#include#include typedef unsigned int u_size; int main() { u_size a = 0, b = 0, c = 0, d = 0; //CSD = 003e00325b5a83c5e597ffff12800000 a = 0x003e0032; //[127:96] b = 0x5b5a83c5; //[95 :64] c = 0xe597ffff; //[63 :32] d = 0x12800000; //[31 :0 ] u_size CSD_STRUCTURE = a / (u_size)pow(2,30) & 0x3; // [127:126 - 96] u_size TAAC = a/(u_size)pow(2,16) & 0xff; // [119:112] u_size NSAC = a/(u_size)pow(2,8) & 0xff; // [111:104] u_size TRAN_SPEED = a/(u_size)pow(2,0) & 0xff; // [103:96 - 96] u_size CCC = b/(u_size)pow(2,20) & 0xfff; u_size READ_BL_LEN = b/(u_size)pow(2,16) & 0xf; // [83:80-64] u_size READ_BL_PARTIA = b/(u_size)pow(2,15) & 0x1; u_size WRITE_BLK_MISALIGN = b/(u_size)pow(2,14) & 0x1; u_size READ_BLK_MISALIGN = b/(u_size)pow(2,13) & 0x1; u_size DSR_IMP = b/(u_size)pow(2,12) & 0x1; u_size C_SIZE = (b & 0x3ff)*(u_size)pow(2,2) \ + ((c /(u_size)pow(2,30)) & 0x3); // [73:62] u_size VDD_R_CURR_MIN = c/(u_size)pow(2,27) & 0x7; u_size VDD_R_CURR_MAX = c/(u_size)pow(2,24) & 0x7; u_size VDD_W_CURR_MIN = c/(u_size)pow(2,21) & 0x7; u_size VDD_W_CURR_MAX = c/(u_size)pow(2,18) & 0x7; u_size C_SIZE_MULT = c/(u_size)pow(2,15) & 0x7; // [49:47] u_size ERASE_BLK_EN = d/(u_size)pow(2,14) & 0x1; u_size SECTOR_SIZE = d/(u_size)pow(2,7) & 0xef; u_size WP_GRP_SIZE = c/(u_size)pow(2,0) & 0xef; u_size WP_GRP_ENABLE = d/(u_size)pow(2,31) & 0x1; u_size R2W_FACTOR = d/(u_size)pow(2,26) & 0x7; u_size WRITE_BL_LEN = d/(u_size)pow(2,22) & 0xf; u_size WRITE_BL_PARTIAL = d/(u_size)pow(2,21) & 0x1; u_size TMP_WRITE_PROTECT = d/(u_size)pow(2,12) & 0x1; u_size FILE_FORMAT = d/(u_size)pow(2,10) & 0x3; u_size CRC = d/(u_size)pow(2,1) & 0xff; long C = (C_SIZE + 1) * pow(2, (C_SIZE_MULT+2)) * pow(2, READ_BL_LEN); // C = (3863 + 1) * 512 * 1024 printf(" 1. CSD_STRUCTURE = 0x%x\n", CSD_STRUCTURE); printf(" 3. TAAC = 0x%x\n", TAAC); printf(" 4. NSAC = 0x%x\n", NSAC); printf(" 5. TRAN_SPEED = 0x%x (0x32==>25MHz;0x5a==>50MHz)\n", TRAN_SPEED); printf(" 6. CCC = 0x%x\n", CCC); printf(" 7. READ_BL_LEN = %d\n", READ_BL_LEN); printf(" 8. READ_BL_PARTIA = %d\n", READ_BL_PARTIA); printf(" 9. WRITE_BLK_MISALIGN = %d\n", WRITE_BLK_MISALIGN); printf("10. READ_BLK_MISALIGN = %d\n", READ_BLK_MISALIGN); printf("11. DSR_IMP = %d\n", DSR_IMP); printf("12. / *No Use* /\n"); printf("13. C_SIZE = %d\n", C_SIZE); printf("14. VDD_R_CURR_MIN = %d\n", VDD_R_CURR_MIN); printf("15. VDD_R_CURR_MAX = %d\n", VDD_R_CURR_MAX); printf("16. VDD_W_CURR_MIN = %d\n", VDD_W_CURR_MIN); printf("17. VDD_W_CURR_MAX = %d\n", VDD_W_CURR_MAX); printf("18. C_SIZE_MULT = %d\t""(本SD卡容量 = %f G)\n", C_SIZE_MULT, (float)C/1073741824); printf("19. ERASE_BLK_EN = 0x%x\n", ERASE_BLK_EN); printf("20. SECTOR_SIZE = 0x%x\n", SECTOR_SIZE); printf("21. WP_GRP_SIZE = 0x%x\n", WP_GRP_SIZE); printf("22. WP_GRP_ENABLE = 0x%x\n", WP_GRP_ENABLE); printf("23. / *No Use* /\n"); printf("24. R2W_FACTOR = 0x%x\n", R2W_FACTOR); printf("25. WRITE_BL_LEN = 0x%x\n", WRITE_BL_LEN); printf("26. WRITE_BL_PARTIAL = 0x%x\n", WRITE_BL_PARTIAL); printf("31. TMP_WRITE_PROTECT = 0x%x\n", TMP_WRITE_PROTECT); printf("32. FILE_FORMAT = 0x%x\n", FILE_FORMAT); printf("34. CRC = 0x%x\t", CRC); return 0; }
/ * @file sdi.c * @brief sd卡 读写 * @details 本程序实现了,读SD卡的CSD寄存器;读写SD卡,并用LED显示。 * 程序正常:led1首先点亮,然后是0-15的二进制显示 * 程序出错:led2首先点亮,然后是乱无序的二进制显示 * 目前只能读写2G以下的SD卡 * (启动代码是适用于mini2440 nand 256M的开发板) * 读写SD有三种模式:中断,DMA中断,查询。本程序使用的是查询 * @author kangear * @date 2013-4-26 * @version A001 * @par Copyright (c): * XXX公司 * @par History: * version: author, date, desc\n * * docs 1.SD Specifications Part 1 Physical Layer Simplified Specification Version 4.10 January 22, 2013.pdf * 2.SD Specifications Part A1 Advanced Security SD Extension Simplified Specification Version 2.00 May 18, 2010.pdf * 3.SD Specifications Part A2 SD Host Controller Simplified Specification Version 3.00 February 25, 2011.pdf * 4.SD Specifications Part E1 SDIO Simplified Specification Version 3.00 February 25, 2011.pdf * * download addr:https://www.sdcard.org/downloads/pls/simplified_specs/ */ //#include//#include #include "def.h" //#include "option.h" //#include "2440addr.h" #include "s3c24xx.h" //#include "2440lib.h" #include "sdi.h" /* * 用在SDICCON中的[7:0] 现在没有搞懂它的实际意义 * CMD1 = MAGIC_NUMBER | 1 */ #define MAGIC_NUMBER 64 #define INICLK 300000 #define SDCLK 24000000 //PCLK=49.392MHz #define POL 0 #define INT 1 #define DMA 2 int CMD13(void); // Send card status int CMD9(void); unsigned int *Tx_buffer; //128[word]*16[blk]=8192[byte] unsigned int *Rx_buffer; //128[word]*16[blk]=8192[byte] volatile unsigned int rd_cnt; volatile unsigned int wt_cnt; volatile unsigned int block; volatile unsigned int TR_end=0; int Wide=0; // 0:1bit, 1:4bit int MMC=0; // 0:SD , 1:MMC int Maker_ID; char Product_Name[7]; int Serial_Num; int PCLK = 50000000; volatile int RCA; void Test_SDI(void) { U32 save_rGPEUP, save_rGPECON; RCA=0; MMC=0; block=3072; //3072Blocks=1.5MByte, ((2Block=1024Byte)*1024Block=1MByte) save_rGPEUP=GPEUP; save_rGPECON=GPECON; GPEUP = 0xf83f; // SDCMD, SDDAT[3:0] => PU En. GPECON = 0xaaaaaaaa; //SDCMD, SDDAT[3:0] //Uart_Printf("\nSDI Card Write and Read Test\n"); if(!SD_card_init()) return; TR_Buf_new(); Wt_Block(); Rd_Block(); View_Rx_buf(); Card_sel_desel(0); // Card deselect if(!CMD9()) //Uart_Printf("Get CSD fail!!!\n"); SDIDCON=0;//tark??? SDICSTA=0xffff; GPEUP=save_rGPEUP; GPECON=save_rGPECON; } void TR_Buf_new(void) { //-- Tx & Rx Buffer initialize int i, j; Tx_buffer=(unsigned int *)0x31000000; j=0; for(i=0;i<2048;i++) //128[word]*16[blk]=8192[byte] *(Tx_buffer+i)=i+j; Flush_Rx_buf(); } void Flush_Rx_buf(void) { //-- Flushing Rx buffer int i; Rx_buffer=(unsigned int *)0x31800000; for(i=0;i<2048;i++) //128[word]*16[blk]=8192[byte] *(Rx_buffer+i)=0; //Uart_Printf("End Rx buffer flush\n"); } void View_Rx_buf() { //-- Display Rx buffer int i,error=0; Tx_buffer=(unsigned int *)0x31000000; Rx_buffer=(unsigned int *)0x31800000; //Uart_Printf("Check Rx data\n"); for(i=0;i<128*block;i++) { if(Rx_buffer[i] != Tx_buffer[i]) { //Uart_Printf("\nTx/Rx error\n"); //Uart_Printf("%d:Tx-0x%08x, Rx-0x%08x\n",i,Tx_buffer[i], Rx_buffer[i]); error=1; break; } ////Uart_Printf("."); } if(!error) { //Uart_Printf("\nThe Tx_buffer is same to Rx_buffer!\n"); //Uart_Printf("SD CARD Write and Read test is OK!\n"); } } void View_Tx_buf(void) { } int SD_card_init(void) { //-- SD controller & card initialize int i; /* Important notice for MMC test condition */ /* Cmd & Data lines must be enabled by pull up resister */ SDIPRE=PCLK/(INICLK)-1; // 400KHz //Uart_Printf("Init. Frequency is %dHz\n",(PCLK/(SDIPRE+1))); SDICON=(1<<4)|1; // Type B, clk enable SDIFSTA=SDIFSTA|(1<<16); //YH 040223 FIFO reset SDIBSIZE=0x200; // 512byte(128word) SDIDTIMER=0x7fffff; // Set timeout count for(i=0;i<0x1000;i++); // Wait 74SDCLK for MMC card CMD0(); //Uart_Printf("In idle\n"); //-- Check SD card OCR if(!Chk_SD_OCR()) { // fail GPBDAT = (~(2<<5)); // 点亮LED2 //Uart_Printf("Initialize fail\nNo Card assertion\n"); return 0; } // Uart_Printf("In SD ready\n"); GPBDAT = (~(1<<5)); // 点亮LED1 do { //-- Check attaced cards, it makes card identification state SDICARG = 0x0; // CMD2(stuff bit) SDICCON = (0x1 << 10) | (0x1 << 9) | (0x1 << 8) | (MAGIC_NUMBER | 2); //lng_resp, wait_resp, start, CMD2 //-- Check end of CMD2 } while (!Chk_CMDend(2, 1)); SDICSTA=0xa00; // Clear cmd_end(with rsp) //Uart_Printf("End id\n"); do { //--Send RCA SDICARG = MMC << 16; // CMD3(MMC:Set RCA, SD:Ask RCA-->SBZ) SDICCON = (0x1 << 9) | (0x1 << 8) | (MAGIC_NUMBER | 3); // sht_resp, wait_resp, start, CMD3 //-- Check end of CMD3 if (!Chk_CMDend(3, 1)) continue; SDICSTA = 0xa00; // Clear cmd_end(with rsp) //--Publish RCA RCA = (SDIRSP0 & 0xffff0000) >> 16; //Uart_Printf("RCA=0x%x\n",RCA); SDIPRE = PCLK / (SDCLK) - 1; // Normal clock=25MHz //Uart_Printf("SD Frequency is %dHz\n",(PCLK/(SDIPRE+1))); //--State(stand-by) check if (SDIRSP0 & 0x1e00 != 0x600) // CURRENT_STATE check continue; } while (0); //Uart_Printf("In stand-by\n"); Card_sel_desel(1); // Select Set_4bit_bus(); return 1; } void Card_sel_desel(char sel_desel) { //-- Card select or deselect if(sel_desel) { do { SDICARG = RCA << 16; // CMD7(RCA,stuff bit) SDICCON = (0x1 << 9) | (0x1 << 8) | (MAGIC_NUMBER | 7); // sht_resp, wait_resp, start, CMD7 //-- Check end of CMD7 if (!Chk_CMDend(7, 1)) continue; SDICSTA = 0xa00; // Clear cmd_end(with rsp) //--State(transfer) check if (SDIRSP0 & 0x1e00 != 0x800) continue; } while (0); } else { do { SDICARG = 0 << 16; //CMD7(RCA,stuff bit) SDICCON = (0x1 << 8) | (MAGIC_NUMBER | 7); //no_resp, start, CMD7 //-- Check end of CMD7 if (!Chk_CMDend(7, 0)) continue; } while (0); SDICSTA=0x800; // Clear cmd_end(no rsp) } } //void __irq Rd_Int(void) //{ // U32 i,status; // // status=SDIFSTA; // if( (status&0x200) == 0x200 ) // Check Last interrupt? // { // for(i=(status & 0x7f)/4;i>0;i--) // { // *Rx_buffer++=SDIDAT; // rd_cnt++; // } // SDIFSTA=SDIFSTA&0x200; //Clear Rx FIFO Last data Ready, YH 040221 // } // else if( (status&0x80) == 0x80 ) // Check Half interrupt? // { // for(i=0;i<8;i++) // { // *Rx_buffer++=SDIDAT; // rd_cnt++; // } // } // // ClearPending(BIT_SDI); //} //void __irq Wt_Int(void) //{ // ClearPending(BIT_SDI); // // SDIDAT=*Tx_buffer++; // wt_cnt++; // // if(wt_cnt==128*block) // { // rINTMSK |= BIT_SDI; // SDIDAT=*Tx_buffer; // TR_end=1; // } //} // //void __irq DMA_end(void) //{ // ClearPending(BIT_DMA0); // // TR_end=1; //} void Rd_Block(void) { U32 mode; int status; rd_cnt=0; //Uart_Printf("Block read test[ Polling read ]\n"); mode = 0 ; SDIFSTA=SDIFSTA|(1<<16); // FIFO reset if(mode!=2) SDIDCON=(2<<22)|(1<<19)|(1<<17)|(Wide<<16)|(1<<14)|(2<<12)|(block<<0); //YH 040220 SDICARG=0x0; // CMD17/18(addr) RERDCMD: switch(mode) { case POL: if(block<2) // SINGLE_READ { SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 17); // sht_resp, wait_resp, dat, start, CMD17 if(!Chk_CMDend(17, 1)) //-- Check end of CMD17 goto RERDCMD; } else // MULTI_READ { SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 18); // sht_resp, wait_resp, dat, start, CMD18 if(!Chk_CMDend(18, 1)) //-- Check end of CMD18 goto RERDCMD; } SDICSTA=0xa00; // Clear cmd_end(with rsp) while(rd_cnt<128*block) // 512*block bytes { if((SDIDSTA&0x20)==0x20) // Check timeout { SDIDSTA=(0x1<<0x5); // Clear timeout flag break; } status=SDIFSTA; if((status&0x1000)==0x1000) // Is Rx data? { *Rx_buffer++=SDIDAT; rd_cnt++; } } break; // case INT: // pISR_SDI=(unsigned)Rd_Int; // rINTMSK = ~(BIT_SDI); // // rSDIIMSK=5; // Last & Rx FIFO half int. // // if(block<2) // SINGLE_READ // { // SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 17); // sht_resp, wait_resp, dat, start, CMD17 // if(!Chk_CMDend(17, 1)) //-- Check end of CMD17 // goto RERDCMD; // } // else // MULTI_READ // { // SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 18); // sht_resp, wait_resp, dat, start, CMD18 // if(!Chk_CMDend(18, 1)) //-- Check end of CMD18 // goto RERDCMD; // } // // SDICSTA=0xa00; // Clear cmd_end(with rsp) // // while(rd_cnt<128*block); // // rINTMSK |= (BIT_SDI); // rSDIIMSK=0; // All mask // break; // // case DMA: // pISR_DMA0=(unsigned)DMA_end; // rINTMSK = ~(BIT_DMA0); // SDIDCON=SDIDCON|(1<<24); //YH 040227, Burst4 Enable // // rDISRC0=(int)(SDIDAT); // SDIDAT // rDISRCC0=(1<<1)+(1<<0); // APB, fix // rDIDST0=(U32)(Rx_buffer); // Rx_buffer // rDIDSTC0=(0<<1)+(0<<0); // AHB, inc // rDCON0=(1<<31)+(0<<30)+(1<<29)+(0<<28)+(0<<27)+(2<<24)+(1<<23)+(1<<22)+(2<<20)+128*block; // // rDMASKTRIG0=(0<<2)+(1<<1)+0; //no-stop, DMA2 channel on, no-sw trigger // // SDIDCON=(2<<22)|(1<<19)|(1<<17)|(Wide<<16)|(1<<15)|(1<<14)|(2<<12)|(block<<0); // if(block<2) // SINGLE_READ // { // SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 17); // sht_resp, wait_resp, dat, start, CMD17 // if(!Chk_CMDend(17, 1)) //-- Check end of CMD17 // goto RERDCMD; // } // else // MULTI_READ // { // SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 18); // sht_resp, wait_resp, dat, start, CMD18 // if(!Chk_CMDend(18, 1)) //-- Check end of CMD18 // goto RERDCMD; // } // // SDICSTA=0xa00; // Clear cmd_end(with rsp) // while(!TR_end); // ////Uart_Printf("SDIFSTA=0x%x\n",SDIFSTA); // rINTMSK |= (BIT_DMA0); // TR_end=0; // rDMASKTRIG0=(1<<2); //DMA0 stop // break; default: break; } //-- Check end of DATA if(!Chk_DATend()) //Uart_Printf("dat error\n"); SDIDCON=SDIDCON&~(7<<12); SDIFSTA=SDIFSTA&0x200; //Clear Rx FIFO Last data Ready, YH 040221 SDIDSTA=0x10; // Clear data Tx/Rx end detect if(block>1) { RERCMD12: //--Stop cmd(CMD12) SDICARG=0x0; //CMD12(stuff bit) SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 12);//sht_resp, wait_resp, start, CMD12 //-- Check end of CMD12 if(!Chk_CMDend(12, 1)) goto RERCMD12; SDICSTA=0xa00; // Clear cmd_end(with rsp) } } void Wt_Block(void) { U32 mode; int status; wt_cnt=0; //Uart_Printf("Block write test[ Polling write ]\n"); mode = 0 ; SDIFSTA=SDIFSTA|(1<<16); //YH 040223 FIFO reset if(mode!=2) SDIDCON=(2<<22)|(1<<20)|(1<<17)|(Wide<<16)|(1<<14)|(3<<12)|(block<<0); //YH 040220 SDICARG=0x0; // CMD24/25(addr) REWTCMD: switch(mode) { case POL: if(block<2) // SINGLE_WRITE { SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 24); //sht_resp, wait_resp, dat, start, CMD24 if(!Chk_CMDend(24, 1)) //-- Check end of CMD24 goto REWTCMD; } else // MULTI_WRITE { SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 25); //sht_resp, wait_resp, dat, start, CMD25 if(!Chk_CMDend(25, 1)) //-- Check end of CMD25 goto REWTCMD; } SDICSTA=0xa00; // Clear cmd_end(with rsp) while(wt_cnt<128*block) { status=SDIFSTA; if((status&0x2000)==0x2000) { SDIDAT=*Tx_buffer++; wt_cnt++; ////Uart_Printf("Block No.=%d, wt_cnt=%d\n",block,wt_cnt); } } break; // case INT: // pISR_SDI=(unsigned)Wt_Int; // rINTMSK = ~(BIT_SDI); // // rSDIIMSK=0x10; // Tx FIFO half int. // // if(block<2) // SINGLE_WRITE // { // SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 24); //sht_resp, wait_resp, dat, start, CMD24 // if(!Chk_CMDend(24, 1)) //-- Check end of CMD24 // goto REWTCMD; // } // else // MULTI_WRITE // { // SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 25); //sht_resp, wait_resp, dat, start, CMD25 // if(!Chk_CMDend(25, 1)) //-- Check end of CMD25 // goto REWTCMD; // } // // SDICSTA=0xa00; // Clear cmd_end(with rsp) // // while(!TR_end); // //while(wt_cnt<128); // // rINTMSK |= (BIT_SDI); // TR_end=0; // rSDIIMSK=0; // All mask // break; // // case DMA: // pISR_DMA0=(unsigned)DMA_end; // rINTMSK = ~(BIT_DMA0); // SDIDCON=SDIDCON|(1<<24); //YH 040227, Burst4 Enable // // rDISRC0=(int)(Tx_buffer); // Tx_buffer // rDISRCC0=(0<<1)+(0<<0); // AHB, inc // rDIDST0=(U32)(SDIDAT); // SDIDAT // rDIDSTC0=(1<<1)+(1<<0); // APB, fix // rDCON0=(1<<31)+(0<<30)+(1<<29)+(0<<28)+(0<<27)+(2<<24)+(1<<23)+(1<<22)+(2<<20)+128*block; // //handshake, sync PCLK, TC int, single tx, single service, SDI, H/W request, // //auto-reload off, word, 128blk*num // rDMASKTRIG0=(0<<2)+(1<<1)+0; //no-stop, DMA0 channel on, no-sw trigger // // SDIDCON=(2<<22)|(1<<20)|(1<<17)|(Wide<<16)|(1<<15)|(1<<14)|(3<<12)|(block<<0); //YH 040220 // // // Word Tx, Tx after rsp, blk, 4bit bus, dma enable, Tx start, blk num // if(block<2) // SINGLE_WRITE // { // SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 24); //sht_resp, wait_resp, dat, start, CMD24 // if(!Chk_CMDend(24, 1)) //-- Check end of CMD24 // goto REWTCMD; // } // else // MULTI_WRITE // { // SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 25); //sht_resp, wait_resp, dat, start, CMD25 // if(!Chk_CMDend(25, 1)) //-- Check end of CMD25 // goto REWTCMD; // } // // SDICSTA=0xa00; // Clear cmd_end(with rsp) // // while(!TR_end); // // rINTMSK |= (BIT_DMA0); // TR_end=0; // rDMASKTRIG0=(1<<2); //DMA0 stop // // break; default: break; } //-- Check end of DATA if(!Chk_DATend()) //Uart_Printf("dat error\n"); SDIDCON=SDIDCON&~(7<<12); //YH 040220, Clear Data Transfer mode => no operation, Cleata Data Transfer start SDIDSTA=0x10; // Clear data Tx/Rx end if(block>1) { //--Stop cmd(CMD12) REWCMD12: SDIDCON=(1<<18)|(1<<17)|(0<<16)|(1<<14)|(1<<12)|(block<<0); //YH 040220 SDICARG=0x0; //CMD12(stuff bit) SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 12); //sht_resp, wait_resp, start, CMD12 //-- Check end of CMD12 if(!Chk_CMDend(12, 1)) goto REWCMD12; SDICSTA=0xa00; // Clear cmd_end(with rsp) //-- Check end of DATA(with busy state) if(!Chk_BUSYend()) //Uart_Printf("error\n"); SDIDSTA=0x08; //! Should be cleared by writing '1'. } } void Delay(volatile unsigned long dly) { for(; dly > 0; dly--); } int Chk_CMDend(int cmd, int be_resp) //0: Timeout { int finish0; if(!be_resp) // No response { finish0=SDICSTA; while((finish0&0x800)!=0x800) // Check cmd end finish0=SDICSTA; SDICSTA=finish0;// Clear cmd end state return 1; } else // With response { finish0=SDICSTA; while( !( ((finish0&0x200)==0x200) | ((finish0&0x400)==0x400) )) // Check cmd/rsp end finish0=SDICSTA; if(cmd==1 | cmd==41) // CRC no check, CMD9 is a long Resp. command. { if( (finish0&0xf00) != 0xa00 ) // Check error { SDICSTA=finish0; // Clear error state if(((finish0&0x400)==0x400)) return 0; // Timeout error } SDICSTA=finish0; // Clear cmd & rsp end state } else // CRC check { if( (finish0&0x1f00) != 0xa00 ) // Check error { //Uart_Printf("CMD%d:SDICSTA=0x%x, SDIRSP0=0x%x\n",cmd, SDICSTA, SDIRSP0); SDICSTA=finish0; // Clear error state if(((finish0&0x400)==0x400)) return 0; // Timeout error } SDICSTA=finish0; } return 1; } } int Chk_DATend(void) { int finish; finish=SDIDSTA; while( !( ((finish&0x10)==0x10) | ((finish&0x20)==0x20) )) // Chek timeout or data end finish=SDIDSTA; if( (finish&0xfc) != 0x10 ) { //Uart_Printf("DATA:finish=0x%x\n", finish); SDIDSTA=0xec; // Clear error state return 0; } return 1; } int Chk_BUSYend(void) { int finish; finish=SDIDSTA; while( !( ((finish&0x08)==0x08) | ((finish&0x20)==0x20) )) finish=SDIDSTA; if( (finish&0xfc) != 0x08 ) { //Uart_Printf("DATA:finish=0x%x\n", finish); SDIDSTA=0xf4; //clear error state return 0; } return 1; } void CMD0(void) { //-- Make card idle state SDICARG=0x0; // CMD0(stuff bit) SDICCON=(1<<8)|(MAGIC_NUMBER | 0); // No_resp, start, CMD0 //-- Check end of CMD0 Chk_CMDend(0, 0); SDICSTA=0x800; // Clear cmd_end(no rsp) } int Chk_SD_OCR(void) { int i; //-- Negotiate operating condition for SD, it makes card ready state for(i=0;i<50;i++) //If this time is short, init. can be fail. { CMD55(); // Make ACMD SDICARG=0xff8000; //ACMD41(SD OCR:2.7V~3.6V) SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 41);//sht_resp, wait_resp, start, ACMD41 //-- Check end of ACMD41 if( Chk_CMDend(41, 1) & SDIRSP0==0x80ff8000 ) { SDICSTA=0xa00; // Clear cmd_end(with rsp) return 1; // Success } Delay(20000); // Wait Card power up status 1Sec //Delay(200); // Wait Card power up status } ////Uart_Printf("SDIRSP0=0x%x\n",SDIRSP0); SDICSTA=0xa00; // Clear cmd_end(with rsp) return 0; // Fail } int CMD55(void) { //--Make ACMD SDICARG=RCA<<16; //CMD7(RCA,stuff bit) SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 55); //sht_resp, wait_resp, start, CMD55 //-- Check end of CMD55 if(!Chk_CMDend(55, 1)) return 0; SDICSTA=0xa00; // Clear cmd_end(with rsp) return 1; } int CMD13(void)//SEND_STATUS { int response0; SDICARG=RCA<<16; // CMD13(RCA,stuff bit) SDICCON=(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 13); // sht_resp, wait_resp, start, CMD13 //-- Check end of CMD13 if(!Chk_CMDend(13, 1)) return 0; ////Uart_Printf("SDIRSP0=0x%x\n", SDIRSP0); if(SDIRSP0&0x100) ////Uart_Printf("Ready for Data\n"); //else ////Uart_Printf("Not Ready\n"); response0=SDIRSP0; response0 &= 0x3c00; response0 = response0 >> 9; ////Uart_Printf("Current Status=%d\n", response0); if(response0==6) Test_SDI(); SDICSTA=0xa00; // Clear cmd_end(with rsp) return 1; } int CMD9(void)//SEND_CSD { SDICARG=RCA<<16; // CMD9(RCA,stuff bit) SDICCON=(0x1<<10)|(0x1<<9)|(0x1<<8)|(MAGIC_NUMBER | 9); // long_resp, wait_resp, start, CMD9 //Uart_Printf("\nCSD register :\n"); //-- Check end of CMD9 if(!Chk_CMDend(9, 1)) return 0; //Uart_Printf("SDIRSP0=0x%x\nSDIRSP1=0x%x\nSDIRSP2=0x%x\nSDIRSP3=0x%x\n", SDIRSP0,rSDIRSP1,rSDIRSP2,rSDIRSP3); return 1; } void Set_4bit_bus(void) { Wide=1; SetBus(); ////Uart_Printf("\n4bit bus\n"); } void SetBus(void) { do { CMD55(); // Make ACMD //-- CMD6 implement SDICARG = Wide << 1; //Wide 0: 1bit, 1: 4bit SDICCON = (0x1 << 9) | (0x1 << 8) | (MAGIC_NUMBER | 6); //sht_resp, wait_resp, start, CMD55 if (!Chk_CMDend(6, 1)) // ACMD6 continue; SDICSTA = 0xa00; // Clear cmd_end(with rsp) } while (0); } void Set_Prt(void) { //-- Set protection addr.0 ~ 262144(32*16*512) //Uart_Printf("[Set protection(addr.0 ~ 262144) test]\n"); do { //--Make ACMD SDICARG = 0; // CMD28(addr) SDICCON = (0x1 << 9) | (0x1 << 8) | (MAGIC_NUMBER | 28); //sht_resp, wait_resp, start, CMD28 //-- Check end of CMD28 if (!Chk_CMDend(28, 1)) continue; SDICSTA = 0xa00; // Clear cmd_end(with rsp) } while (0); } void Clr_Prt(void) { //-- Clear protection addr.0 ~ 262144(32*16*512) ////Uart_Printf("[Clear protection(addr.0 ~ 262144) test]\n"); do { //--Make ACMD SDICARG = 0; // CMD29(addr) SDICCON = (0x1 << 9) | (0x1 << 8) | (MAGIC_NUMBER | 29); //sht_resp, wait_resp, start, CMD29 //-- Check end of CMD29 if (!Chk_CMDend(29, 1)) continue; SDICSTA = 0xa00; // Clear cmd_end(with rsp) } while (0); }
总结:调试和运行还是用很在的差别的,eclipse调试没有问题的,运行就会有点小问题,eclipse可以确定程序的框架,运行可以细节地显示问题,那个延时Delay(200)没有问题,到运行时候调整为Delay(2000)才可以正常。jlink的速率什么的都会影响,并不能代码整个实时的运行效果。在线调试和下载运行调试相接合才是王道。
