#include "string.h"
#include "stdio.h"
#include
sfr16 DPTR = 0x82;
typedef unsigned char INT8U;
typedef unsigned int INT16U;
typedef unsigned char uint8_t;
typedef unsigned int uint16_t;
typedef unsigned int uchar;
typedef unsigned char byte;
typedef unsigned int word;
#define YES 1
#define NO 0
//定义使用哪个定时器, 只可定义一个
#define TIMER_0
//#define TIMER_1
//定义串口收、发送管脚。
sbit rs_TXD = P2^1;
sbit rs_RXD = P2^0;
//根据定时器确定参数
#ifdef TIMER_0
#define TMOD_AND_WORD 0xF0;
#define TMOD_TIME_MODE 0x01;
#define TMOD_COUNT_MODE 0x05; //设置计数模式位
sbit TCON_ENABLE_TIMER = TCON^4;
sbit TCON_TFx = TCON^5; //中断标志位
sbit IE_ETx = IE^1; //中断允许位为 ET0
sbit IP_PTx = IP^1; //中断优先级
sfr rs_timerL = 0x8A; //TL0
sfr rs_timerH = 0x8C; //TH0
#endif
#ifdef TIMER_1
#define TMOD_AND_WORD 0x0F;
#define TMOD_TIME_MODE 0x10;
#define TMOD_COUNT_MODE 0x50; //设置计数模式位
sbit TCON_ENABLE_TIMER = TCON^6; //
sbit TCON_TFx = TCON^7; //中断标志位
sbit IE_ETx = IE^3; //中断允许位为 ET1
sbit IP_PTx = IP^4; //中断优先级
sfr rs_timerL = 0x8B; //TL1
sfr rs_timerH = 0x8D; //TH1
#endif
INT8U bdata rs_BUF; //串行收、发时用的移位暂存器。
sbit rs_BUF_bit7 = rs_BUF^7; //移位暂存器的最高位。
INT8U rs_shift_count; //移位计数器。
INT8U bdata rsFlags;
sbit rs_f_TI = rsFlags^0; //0:正在发送; 1: 一个字符完毕
sbit rs_f_RI_enable = rsFlags^1; //0:禁止接收; 1:允许接收
sbit rs_f_TI_enable = rsFlags^2; //0:禁止发送; 1:允许发送
//选择以下一个晶体频率
//#define Fosc 6000000 //6MHz
#define Fosc 11059200 //11.059MHz
//#define Fosc 12000000
//#define Fosc 18432000
//#define Fosc 20000000
//#define Fosc 24000000
//#define Fosc 30000000
//#define Fosc 40000000
//选择以下一个波特率:
//#efine Baud 300 //11.059MHz时,baud 最低为 300
//#define Baud 1200
//#define Baud 2400
//#define Baud 4800
#define Baud 9600
//#define Baud 14400
//#define Baud 19200
//#define Baud 28800
//#define Baud 38400
//#define Baud 57600
//收、发一位所需定时器计数
#define rs_FULL_BIT0 ((Fosc/12) / Baud)
#define rs_FULL_BIT (65536 - rs_FULL_BIT0)
#define rs_FULL_BIT_H rs_FULL_BIT >> 8 //收、发一位所需定时器计数高位
#define rs_FULL_BIT_L (rs_FULL_BIT & 0x00FF) //收、发一位所需定时器计数低位
//检测起始位的时间间隔所需定时器计数
#define rs_TEST0 rs_FULL_BIT0 / 4 //波特率较低时可以除以 3 或除以 2
#define rs_TEST ((~rs_TEST0))
#define rs_TEST_H rs_TEST >> 8 //高位
#define rs_TEST_L rs_TEST & 0x00FF //低位
//发送起始位所需定时器总计数
#define rs_START_BIT 0xFFFF - (Fosc/12/Baud) + 0x28
#define rs_START_BIT_H rs_START_BIT >> 8 //发送起始位所需定时器计数高位
#define rs_START_BIT_L rs_START_BIT & 0x00FF //发送起始位所需定时器计数低位
#define rs_RECEIVE_MAX 32 //最大接收长度
INT8U idata rs232buffer[rs_RECEIVE_MAX]; //收、发缓冲区
INT16U ReceivePoint; //接收数据存储指针
void soft_rs232_interrupt( void );
#ifdef TIMER_0
void timer0 (void) interrupt 1 using 3
if (rs_RXD == 0 | rs_shift_count > 0)
{ soft_rs232_interrupt(); }
else
rs_timerH = rs_TEST_H;
rs_timerL = rs_TEST_L;
#endif
#ifdef TIMER_1
void timer1 (void) interrupt 3 using 3
else
#endif
void soft_rs232_init (void) //串口初始化
TCON_ENABLE_TIMER = 0; //停止定时器
TMOD &= TMOD_AND_WORD;
TMOD |= TMOD_TIME_MODE;
rs_RXD = 1; //接收脚置成高电平
rs_TXD = 1; //发射脚置成高电平
IP_PTx = 1; //置中断优先级为高
IE_ETx = 1; //允许定时器中断
void soft_receive_init() //监测起始位
rs_shift_count = 0;
TCON_ENABLE_TIMER = 1; //启动定时器
void soft_receive_enable() //允许接收
rs_f_RI_enable = 1; //允许接收
rs_f_TI_enable = 0; //禁止发送
soft_receive_init(); //监测起始位, RXD 下降沿触发接收字节过程.
void soft_send_enable (void) //允许发送
rs_f_TI_enable = 1; //允许发送
rs_f_RI_enable = 0; //禁止接收
rs_shift_count = 0; //清移位计数器
rs_f_TI = 1; //发送一个字符完毕标志
[page]
if (rs_f_RI_enable == 1)
if (rs_shift_count == 0) //移位计数器==0, 表示检测到起始位的起点
if ( rs_RXD == 1 )
soft_receive_enable (); //起始位错, 从新开始
else
//下次中断在数据位或停止位中的某时刻发生
rs_timerL += rs_FULL_BIT_L + 0x10;
rs_timerH = rs_FULL_BIT_H;
rs_shift_count++;
rs_BUF = 0; //清移位缓冲变量
else
rs_timerL += rs_FULL_BIT_L; //下次中断在数据位或停止位中发生
rs_shift_count++; //2--9:数据位 10:停止位
if ( rs_shift_count == 9)
rs_BUF = rs_BUF >> 1; //接收第8位
rs_BUF_bit7 = rs_RXD;
// if( ReceivePoint rs_RECEIVE_MAX)
// { //保存收到的字节
rs232buffer[ReceivePoint++] = rs_BUF;
// else
// rs_f_RI_enable = 0; //缓冲区满, 禁止接收
else
if (rs_shift_count 9 ) //收到的是数据位 1 -- 7
else
{ //收到停止位,继续检测 PC 机发出的下一个起始位
TCON_TFx = 0; //清定时器中断标志
else
if (rs_f_TI_enable == 1)
rs_timerL += rs_FULL_BIT_L;//下次中断在数据位的末尾时刻
rs_shift_count--; //0:停止位末尾时刻到
//1:发送停止位
//2--9:发送数据位
if (rs_shift_count > 9) //错误状态
rs_shift_count = 9;
rs_BUF = 0xFF;
if (rs_shift_count > 1) //2--9:发送数据位
ACC = rs_BUF;
ACC = ACC >> 1;
rs_TXD = CY;
rs_BUF = ACC;
else
if (rs_shift_count == 0) //0:停止位末尾时刻到
rs_TXD = 1;
rs_f_TI = 1; //已发送完毕一个字节
else
rs_TXD = 1; //1:发送停止位
//由收转到发时,要先调用 soft_send_enable ()
void rs_send_byte(INT8U SendByte) //发送一个字节
while ( rs_f_TI == 0); //等待发送完毕前一个字节
rs_TXD = 1;
rs_timerL = rs_START_BIT_L; //下次中断在起始位的末尾时刻
rs_timerH = rs_START_BIT_H;
rs_BUF = SendByte;
rs_shift_count = 10;
rs_TXD = 0; //发送起始位
rs_f_TI = 0; //清已发送完毕一个字节的标志
void initiate_MCU (void) //系统初始化
soft_rs232_init(); //串口初始化
EA = 1; //开中断
void delay (INT16U useconds)
for(;useconds>0;useconds--);
void send(uint8_t *temp,char j)
char i=0;
for (i=0;i=j-1;i++) //按发送数据的长度来发送数据
ACC=*(temp+i);
SBUF=ACC; //发送数据
while(TI==0); //发送数据完毕时,TI会自动置高
TI=0; //发送数据完毕,将TI清零,准备下一次发送
GsmSend(char * CmdTmp)
char i;
for(i=0;i
send(&CmdTmp[i],1);
void initial()
PCON= PCON & 0X7F;
TR1=0;
TMOD=TMOD | 0x20; //定时器1为自动装入方式 模式2、自动再装入8位计数器
ET1 = 0;
SCON=0x40; //串行口工作方式1:10位URAT,数据传输率可变
TH1=0xFD;
TL1=0xFD;
//设置数据格式
//低位在前
SM0=0;
SM1=1;
RI=0;
TI=0;
REN=1;
ES=1;
TR1=1;
void main (void)
//首先发送 128 个字节 00H--7FH, 然后等待 PC 机发送的数据。当收到 128
//个字节后,立刻将收到的 128 个数据回发送给 PC 机,然后继续等待下一个
//数据块。
word i;
initial();
// initiate_MCU(); //系统初始化:定时器模式1、
while(1)
rs232buffer[0]=';
strcat(rs232buffer,"ERROR!");
rs232buffer[sizeof(rs232buffer)]=';
EA=0;
GsmSend(rs232buffer);
EA=1;
delay(60000);
