配置内核支持UVC驱动,然后make uImage编译内核,烧写内核到nand flash,再启动开发板,把USB摄像头插到JZ2440开发板上以后,弹出以下错误,使用ls /dev/video*命令查看不到设备节点,参照以下方法解决问题:
usb 1-1: new full speed USB device usings3c2410-ohci and address 2
usb 1-1: device descriptor read/64, error -62
usb 1-1: new full speed USB device using s3c2410-ohci andaddress 3
usb 1-1: new full speed USB device using s3c2410-ohci andaddress 4
usb 1-1: device not accepting address 4, error -62
usb 1-1: new full speed USB device using s3c2410-ohci andaddress 5
usb 1-1: device not accepting address 5, error -62
hub 1-0:1.0: unable to enumerate USB device on port 1
找到的解决办法:
修改drivers/usb/host/ohci-s3c2410.c
添加头文件:
#include
在函数s3c2410_start_hc最后添加:
unsigned long upllvalue = (0x78<< 12) | (0x02<< 4) | (0x03);
while (upllvalue != __raw_readl(S3C2410_UPLLCON)) {
__raw_writel(upllvalue, S3C2410_UPLLCON);
mdelay(1);
在这里,S3C2410_UPLLCON的值为0xF4100008(采用系统默认值尝试成功)。
