相关寄存器设置参照M16单片机
初始化写:
SPI_Masterinit();
init_DA();
/****************************SPI片选硬件宏定义*************************************/
//各芯片的片选脚自行修改
#define Select_Volat PORTD&=~(0x01<<6) //置低PD6,选择电压采样ADS7816
#define un_Select_Volat PORTD|=(0X01<<6) //拉高PD6,放弃电压采样ADS7816
#define Select_Amp PORTD&=~(0x01<<5) //置低PD5,选择电流采样ADS7816
#define un_Select_Amp PORTD|=(0X01<<5) //拉高PD5,放弃电流采样ADS7816
#define Select_DA PORTD&=~(0x01<<7) //置低PD7,选择MAX5712
#define un_Select_DA PORTD|=(0X01<<7) //拉高PD7,放弃MAX5712
/******************************初始化SPI*******************************************/
void SPI_Masterinit(void)
PORTB|=(0x01<<6); //set bit MISO
PORTB&=~(0x01<<5);
PORTB&=~(0x01<<7); // clear bits MOSI, & SCK
DDRB|=0xb0; // Set SCK, MOSI & SS as outputs
//SPCR=BIT(MSTR)|BIT(CPHA)|BIT(SPR1);
SPCR=BIT(SPE)|BIT(MSTR)|BIT(CPOL);
SPSR=0x01;
/***************************SPI数据传递函数****************************************/
void SPI_WriteByte(unsigned char data)
SPDR = data; // 启动数据传输
while(!(SPSR & (1<
unsigned char SPI_ReadByte(void)
SPDR = 0xff;
while(!(SPSR & (1<
return SPDR; //返回数据
unsigned int volat(void)
unsigned int c=0;
unsigned int out= 0;
un_Select_Volat;
Select_Volat; //开始采样
SPDR = 0x00;
while(!(SPSR & (1<
c = SPDR&(0b01111111)&(0b10111111);//前三位无效,从第四位开始B11,B10...
out = c;//第一次取得5个有效位
out = out<<7;
SPDR = 0x00;
while(!(SPSR & (1<
c = SPDR;//第二次取得7个有效位
out += (c>>1);
//结束采样
un_Select_Volat;
return out;
