先引用网上有朋友问到的一个问题。
其实这个朋友的程序操作步骤是对。只是出现了一个小问题,在读EEPROM的时候,不能将数据暂存在ACC中,因为在 执行 ACC = XBYTE[EEPROM_VC_ADD+1]后,
EECON=0x00编译出来是:
CLR A
MOV EECON,A
也就是ACC已经被清零了,所以返回的值永远是零。
下面我的一个测试程序。
#include "REG51xD2.h"
# include "ABSACC.H"
unsigned int xdata test1 _at_ 0x500;
unsigned long xdata test2 _at_ 0x6f0;
unsigned int test3;
unsigned long test4;
unsigned char temp;
unsigned char w_dat[10]={1,2,3,4,5,6,7,8,9,0};
unsigned char r_dat[10];
unsigned char R_EEPROM_BYTE(unsigned int addr)
bit ea_temp;
unsigned char dat;
while((EECON&0x01)!=0);//EEBUSY = 0? 等待
ea_temp = EA;
EA=0;
EECON = 0x02; //EEE=1; 使能EEPROM
dat = XBYTE[addr]; // Read DATA; //******不能暂存在ACC中。
EECON= 0x00; // 编译出来是 CLR A;MOV EECON,A
EA=ea_temp;
return dat; //返回读出值
void R_EEPROM_nBYTE(unsigned int saddr,unsigned char num)
unsigned char i;
for(i=0;i
r_dat[i]=R_EEPROM_BYTE(saddr++);
void W_EEPROM_BYTE(unsigned int addr ,unsigned char dat)
bit ea_temp;
ea_temp=EA;
EA = 0;
EECON = 0x02; // EEE=1;
XBYTE[addr]=dat;
EECON = 0x00;
EA = ea_temp;
void W_EEPROM_nBYTE (unsigned char num,unsigned int saddr,unsigned char *s )
unsigned char i;
for(i=0;i
void main()
while(1)
AUXR = 0x10;
test1 = 0x1234;
test2 = 0x98765432;
test3=test1;
test4 =test2;
test1++;
test2++;
W_EEPROM_nBYTE(10,0x0000,w_dat);
R_EEPROM_nBYTE(0x0000,10);
