#if !defined (HSE_VALUE)
#define HSE_VALUE ((uint32_t)24000000U) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
HSE_VALUE 值的大小决定了,时钟滴答的周期。 这个值的设置不会影响主频的时钟周期以及相关timer的变化。
__weak uint32_t HAL_RCC_GetSysClockFreq(void)
uint32_t pllm = 0U, pllvco = 0U, pllp = 0U;
uint32_t sysclockfreq = 0U;
/* Get SYSCLK source -------------------------------------------------------*/
switch (RCC->CFGR & RCC_CFGR_SWS)
case RCC_CFGR_SWS_HSI: /* HSI used as system clock source */
sysclockfreq = HSI_VALUE;
break;
case RCC_CFGR_SWS_HSE: /* HSE used as system clock source */
sysclockfreq = HSE_VALUE;
break;
case RCC_CFGR_SWS_PLL: /* PLL used as system clock source */
/* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLLM) * PLLN
SYSCLK = PLL_VCO / PLLP */
pllm = RCC->PLLCFGR & RCC_PLLCFGR_PLLM;
if(__HAL_RCC_GET_PLL_OSCSOURCE() != RCC_PLLSOURCE_HSI)
/* HSE used as PLL clock source */
pllvco = ((HSE_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> POSITION_VAL(RCC_PLLCFGR_PLLN)));
else
/* HSI used as PLL clock source */
pllvco = ((HSI_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> POSITION_VAL(RCC_PLLCFGR_PLLN)));
pllp = ((((RCC->PLLCFGR & RCC_PLLCFGR_PLLP) >> POSITION_VAL(RCC_PLLCFGR_PLLP)) + 1U) *2U);
sysclockfreq = pllvco/pllp;
break;
default:
break;
return sysclockfreq;
