430的定时器的有点类似于51单片机,利用定时器实现P1.0口LED灯1s闪烁代码如下
#include "wdt_a.h"
#include "gpio.h"
#include "timer_a.h"
#define COMPARE_VALUE 32768
int main( void )
volatile unsigned int i;
WDT_A_hold(WDT_A_BASE);
GPIO_setAsOutputPin(GPIO_PORT_P1,GPIO_PIN0);
GPIO_setOutputHighOnPin(GPIO_PORT_P1,GPIO_PIN0);
//Start timer in continuous mode sourced by ACLK
Timer_A_initContinuousModeParam initContParam = {0};
initContParam.clockSource = TIMER_A_CLOCKSOURCE_ACLK;
initContParam.clockSourceDivider = TIMER_A_CLOCKSOURCE_DIVIDER_1;
initContParam.timerInterruptEnable_TAIE = TIMER_A_TAIE_INTERRUPT_DISABLE;
initContParam.timerClear = TIMER_A_DO_CLEAR;
initContParam.startTimer = false;
Timer_A_initContinuousMode(TIMER_A1_BASE, &initContParam);
//Initiaze compare mode
Timer_A_clearCaptureCompareInterrupt(TIMER_A1_BASE,TIMER_A_CAPTURECOMPARE_REGISTER_0);
Timer_A_initCompareModeParam initCompParam = {0};
initCompParam.compareRegister = TIMER_A_CAPTURECOMPARE_REGISTER_0;
initCompParam.compareInterruptEnable = TIMER_A_CAPTURECOMPARE_INTERRUPT_ENABLE;
initCompParam.compareOutputMode = TIMER_A_OUTPUTMODE_OUTBITVALUE;
initCompParam.compareValue = COMPARE_VALUE;
Timer_A_initCompareMode(TIMER_A1_BASE, &initCompParam);
Timer_A_startCounter(TIMER_A1_BASE,TIMER_A_CONTINUOUS_MODE);
//Enter LPM0, enable interrupts
__bis_SR_register(LPM0_bits + GIE);
//For debugger
__no_operation();
while(1) // continuous loop
//This is the TIMER1_A3 interrupt vector service routine.
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=TIMER1_A0_VECTOR
__interrupt
#elif defined(__GNUC__)
__attribute__((interrupt(TIMER1_A0_VECTOR)))
#endif
void TIMER1_A0_ISR (void)
uint16_t compVal = Timer_A_getCaptureCompareCount(TIMER_A1_BASE,TIMER_A_CAPTURECOMPARE_REGISTER_0)+COMPARE_VALUE;
//Toggle P1.0
GPIO_toggleOutputOnPin(GPIO_PORT_P1,GPIO_PIN0);
//Add Offset to CCR0
Timer_A_setCompareValue(TIMER_A1_BASE,TIMER_A_CAPTURECOMPARE_REGISTER_0,compVal);
