___________________________________________ 功能:99秒计时 时间2010—7—18 ___________________________________________ #includecode unsigned char tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; unsigned char Dis_Shiwei; unsigned char Dis_Gewei; void delay(unsigned int cnt) { while(--cnt); } main() { TMOD |=0x01; //10ms in 12M crystal,工作在模式一,16位定时器 TH0=0xd8; TL0=0xf0; IE= 0x82; //打开中断 TR0=1; //打开定时开关 while(1) { P0=Dis_Shiwei; P2=0; delay(300); P0=Dis_Gewei; P2=1; delay(300); } } void tim(void) interrupt 1 using 1 { static unsigned char second,count; TH0=0xd8; TL0=0xf0; count++; if (count==100) //100x10ms { count=0; second++; if(second==100) second=0; Dis_Shiwei=tab[second/10]; Dis_Gewei=tab[second%10]; } } /* 定时器设定为:TH0=0xd8;TL0=0xf0;经确定时10ms。从程序开始执行,每当主程序中的16位数发生溢出则触发中断,主程序保护现场并调用中断子程序,也可以写为:TH0=(65536-10000)/256;TL0=(65536-10000)%256。秒脉冲的产生要求精确定时1s,实际情况可能有延误。 1 0000 0000 0000 0000 1101 1000 1111 0000 ———————————— 0010 0111 0001 0000 Time=16(1+16+32+64+512)=16*625=10000us=10ms 主函数中的关于定时器和中断的控制位: TMOD |=0x01; //模式选择 TH0=0xd8; //高8位 TL0=0xf0; //低8位 IE= 0x82; //打开中断 TR0=1; //打开定时开关(定时器运行控制位,置“1”启动定时器0) TMOD |= 0x01; //使用模式1,16位定时器 TH0=0x00; TL0=0x00; EA=1; //总中断打开 ET0=1; //定时器中断打开 TR0=1; //定时器开关打开 */ ______________________________________________ 功能:99秒倒计时 时间:2010—7—18 ______________________________________________ #include code unsigned char tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; unsigned char Dis_Shiwei; unsigned char Dis_Gewei; void delay(unsigned int cnt) { while(--cnt); } main() { TMOD |=0x01; //10ms in 12M crystal TH0=0xd8; TL0=0xf0; IE= 0x82; TR0=1; while(1) { P0=Dis_Shiwei; P2=0; delay(300); P0=Dis_Gewei; P2=1; delay(300); } } void tim(void) interrupt 1 using 1 { static unsigned char second=99,count; TH0=0xd8; TL0=0xf0; count++; if (count==100) { count=0; second--; if(second==0) { second=99; } Dis_Shiwei=tab[second/10]; Dis_Gewei=tab[second%10]; } }
