usbmouse_as_key.c驱动源码:
//参考源码: drivershidusbhidusbmouse.c
#include "linux/kernel.h"
#include "linux/slab.h"
#include "linux/module.h"
#include "linux/init.h"
#include "linux/usb/input.h"
#include "linux/hid.h"
static struct input_dev *uk_dev;
static char *usb_buf;
static dma_addr_t usb_buf_phys;
static int len;
static struct urb *uk_urb;
static struct usb_device_id usbmouse_as_key_id_table [] = {
{ USB_INTERFACE_INFO(USB_INTERFACE_CLASS_HID, USB_INTERFACE_SUBCLASS_BOOT,
USB_INTERFACE_PROTOCOL_MOUSE)
//{USB_DEVICE(0x1234,0x5678)},
{ } // Terminating entry
static void usbmouse_as_key_irq(struct urb *urb)
static unsigned char pre_val;
#if 0
int i;
static int cnt = 0;
printk("data cnt %d: ", ++cnt);
for (i = 0; i < len; i++)
printk("x ", usb_buf[i]);
printk(" ");
#endif
// USB鼠标数据含义
// data[0]: bit0-左键, 1-按下, 0-松开
// bit1-右键, 1-按下, 0-松开
// bit2-中键, 1-按下, 0-松开
if ((pre_val & (1<<0)) != (usb_buf[0] & (1<<0)))
// 左键发生了变化
input_event(uk_dev, EV_KEY, KEY_L, (usb_buf[0] & (1<<0)) ? 1 : 0);
input_sync(uk_dev);
if ((pre_val & (1<<1)) != (usb_buf[0] & (1<<1)))
// 右键发生了变化
input_event(uk_dev, EV_KEY, KEY_S, (usb_buf[0] & (1<<1)) ? 1 : 0);
input_sync(uk_dev);
if ((pre_val & (1<<2)) != (usb_buf[0] & (1<<2)))
// 中键发生了变化
input_event(uk_dev, EV_KEY, KEY_ENTER, (usb_buf[0] & (1<<2)) ? 1 : 0);
input_sync(uk_dev);
pre_val = usb_buf[0];
// 重新提交urb
usb_submit_urb(uk_urb, GFP_KERNEL);
static int usbmouse_as_key_probe(struct usb_interface *intf, const struct usb_device_id *id)
struct usb_device *dev = interface_to_usbdev(intf);
struct usb_host_interface *interface;
struct usb_endpoint_descriptor *endpoint;
int pipe;
interface = intf->cur_altsetting;
endpoint = &interface->endpoint[0].desc;
// a. 分配一个input_dev
uk_dev = input_allocate_device();
// b. 设置
// b.1 能产生哪类事件
set_bit(EV_KEY, uk_dev->evbit);
set_bit(EV_REP, uk_dev->evbit);
// b.2 能产生哪些事件
set_bit(KEY_L, uk_dev->keybit);
set_bit(KEY_S, uk_dev->keybit);
set_bit(KEY_ENTER, uk_dev->keybit);
// c. 注册
input_register_device(uk_dev);
// d. 硬件相关操作
// 数据传输3要素: 源,目的,长度
// 源: USB设备的某个端点
pipe = usb_rcvintpipe(dev, endpoint->bEndpointAddress);
// 长度:
len = endpoint->wMaxPacketSize;
// 目的:
usb_buf = usb_alloc_coherent(dev, len, GFP_ATOMIC, &usb_buf_phys);
// 使用"3要素"
// 分配usb request block
uk_urb = usb_alloc_urb(0, GFP_KERNEL);
// 使用"3要素设置urb"
usb_fill_int_urb(uk_urb, dev, pipe, usb_buf, len, usbmouse_as_key_irq, NULL, endpoint->bInterval);
uk_urb->transfer_dma = usb_buf_phys;
uk_urb->transfer_flags |= URB_NO_TRANSFER_DMA_MAP;
// 使用URB
return 0;
static void usbmouse_as_key_disconnect(struct usb_interface *intf)
//printk("disconnect usbmouse! ");
usb_kill_urb(uk_urb);
usb_free_urb(uk_urb);
usb_free_coherent(dev, len, usb_buf, usb_buf_phys);
input_unregister_device(uk_dev);
input_free_device(uk_dev);
// 1. 分配/设置usb_driver
static struct usb_driver usbmouse_as_key_driver = {
.name = "usbmouse_as_key_",
.probe = usbmouse_as_key_probe,
.disconnect = usbmouse_as_key_disconnect,
.id_table = usbmouse_as_key_id_table,
static int usbmouse_as_key_init(void)
// 2. 注册
usb_register(&usbmouse_as_key_driver);
return 0;
static void usbmouse_as_key_exit(void)
usb_deregister(&usbmouse_as_key_driver);
module_init(usbmouse_as_key_init);
module_exit(usbmouse_as_key_exit);
MODULE_LICENSE("GPL");
