utilities.h
#ifndef UTILITIES_H_INCLUDED
#define UTILITIES_H_INCLUDED
typedef unsigned char uchar, BYTE, uint8;
typedef unsigned int uint, WORD, uint16;
typedef unsigned long ulong, DWORD, uint32;
typedef char int8;
typedef int int16;
typedef long int32;
typedef unsigned char * uchar_p;
typedef unsigned int * uint_p;
typedef unsigned long * ulong_p;
typedef char * char_p;
typedef int * int_p;
typedef long * long_p;
#endif // UTILITIES_H_INCLUDED
keyBoard.c
#include
#include "utilities.h"
sbit KEY_OUT_3 = P2^0;
sbit KEY_OUT_2 = P2^1;
sbit KEY_OUT_1 = P2^2;
sbit KEY_OUT_0 = P2^3;
sbit KEY_IN_0 = P2^4;
sbit KEY_IN_1 = P2^5;
sbit KEY_IN_2 = P2^6;
sbit KEY_IN_3 = P2^7;
uchar code keyCodeMap[4][4] = { //矩阵按键编号到标准键盘键码的映射表
{0x31, 0x32, 0x33, 0x26}, //数字键1、数字键2、数字键3、向上键
{0x34, 0x35, 0x36, 0x25}, //数字键4、数字键5、数字键6、向左键
{0x37, 0x38, 0x39, 0x28}, //数字键7、数字键8、数字键9、向下键
{0x30, 0x1B, 0x0D, 0x27} //数字键0、ESC键、 回车键、 向右键
uchar pdata keyState[4][4] = { //全部矩阵按键的当前状态
{1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}
extern void keyAction(uchar keyCode);
void keyDriver() {
uchar i, j;
static uchar backup[4][4] = {
for (i=0; i<4; i++)
for (j=0; j<4; j++)
if (keyState[i][j] != backup[i][j]) {
if (keyState[i][j] == 0)
keyAction(keyCodeMap[i][j]);
backup[i][j] = keyState[i][j];
void keyScan() {
static uchar i = 0;
static uchar keyBuf[4][4] = {
{0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF},
uchar j;
keyBuf[i][0] = (keyBuf[i][0] <
keyBuf[i][1] = (keyBuf[i][1] <
keyBuf[i][2] = (keyBuf[i][2] <
keyBuf[i][3] = (keyBuf[i][3] <
for (j=0; j<4; j++) {
if (keyBuf[i][j] == 0x00)
keyState[i][j] = 0;
else if (keyBuf[i][j] == 0xFF)
keyState[i][j] = 1;
switch (i) {
case 0: KEY_OUT_0 = 1; KEY_OUT_1 = 0; break;
case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
case 3: KEY_OUT_3 = 1; KEY_OUT_0 = 0; break;
default : break;
i = ++i & 0x03;
digitalTube.c
#include
uchar code LEDChar[] = { //数码管显示字符转换表
0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
uchar LEDBuff[6] = { //数码管显示缓冲区
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
void showNumber(ulong num) {
char i;
uchar buf[6];
for (i=0; i<6; i++) {
buf[i] = num % 10;
num /= 10;
for (i=5; i>0; i--) {
if (buf[i] == 0)
LEDBuff[i] = 0xFF;
else
break;
for (; i>=0; i--)
LEDBuff[i] = LEDChar[buf[i]];
void LEDScan() {
static uchar i = 0;
P0 = 0xFF;
P1 = (P1 & 0xF8) | i;
P0 = LEDBuff[i];
if (i
i++;
else
i = 0;
timer.c
#include
#define TIMER0
#define TIMER0_MOD1
#if defined (TIMER0)
uchar T0RH = 0;
uchar T0RL = 0;
#if defined (TIMER0_MOD1)
void setTmr0(uint ms) {
ulong tmp;
tmp = 11059326 / 12;
tmp = tmp * ms / 1000;
tmp = 65536 - tmp;
tmp += 28;
T0RL = tmp;
T0RH = tmp>>8;
#endif // defined
#endif // defined
calculator.c
加减乘除计算器,能实现连续的运算,并且提供修改功能:
对于算符来说,以最后输入的算符为准。
测试样例:
12 + 256 * 9 - 53 / 2
3 + - * 5
6 + - 2 / * 7
#include
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
extern uchar T0RH;
extern uchar T0RL;
extern uchar LEDBuff[6];
extern uchar code LEDChar[];
extern void showNumber(ulong num);
extern void LEDScan();
extern void keyScan();
extern void keyDriver();
extern void setTmr0(uint ms);
void keyAction(uchar keyCode) {
static ulong result = 0Lu;
static ulong number = 0Lu;
static uchar opPre = 0x26;
static bit preIsOp = 0;
if (keyCode >= 0x30 && keyCode <= 0x39) { //数字键
number = number * 10 + keyCode - 0x30;
showNumber(number);
preIsOp = 0;
else if ((keyCode >= 0x25 && keyCode <= 0x28) || keyCode == 0x0D) { //上下左右,加减乘除;回车键,相当于等于键
if (!preIsOp) {
switch (opPre) {
case 0x26: result += number; break;
case 0x28: result -= number; break;
case 0x25: result /= number; break;
case 0x27: result *= number; break;
case 0x0D: result = number; break;
default: break;
number = 0;
showNumber(result);
opPre = keyCode;
preIsOp = 1;
else if (keyCode == 0x1B) { //ESC键
number = 0Lu;
result = 0Lu;
showNumber(0Lu);
preIsOp = 0;
else {
preIsOp = 0;
void interruptTmr0() interrupt 1 {
TH0 = T0RH;
TL0 = T0RL;
LEDScan();
keyScan();
void main() {
EA = 1;
ENLED = 0;
ADDR3 = 1;
TMOD = 0x01;
setTmr0(1);
TH0 = T0RH;
TL0 = T0RL;
ET0 = 1;
TR0 = 1;
LEDBuff[0] = LEDChar[0];
while (1) {
keyDriver();
