基于AVR单片机ATmega16的8种LED闪烁灯控制转载标签:
#include iom16v.h>
#include macros.h>
#define uchar unsigned char
#define uint unsigned int
void Delay() //延时函数
uchar a, b, c;
for (a = 1; a; a++)
for (b = 1; b; b++)
for (c = 0; c10; c++) //循环次数=255*255*10
void DelayMs(uint i) //1ms延时,准确性较Delay();高
while(i--)
uint j;
for(j=1;j=613;j++)
void LED_on() //打开所有LED
PORTB =0X00;
Delay();
void LED_off() //关闭所有LED
PORTB = 0xFF;
Delay();
void LED_01(int i) //LED亮灭控制
PORTB = ~BIT(i); //输出低电平
DelayMs(100); //调用延时程序
void LED_02(int i) //间隔点亮
PORTB=~(BIT(i)|BIT(i-2));
DelayMs(100);
void LED_03(int i) //相临点亮
PORTB=~(BIT(i)|BIT(i-1)); //~后内容需用括号括起来
DelayMs(100);
void LED_04(int i) //发散聚集点亮
switch(i)
case 0:PORTB=0xE7;DelayMs(100);break; //延时100ms
case 1:PORTB=0xDB;DelayMs(100);break;
case 2:PORTB=0xBD;DelayMs(100);break;
case 3:PORTB=0x7E;DelayMs(100);break;
default:break;
void LED_05(int i) //00,0F,F0,FF方式显示
switch(i)
case 0:PORTB=0x00;DelayMs(100);break; //延时100ms
case 1:PORTB=0x0F;DelayMs(100);break;
case 2:PORTB=0xF0;DelayMs(100);break;
case 3:PORTB=0xFF;DelayMs(100);break;
default:break;
void LED_06(int i)
switch(i)
case 0:PORTB=0XAA;DelayMs(100);break;
case 1:PORTB=0X55;DelayMs(100);break;
void main()
int l,m,n,o,p,q,r,s,i,j;
DDRA =0X00; //端口上拉输入
PORTA=0XFF;
DDRB =0xFF; //端口输出
PORTB="0xFF"; //输出高电平,LED熄灭
DDRC =0X00;
PORTC=0XFF;
DDRD =0X00;
PORTD=0XFF;
for (r=0;r5;r++)
for(l=0;l5;l++) //模式1:顺序点亮
for (i = 0; i 8; i++) //顺序单个点亮LED
LED_01(i);
for (i = 6; i > 0; i--) //逆序单个点亮LED
LED_01(i);
LED_off();
for(m=0;m5;m++) //模式2:顺序单个间隔点亮
for (i = 0; i 8; i += 2) //顺序间隔点亮LED
LED_01(i);
for (i = 7; i > 0; i -= 2) //逆序间隔点亮LED
LED_01(i);
LED_off();
for(n=0;n5;n++) //模式3:间隔点亮
for (i = 2; i 8; i++) //间隔顺序同时点亮
LED_02(i);
for (i = 6; i > 2; i--) //间隔逆序同时点亮
LED_02(i);
LED_off();
for(o=0;o5;o++) //模式4:相临点亮
for (i = 1; i 8; i++) //相临顺序同时点亮
LED_03(i);
for (i = 6; i > 1; i--) //相临逆序同时点亮
LED_03(i);
LED_off();
for(p=0;p5;p++) //模式5:发散聚集点亮
for(i=0;i4;i++) //发散点亮
LED_04(i);
for(i=2;i>0;i--) //聚集点亮
LED_04(i);
LED_off();
for(q=0;q5;q++) //模式6:四四点亮
for(i=0;i4;i++) //四四顺序点亮
LED_05(i);
for(i=2;i>0;i--) //四四逆序点亮
LED_05(i);
LED_off();
for(s=0;s5;s++) //模式7:四四点亮
for(i=0;i2;i++) //四四顺序点亮
LED_06(i);
LED_off();
for(j=0;j10;j++) //模式8:全部点亮熄灭
LED_on();
LED_off();
//MCUCR=0x40; //空闲模式,CPU占用100%
//MCUCR=0x50; //ADC噪声抑制模式,CPU占用100%
//MCUCR=0x60; //掉电模式,CPU占用80%
//MCUCR=0x70; //省电模式,CPU占用4%
//MCUCR=0xE0; //Standby模式,CPU占用80%
MCUCR=0xF0; //扩展Standby模式,CPU占用4%
asm("sleep"); //CPU休眠指令
