#include
#define uchar unsigned char
#define uint unsigned int
#define setbit(sfr,bit) (sfr|=(1<
#define SCL_out() setbit(DDRD,2) //设置SCL为输出
#define SDA_in() clrbit(DDRD,0) //设置SDA为输入
#define SDA_high() setbit(PORTD,0) //设置SDA为高电平
#define SDA_low() clrbit(PORTD,0) //设置SDA为低电平
#define SCL_high() setbit(PORTD,2) //设置SCL为高电平
#define SCL_low() clrbit(PORTD,2) //设置SCL为低电平
void delay_us(uchar t)
uchar i;
for(i=0;i
void delay_ms(uchar m)
uchar i;
for(i=0;i
delay_us(250); //延时250us
delay_us(250);
delay_us(250);
delay_us(250);
void init()
SDA_out();
SCL_out();
//SCL_low();
MCUCR = 0x00; //使能上拉
void start_signed()
SDA_out();
SDA_high();
SCL_high();
delay_us(4);
SDA_low();
delay_us(4);
SCL_low();
void stop_signed()
SDA_out();
SDA_low();
SCL_high();
delay_us(4);
SDA_high();
delay_us(4);
SCL_low();
uchar ACK_signed()
uchar q=1,i;
SDA_in();
SCL_high();
for(i=0;i<200;i++)
q = PIND&0x01;
if(!q)break;
else
i = 0;
delay_us(4);
SCL_low();
return q;
uchar mask_ack()
SDA_out();
SCL_low();
delay_us(2);
SDA_low();
delay_us(4);
SCL_high();
delay_us(4);
void write_byte(uchar w_byte)
uchar i;
SDA_out();
SCL_out();
for(i=0;i<8;i++)
if((w_byte&0x80)!=0)SDA_high();
else
SDA_low();
w_byte<<=1;
SCL_high();
delay_us(4);
SCL_low();
delay_us(4);
uchar read_byte()
uchar i,read_byte;
SDA_in();
for(i=0;i<8;i++)
SCL_high();
delay_us(10);
read_byte=read_byte<<1;
if((PIND&0x01)!=0)read_byte|=0x01;
delay_us(10);
SCL_low();
delay_us(10);
return read_byte;
write_24c02(uchar addr,uchar w_data)
start_signed();
write_byte(0xa0);
if(ACK_signed())return;
write_byte(addr);
write_byte(w_data);
stop_signed();
delay_ms(10); //延时10MS等待写操作完成
uchar read_24c02(uchar addr)
uchar temp;
start_signed();
write_byte(0xa0);
write_byte(addr);
start_signed(); //从新开始
write_byte(0xa1);
temp = read_byte();
mask_ack(); //主机发送应答信号
stop_signed();
return temp;
uchar main()
uchar p = 0xff;
init();
DDRB = 0xff;
PORTB = 0xff;
while(1)
write_24c02(0x03,0x43);
delay_ms(10);
p = read_24c02(0x03);
PORTB = p;
