// PIN assignment
#define SS PB2 //Chip select
#define SCK PB5 //cLOCk
#define MOSI PB3 //input
#define MISO PB4 //output
#define SS_SET (PORTB|=(1<
#define SS_CLR (PORTB &= ~(1<
void spi_init(void)
DDRB |= (1<
SPCR = 0x53;
SPSR = 0x00;
void SendByte(u8 sData)
SPDR = sData;
while(!(SPSR & (1<
u8 spi_read(void)
SPDR = 0x00;
while(!(SPSR & (1<
//start and stop condition of 93C46
void Start(void)
u8 temp;
temp = SPCR;
SPCR = 0; // 禁止SPI功能
SCK_CLR; // 手工产生一个起始位,93C46特殊的地方
MOSI_SET; // 所以要特殊处理
SS_SET;
SCK_SET;
SPCR = temp; // 使能SPI功能
void Stop(void)
SS_CLR;
// write enable / diable
void EWEN(void)
Start();
SendByte(0x30); // EWEN command
Stop();
void EWDS(void)
Start();
SendByte(0x00); // EWDS command
Stop();
// read word
u16 ReadWord(u8 addr)
u16 temp=0;
u8 hig,low;
Start();
SendByte(addr | 0x80); // read command
//------------------------ 切换到SPI模式1
SPCR = 0x5b;
hig = spi_read();
low = spi_read();
//------------------------ 切换回SPI模式0
SPCR = 0x53;
Stop();
temp = (hig<<8) + low ;
return temp;
// write a word
void WriteWord(u16 data,u8 addr)
EWEN();
Start();
SendByte(addr | 0x40); // write command
SendByte((u8)(data>>8)); // send hig byte
SendByte((u8)data); // send low byte
Stop(); // wait at lease 2ms
void WriteAll(u16 data)
EWEN(); // write enable
Start();
SendByte(0x10); // write command
Stop(); // wait at lease 10MS
