/*GCC编译器*/
#include
#include
#include
#define SET_1(a,b) a|=(1< #define CLE_0(a,b) a&=~(1<
#define uchar unsigned char
#define uint unsigned int
/*中断初始化,INT0、INT1、定义为下降沿触发*/
void int_init( void )
cli();
EICRA|=(1<
/*端口初始化*/
void port_init()
DDRA=0XFF;
PORTA=0XFF;
DDRD=0X00;
PORTD=0X00;
/*INT0中断服务函数*/
SIGNAL(INT0_vect)
CLE_0(EIMSK,INT0);
PORTA=0X0F;
_delay_ms(200);
PORTA=0XFF;
SET_1(EIMSK,INT0);
/*INT1中断服务函数*/
SIGNAL(INT1_vect)
CLE_0(EIMSK,INT1);
PORTA=0XF0;
_delay_ms(200);
PORTA=0XFF;
SET_1(EIMSK,INT1);
/*主函数,无中断时发光二极管轮流点亮熄灭200毫秒*/
int main( void )
uchar i;
port_init();
int_init();
while(1)
for(i=0;i<8;i++)
PORTA=CLE_0(PORTA,i);
_delay_ms(200);
PORTA=SET_1(PORTA,i);
_delay_ms(200);
return 0;
