#include "regs.h"
void enable_mmu(unsigned long ttb);
void init_ttb(unsigned long *ttb_base);
void mmap(unsigned long *ttb_base, unsigned long va, unsigned long pa);
void memset(char *buf, char ch, int size);
void memcpy(char *dst, char *src, int size);
void do_irq(unsigned long regs[]);
void (*printf)(char *, ...) = 0x43e11434;
void main(void)
unsigned long vector_base = 0xffff0000;
unsigned long tt_base = 0x73000000;
unsigned long *pdo_irq = 0x75000000;
extern unsigned long vectors_start, vectors_end;
memset(tt_base, 0x00, 16 * 1024);
mmap(tt_base, vector_base, 0x70000000);
enable_mmu(tt_base);
memcpy(vector_base, vectors_start, 0x100);
*pdo_irq = do_irq;
__asm__ __volatile__ (
"cpsie i "
ICCICR_CPU0 = 1;
ICCPMR_CPU0 = 0xff; //Priority Unmask All Interrupt
ICDDCR = 1;
//------ Watchdog IRQ ID is 75------------------
ICDIPR18_CPU0 = ~(0xff << 24);// the Zero is Highest priority
ICDIPTR18_CPU0 = (1 << 24); // for CPU0 , refer PG815
ICDISER2_CPU0 = (1 << 11); // enable interrupt 0 --- SGI0
//---------- Configure WDT ----------------------
// 200000000 / 128 / 256 = 6103,即频率6103
WTCNT = 6103; // 1秒钟减完
WTDAT = 6103; // WTCNT 1秒钟减完后把WTDAT值装入WTCNT中继续减
WTCON = (1 << 2) | (3 << 3) | (1 << 5) | (0xff << 8) ; //启动看门狗
printf("watchdog: wang wang wang .... ");
WTCLRINT = 0;
unsigned long c1_flags;
init_ttb(ttb);
c1_flags = 1 | (1 << 3) | ( 1 << 11) | ( 1 << 13) | (1 << 28);
"mvn r0, #0 "
"mcr p15, 0, r0, c3, c0, 0 "
"mcr p15, 0, %1, c2, c0, 0 " //configure ttb
"mrc p15, 0, r0, c1, c0, 0 "
"orr %0, r0, %0 "
"mcr p15, 0, %0, c1, c0, 0 " //enable mmu
: "r" (c1_flags), "r" (ttb)
: "r0"
unsigned long va, pa;
for (va = 0x00000000; va < 0x10000000; va += 0x100000) { //Others
pa = va;
ttb_base[ va >> 20] = (pa & 0xfff00000) | 2;
for (va = 0x10000000; va < 0x14000000; va += 0x100000) { //SFR
pa = va;
for (va = 0x40000000; va < 0x80000000; va += 0x100000) { //DRAM
pa = va;
int i;
for (i = 0; i < size; i ++)
buf[i] = ch;
int i;
dst[i] = src[i];
__asm__ (
"vectors: "
"b reset "
"b und "
"b swi "
"b pre_abt "
"b dat_abt "
".word 0 "
"b irq "
"b fiq "
"reset: "
"und: "
"mov sp, #0x74000000 "
"stmfd sp!, {r0-r12, lr} "
"mov r0, sp "
"mov r3, #0x74000000 "
"ldr r3, [r3] "
"blx r3 "
"ldmea sp, {r0-r12, pc}^ "
"swi: "
"pre_abt: "
"dat_abt: "
"fiq: "
"irq: "
"mov sp, #0x75000000 "
"sub lr, lr, #4 "
"mov r0, sp "
"mov r3, #0x75000000 "
"ldr r3, [r3] "
"blx r3 "
"EOV: "
"vectors_start: "
".word vectors "
"vectors_end: "
".word EOV "
Makefile文件:
default:
arm-linux-gcc -c test.c -o test.o
arm-linux-ld -Ttext=0x70003000 test.o -o test
arm-linux-objcopy -O binary test test.bin
clean:
rm -f test.o test test.bin *~
