do
i=(i<<1|i>>7);
PORTD=i;
DDRD=0X0F;//
key=PIND;//不论如何配置DDxn,都可以通过读取PINxn 寄存器来获得引脚电平
j=key&0xf0;
}while(j==0xf0);//直到发现按键按下。若没有找到按键按下 的,继续循环
i的初值0x7f。i=(i<<1|i>>7);之后。i=1111 1110b
第二次,i= 1111 1101b
保证只有一位为0
下面是程序,写得很巧妙
#include
#include
#define uchar unsigned char
#define uint unsigned int
#pragma data:code //save to areas of program
const table[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c ,
0x39,0x5e,0x79,0x71,0};
void delay(uint ms)
uint i,j;
for(i=0;i
void show_init()
DDRA|=BIT(3);
DDRB=0XFF;
DDRA|=BIT(4);
void show(uchar aa,uchar bb)//第aa个数码管显示bb
//PORTB=0XFF;
PORTA|=BIT(4);
PORTB=~BIT(aa);
PORTA&=~BIT(4);
PORTA|=BIT(3);
PORTB=table[bb];
PORTA&=~BIT(3);
delay(10);
uchar key_press()
uchar i;
DDRD=0XFF;
PORTD=0XF0;
DDRD=0X0F;
i=PIND;
if(i==0xf0)
DDRD=0XFF;
return 0;
else
DDRD=0XFF;
return 1;
uchar key_scan()
uchar key,i=0x7f,j,code;
delay(10);
if(key_press())
do
i=(i<<1|i>>7);
PORTD=i;
DDRD=0X0F;
key=PIND;
j=key&0xf0;
}while(j==0xf0);
while(key_press());
switch(key)
case 0x7e: code=0;break;
case 0xbe: code=1;break;
case 0xde: code=2;break;
case 0xee: code=3;break;
case 0x7d: code=4;break;
case 0xbd: code=5;break;
case 0xdd: code=6;break;
case 0xed: code=7;break;
case 0x7b: code=8;break;
case 0xbb: code=9;break;
case 0xdb: code=10;break;
case 0xeb: code=11;break;
case 0x77: code=12;break;
case 0xb7: code=13;break;
case 0xd7: code=14;break;
case 0xe7: code=15;break;
return code;
void main()
uchar s;
show_init();
while(1)
if(key_press())
s=key_scan();
show(0,s);
