环境:STM32F407, IAR 7.4, STM32CubeF4
GPIO配置代码:
GPIO_InitStruct.Pin = GPIO_PIN_10;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLDOWN;
GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF15_EVENTOUT;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
脉冲输出用intrinsics.h里定义的一个函数:
__SETV();
输出波形:
示波器采样率只有这样,估计是1个时钟,1/168M=6ns。
EVENTOUT 用途据资料说是用于多个ARM之间同步用。与用GPIO输出相比较,GPIO至少要3条指令输出一个脉冲,并且访问总线有延时。而输出EVENTOUT只 用一条SEV指令,脉冲直接由内核控制,延迟最小。不过这个脉冲太窄了点,不能满足我的应用中宽度的要求,只能还是用GPIO了。
接收EVENT没测试过,不过看到代码里管脚MODE可以设成:
#define GPIO_MODE_EVT_RISING ((uint32_t)0x10120000) /*!< External Event Mode with Rising edge trigger detection */
#define GPIO_MODE_EVT_FALLING ((uint32_t)0x10220000) /*!< External Event Mode with Falling edge trigger detection */
#define GPIO_MODE_EVT_RISING_FALLING ((uint32_t)0x10320000) /*!< External Event Mode with Rising/Falling edge trigger detection */
接收方并是不把EVENT当作中断来处理,而是当做唤醒的信号。参考资料PM0214:STM32F3 and STM32F4 Series Cortex-M4 programming manual中2.5.1 Entering sleep mode。
