#ifndef __PIC18F4580_h
#define __PIC18F4580_h
#include
#include
#include
#include
#include
#define InterruptEnable INTCONbits.PEIE = 1,INTCONbits.GIE = 1
#define InterruptDisable INTCONbits.PEIE = 0,INTCONbits.GIE = 0
extern void IntTimer0(void);
#endif
#include"PIC18F4580.h"
#pragma interrupt SelectHPrioInt
#pragma code HiPrio_Int = 0x08
void HighPrioInt(void)
_asm
goto SelectHPrioInt
_endasm
#pragma code
void SelectHPrioInt (void)
if(INTCONbits.TMR0IF)
IntTimer0();
#pragma config OSC =IRCIO67, WDTPS = 1024, WDT = ON,PBADEN = OFF,DEBUG = OFF,MCLRE = OFF,LVP = OFF
#define u16 unsigned int
#define u8 unsigned char
#define LED LATCbits.LATC2
void WdtReset(void)
_asm
CLRWDT
_endasm
void delay_n_ms(u16 n)//8MHz时钟下的ms延时
T1CON = 0xB0; //16位定时器,系统8分频
while(n!=0)
TMR1L = 0x31;
TMR1H = 0xF8;
PIR1bits.TMR1IF = 0; //标志位清空
T1CONbits.TMR1ON = 1; //使能定时器
n--;
while(!PIR1bits.TMR1IF){;}
T1CONbits.TMR1ON =0; //关闭定时器
void InitTimer0(void)
T0CON = 0x05; //系统64分频
TMR0L = 0XEF; //1秒中断
TMR0H = 0x85;
INTCONbits.TMR0IE = 1; //打开定时器0中断
INTCON2bits.TMR0IP = 1; //设置优先级为最高
T0CONbits.TMR0ON =1; //打开定时器0
INTCONbits.TMR0IF = 0; //标志位清空
T0CONbits.TMR0ON = 1;
TMR0L = 0XEF;
TMR0H = 0x85;
LED=~LED;
WdtReset();
void main(void)
OSCCON = 0x72;//OSCCON = 0x72;设置OSC时钟输出=8M
//OSCCON = 0x62;设置OSC时钟输出=4M
//OSCCON = 0x52;设置OSC时钟输出=2M
//OSCCON = 0x42;设置OSC时钟输出=1M
//OSCCON = 0x32;设置OSC时钟输出=500KHz
//OSCCON = 0x22;设置OSC时钟输出=250KHz
//OSCCON = 0x12;设置OSC时钟输出=125KHz
//OSCCON = 0x02;设置OSC时钟输出=31KHz(from either INTOSC/256 or INTRC directly)
InterruptDisable;
InitTimer0();
InterruptEnable;
TRISC=0X00; //TRISC寄存器被赋值,PORTC每一位都为输出
LED=0;
for(;;)
//LED=0;
//delay_n_ms(500);
//LED=1;
//delay_n_ms(500);
