tiny_nand.c驱动源码:
#include "linux/module.h"
#include "linux/types.h"
#include "linux/init.h"
#include "linux/kernel.h"
#include "linux/string.h"
#include "linux/ioport.h"
#include "linux/platform_device.h"
#include "linux/delay.h"
#include "linux/err.h"
#include "linux/slab.h"
#include "linux/clk.h"
#include "linux/cpufreq.h"
#include "linux/mtd/mtd.h"
#include "linux/mtd/nand.h"
#include "linux/mtd/nand_ecc.h"
#include "linux/mtd/partitions.h"
#include "asm/io.h"
#include "plat/regs-nand.h"
#include "plat/nand.h"
static unsigned long *clk_gate_ip1;
static unsigned long *clk_gate_block;
static unsigned long *mp0_3con;
static struct mtd_partition tiny_nand_part[] = {
[0] = {
.name = "bootloader",
.size = SZ_4M,
.offset = 0,
[1] = {
.name = "kernel",
.size = SZ_8M,
.offset = MTDPART_OFS_APPEND,
[2] = {
.name = "root",
.size = MTDPART_SIZ_FULL,
struct nand_regs {
unsigned long nfconf;
unsigned long nfcont;
unsigned long nfcmmd;
unsigned long nfaddr;
unsigned long nfdata;
unsigned long nfmeccd0;
unsigned long nfmeccd1;
unsigned long nfseccd;
unsigned long nfsblk;
unsigned long nfeblk;
unsigned long nfstat;
unsigned long nfeccerr0;
unsigned long nfeccerr1;
static struct nand_regs *nand_regs;
static struct nand_chip *tiny_nand_chip;
static struct mtd_info *tiny_nand_mtd;
static void tiny_nand_select_chip(struct mtd_info *mtd, int chipnr)
if(chipnr == -1)
//取消选择
nand_regs->nfcont |= (1<<1);
else
//选中芯片
nand_regs->nfcont &= ~(1<<1);
static void tiny_nand_cmd_ctrl(struct mtd_info *mtd, int dat,unsigned int ctrl)
if (ctrl & NAND_CLE)
//发命令
nand_regs->nfcmmd = dat;
else
//发地址
nand_regs->nfaddr = dat;
static int tiny_nand_dev_ready(struct mtd_info *mtd)
//等待命令的操作完成
return (nand_regs->nfstat & (1<<0));
static int tiny_nand_init(void)
//1.分配一个nand_chip结构体
tiny_nand_chip = kzalloc(sizeof(struct nand_chip),GFP_KERNEL);
nand_regs = ioremap(0xB0E00000,sizeof(struct nand_regs));
mp0_3con = ioremap(0xE0200320,4);
clk_gate_ip1 = ioremap(0xE0100464,4);
clk_gate_block = ioremap(0xE0100480,4);
//2.设置
// 初始化nand_chip结构体中的函数指针
// 提供选中芯片,发命令,发地址,读数据,写数据,等待等操作
tiny_nand_chip->select_chip = tiny_nand_select_chip;
tiny_nand_chip->cmd_ctrl = tiny_nand_cmd_ctrl;
tiny_nand_chip->IO_ADDR_R = &nand_regs->nfdata;
tiny_nand_chip->IO_ADDR_W = &nand_regs->nfdata;
tiny_nand_chip->dev_ready = tiny_nand_dev_ready;
tiny_nand_chip->ecc.mode = NAND_ECC_SOFT;
//tiny_nand_chip->ecc.mode = NAND_ECC_NONE;
//3.硬件相关
//使能时钟
*clk_gate_ip1 = 0xffffffff;
*clk_gate_block = 0xffffffff;
// 设置相应GPIO管脚用于Nand
*mp0_3con = 0x22222222;
// 设置时序
#define TWRPH1 1
#define TWRPH0 1
#define TACLS 1
nand_regs->nfconf |= (TACLS<<12) | (TWRPH0<<8) | (TWRPH1<<4);
// AddrCycle[1]:1 = 发送地址需要5个周期
nand_regs->nfconf |= 1<<1;
// MODE[0]:1 = 使能Nand Flash控制器
// Reg_nCE0[1]:1 = 取消片选
nand_regs->nfcont |= (1<<1)|(1<<0);
//4.使用
tiny_nand_mtd = kzalloc(sizeof(struct mtd_info), GFP_KERNEL);
tiny_nand_mtd->owner = THIS_MODULE;
tiny_nand_mtd->priv = tiny_nand_chip;
nand_scan(tiny_nand_mtd, 1);
//5.添加分区
add_mtd_partitions(tiny_nand_mtd, tiny_nand_part, 3);
return 0;
static void tiny_nand_exit(void)
del_mtd_partitions(tiny_nand_mtd);
kfree(tiny_nand_mtd);
iounmap(nand_regs);
kfree(tiny_nand_chip);
module_init(tiny_nand_init);
module_exit(tiny_nand_exit);
MODULE_LICENSE("GPL");
