电路图:
C程序:
#include
#include
sbit K01=P1^4; //增加键
sbit K02=P1^5; //减少键
sbit BEEP=P3^7;//蜂鸣器
unsigned char PWM=0x7f;//赋初值
void Beep();
void delayms(unsigned char ms);
void delay(unsigned t);
void main()
P0=0xff;
P1=0xff;
P2=0xff;
P3=0xff;
TMOD=0x21;
TH0=0xfc;//1ms延时常数12M
TL0=0x18;//频率调节
TH1=PWM;//脉宽调节
TL1=0;
EA=1;
ET0=1;
ET1=1;
TR0=1;
while(1)
do{if(PWM!=0xff){PWM++;delayms(10);}
else Beep();}while(K01==0);//K01按下,亮度变暗
do{if(PWM!=0x01){PWM--;delayms(10);}
else Beep();}while(K02==0);//K02按下,亮度变亮
void timer0() interrupt 1 //定时器0中断服务程序
TR1=0;
TH0=0xfc;
TL0=0x66;
TH1=PWM;
TR1=1;
P0=0x00;
P2=0x00; //启动输出
void timer1() interrupt 3//定时器1中断服务程序
{TR1=0;P0=0xff;P2=0xff;}//结束输出
void Beep()//蜂鸣器子程序
{unsigned char i;
for(i=0;i<100;i++){delay(100);BEEP=!BEEP;}//Beep取反
BEEP=1;delayms(100);//关闭蜂鸣器,并延时
void delay(unsigned char t){while(t--);}//延时子程序1
void delayms(unsigned char ms)//延时子程序2
{unsigned char i; while(ms--){for(i=0;i<120;i++);}}
