigned char select,unsigned char data)
//写坐标函数
//入口参数:x y
//y: 页面地址,此液晶将显示区域分为9个页面,y的值域0~8
//x: 列地址,值域:0~127
//返回值:无
void LCD_XYSet(unsigned char x,unsigned char y)
//延时函数
//入口: ms 当延时100毫秒时,ms的值为100即可
//返回值:无
void DelayMs(volatile unsigned int ms)
