嵌入式 > 嵌入式开发 > 详情
单片机控制点阵LED一秒刷新显示I心形U
发布时间:2025-06-19 发布时间:
本程序所用的原理图下载:点这里,单片机芯片使用的stc89c52;找到点阵部分的原理图即可.这是一整个单片机开发板的电路图其他的忽略
下面是程序源码:
/******点阵LED刷新显示I LVOE U**************/
*功能:点阵LED一秒刷新显示I 心形 U(I LOVE YOU)
*作者:徐冉
*日期:2013-06-14-22:44
*备注:程序已调试成功
/*************AT89C52-RC MCU*******************/
/**************51hei开发板********************/
#include
typedef unsigned int uint;
typedef unsigned char uchar;
sbit din = P2^0;
sbit cs = P2^1;
sbit clk = P2^2;
uchar code table[5][8] = {
{0x00,0x3C,0x18,0x18,0x18,0x18,0x3C,0x00}, //I
{0x00,0x66,0xFF,0xFF,0xFF,0x7E,0x3C,0x18}, //心
{0x00,0x66,0x66,0x66,0x66,0x7E,0x3C,0x00}, //U
uchar i, j;
uint counter;
//写字节
void write_byte(uchar date)
uchar i;
cs = 0;
for(i = 0; i < 8; i++)
clk = 0;
din = date & 0x80;
date <<= 1;
clk = 1;
//写MAX7219
void write_max7219(uchar add, uchar date)
cs = 0;
write_byte(add);
write_byte(date);
cs = 1;
//MAX7219初始化
void max7219_init()
write_max7219(0x0c, 0x01);//正常模式
write_max7219(0x09, 0x00);//译码模式
write_max7219(0x0a, 0x08);//亮度控制
write_max7219(0x0b, 0x07);//扫描模式
write_max7219(0x0f, 0x00);//显示检测
//定时器T0初始化
void timer0_init()
TMOD = 0x01;
TH0 = 0x94; //定时30ms
TL0 = 0x00;
TR0 = 1;
EA = 1;
ET0 = 1;
//主程序
void main(void)
max7219_init();
timer0_init();
while(1)
if(i >= 8)
i = 0;
if(counter == 40)
counter = 0;
j++;
if(j >= 3)
j = 0;
write_max7219(i+1, table[j][i]);
//中断服务程序
void timer0_int() interrupt 1
TH0 = 0x94;
TL0 = 0x00;
i++;
counter++;
CANopen 总线插头接线的注意事项
