单片机 > 单片机程序设计 > 详情
51单片机手机拨号模块
发布时间:2023-04-10 发布时间:
#include
#include
#define Delaynop(){_nop_();_nop_();_nop_();_nop_();}
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=P2^2;
void Delayms(unsigned int ms);
bit LCD_Busy();
void LCD_Pos(unsigned char);
void LCD_Wcmd(unsigned char);
void LCD_Wdat(unsigned char);
char code Title_Text[]={"--Phone Code-- "};
unsigned char code Key_Table[]={'1','2','3','4','5','6','7','8','9','*','0','#'};
unsigned char Dial_Code_Str[]={" "};
unsigned char KeyNo=0xff;
int tCount=0;
//毫秒级延时函数
void Delayms(unsigned int x)
unsigned char i;
while(x--)
for(i=0;i<120;i++);
//显示字符串
void Display_String(unsigned char *str,unsigned char LineNo)
unsigned char k;
LCD_Pos(LineNo);
for(k=0;k<16;k++)
LCD_Wdat(str[k]);
//检查1602是否处于忙装填
bit LCD_Busy_Check()
bit Result;
RS=0;
RW=1;
EN=1;
Delaynop();
Result=(bit)(P0 & 0x80);
EN=0;
return Result;
//向1602写入指令的函数
void LCD_Write_Command(unsigned char cmd)
while(LCD_Busy_Check()); //检查是否处于忙状态
RS=0;
RW=0;
EN=0;
_nop_();
_nop_();
P0=cmd; //写入指令
Delaynop();
EN=1;
Delaynop();
EN=0;
//向1602写数据
void LCD_Wdat(unsigned char dat)
RS=1;
RW=0;
EN=0;
P0=dat; //写入数据
Delaynop();
EN=1;
Delaynop();
EN=0;
//初始化1602
void Init_LCD()
LCD_Write_Command(0x38);Delayms(5);
LCD_Write_Command(0x01);Delayms(5);
LCD_Write_Command(0x06);Delayms(5);
LCD_Write_Command(0x0c);Delayms(5);
//设置显示位置
void LCD_Pos(unsigned char pos)
LCD_Write_Command(pos|0x80);
//T0的中断服务子函数
void T0Deal()interrupt 1
TH0=-600/256;
TL0=-600%256;
if(++tCount==200)
tCount=0;
TR0=0;
//按键扫描函数,返回值为对应的按键编码
unsigned char GetKey()
unsigned char i,j,k=0;
unsigned char KeyScanCode[]={0xef,0xdf,0xbf,0x7f}; //行列扫描的行列码
unsigned char KeyCodeTable[]={
0xee,0xed,0xeb,0xde,0xdd,0xdb,0xbe,0xbd,0xbb,0x7e,0x7d,0x7b};
P3=0x0f;
if(P3!=0x0f) //如果有按键被按下
for(i=0;i<4;i++) //依次进行扫描
P3=KeyScanCode[i];
for(j=0;j<3;j++)
k=i*3+j; //计算对应的按键编码
if(P3==KeyCodeTable[k])
return k; //返回按键编码
else
return 0xff; //或者返回0xff
//主函数
void main()
unsigned char i=0,j;
P0 = 0xFF;
P2 = 0xFF;
P1 = 0xFF; //初始化端口
// IE=0x82; //设置中断
// TMOD=0x01; //启动T0定时器
Init_LCD(); //初始化1602
Display_String(Title_Text,0x00); //显示 --Phone Code--
while(1)
KeyNo = GetKey(); //获得按键状态
if(KeyNo==0xff)
continue; //如果没有按键,则进入下一个循环
if(++i==12) //如果已经超过11个数字,清除显示屏幕
for(j=0;j<16;j++)
Dial_Code_Str[j]=' ';
i=0;
Dial_Code_Str[i]=Key_Table[KeyNo]; //显示拨号数据
Display_String(Dial_Code_Str,0x40);
// TR0=1;
while(GetKey()!=0xff);
cortex M3S811学习笔记-GPIO-INT
