难点1:时序,难点2:LCD1602的11条指令;
时序对了,LCD1602基本上就能显示了:(LCD1602的老是忙等待,所以把忙等待改成10MS延时程序了);
下面是程序:
//------------------------------------------- #include#include #define dataport P0 #define uchar unsigned char #define uint unsigned int // sbit RS =P2^4; // sbit RW =P2^3; // sbit En =P2^2; sbit RS=P2^0; sbit RW=P2^1; sbit En=P2^2; void delay_ms(uchar time) { uchar i,j; for(i=time;i>0;i--) { for(j=85;j>0;j--) {;} } } /*/----------------------------------------- 忙等 void read_bf(void) { En=0; RS=0; RW=1; dataport=0xff; _nop_(); _nop_(); _nop_(); En=1; while(dataport&0x80) ; En=0; } */ bit lcd_bf() { bit result; RS=0; RW=1; En=1; _nop_(); _nop_(); _nop_(); result=(bit)(P0&0x80); En=0; return result; } //-----------------------------------------写命令 void write_command(uchar command) { // read_bf(); // while(lcd_bz()); delay_ms(10); RW=0; RS=0; En=0; _nop_(); _nop_(); dataport=command; _nop_(); _nop_(); _nop_(); En=1; _nop_(); _nop_(); En=0; } //------------------------------------------写数据 void write_data(uchar data_) { // read_bf(); // while(lcd_bz()); delay_ms(10); RW=0; RS=1; En=0; _nop_(); _nop_(); dataport=data_; _nop_(); _nop_(); _nop_(); En=1; _nop_(); _nop_(); En=0; } //-------------------------------------------初始化 void init_lcd(void) { delay_ms(15); write_command(0x38); delay_ms(5); write_command(0x38); delay_ms(5); write_command(0x38); while(lcd_bf()); write_command(0x38); //8位数据双行57 // while(lcd_bf()); // write_command(0x08); //关显示 while(lcd_bf()); write_command(0x01); //清显示 while(lcd_bf()); write_command(0x06); while(lcd_bf()); write_command(0x0c); } void lcd_disp(uchar addr,uchar a_data) { write_command(addr); write_data(a_data); } //-------------------------------------------主函数 void main() { // uchar ch[8]= {0x53,0x54,0x43,0x38,0x39,0x43,0x35,0x32}; uchar ch[6]={"hello!"} ; uchar ch_1[16]={" 1234567890abcde"} ; uchar i,j,k; init_lcd(); for(i=0;i<16;i++) lcd_disp(0x80+i,ch[i]) ; for(k=0;k<16;k++) lcd_disp(0xc0+k,ch_1[k]); for (i=0;i<16;i++) write_command(0x07) ; while(1) { for(j=0;j<10;j++) { write_command(0x1c); //右移 delay_ms(500); } delay_ms(500); for(k=0;k<10;k++) { write_command(0x18); //左移 delay_ms(500); } delay_ms(500); } } //-------------------------------------------
