今天上午写了atmega16的I2C硬件接口程序,程序不难,只是给初学的朋友一个思路,不过通过和51的软件模拟I2C程序比较发现,AVR的I2C硬件接口使程序更简单了,
#include
#include
unsigned char const duacode[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71}; //0-f 数字模*/
void delay(unsigned int);
void display(unsigned int);
void send1byte(unsigned char address,unsigned char data);
unsigned char read1byte(unsigned char address);
#define START TWCR=BIT(7)|BIT(5)|BIT(2)
#define STOP TWCR=BIT(7)|BIT(4)|BIT(2)
#define WRITE(x) {TWDR=x; TWCR=BIT(7)|BIT(2);}
void main()
{unsigned char i=0;
DDRC=0xff;
while(1)
send1byte(4,71);
i=read1byte(4);
display(i);
START;
while(!(TWCR&0x80));
WRITE(0xa0);
WRITE(address);
WRITE(data);
STOP;
delay(2);
unsigned char temp;
START;
WRITE(0xa0);
WRITE(address);
START;
WRITE(0xa1);
TWCR=BIT(7)|BIT(2);
temp=TWDR;
STOP;
return temp;
void display(unsigned int dat)
unsigned char a[4],i;
for(i=0;i<4;i++)
a[3-i]=dat%10;
dat/=10;
DDRB=0xff; DDRD=0xff;
for(i=0;i<4;i++)
PORTB=duacode[a[i]];
PORTD&=~BIT(i);
delay(10);
PORTD|=BIT(i);
void delay(unsigned int x)
unsigned int a; unsigned char b;
for(a=x;a>0;a--)
for(b=100;b>0;b--);
