单片机 > 单片机程序设计 > 详情
Keil C51的STARTUP.A51详解
发布时间:2025-05-16 发布时间:
$NOMOD51       ;Ax51宏汇编器控制命令:禁止预定义的8051
; This file is part of the C51 Compiler package
; Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
; STARTUP.A51: This code is executed after processor reset.
; STARTUP.A51: STARTUP.A51文件所生成的代码将在单片机复位后被执行!
; To translate this file use A51 with the following invocation:
;  将按照下面的命令行语句调用A51编译器进行编译产生目标文件
;     A51 STARTUP.A51
; To link the modified STARTUP.OBJ file to your application use the following
; BL51 invocation:
;  将按照下面的命令行语句调用BL51连接器把STARTUP.OBJ定位连接到您的程序代码中
;     BL51 , STARTUP.OBJ
; User-defined Power-On Initialization of Memory
; 自定义上电后需要初始化的储存区域
; With the following EQU statements the initialization of memory
; at processor reset can be defined:
; 使用下列EQU伪指令定义初始化的存储区域 在单片机复位后定义生效
;                   ; the absolute start-address of IDATA memory is always 0
IDATALEN            EQU     80H     ; the length of IDATA memory in bytes.
; IDATA(间接寻址区)其起始地址固定为0;IDATALEN用于指定需要初始化的IDATA区长度(以字节为单位)*
XDATASTART      EQU     0H      ; the absolute start-address of XDATA memory
XDATALEN           EQU      0H      ; the length of XDATA memory in bytes.
;XDATA (外部直接寻址区) XDATASTART用于指定需要初始化的XDATA区起始地址
;XDATALEN 用于指定需要初始化的XDATA区长度(以字节为单位)*
PDATASTART      EQU     0H      ; the absolute start-address of PDATA memory
PDATALEN           EQU     0H      ; the length of PDATA memory in bytes.
;PDATA(页寻址区) PDATASTART用于指定需要初始化的PDATA区起始地址
;PDATALEN用于指定需要初始化的;PDATA区长度(以字节为单位)*
; Notes: The IDATA space overlaps physically the DATA and BIT areas of the
;            8051 CPU. At minimum the memory space occupied from the C51
;           run-time routines must be set to zero.
;注释:8051中 IDATA 区物理上已经包括了DATA区(直接寻址区)以及 BIT区 (位寻址区)。C51(库)占用了 最小化内存空间,运行时程序需要把它设为0
; Reentrant Stack Initilization
; 重入堆栈初始化
; The following EQU statements define the stack pointer for reentrant
; functions and initialized it:
; 下面的EQU语句定义重入函数的堆栈指针并初始化它
; Stack Space for reentrant functions in the SMALL model.
; SMALL模式下的重入函数的堆栈空间
IBPSTACK        EQU     0       ; set to 1 if small reentrant is used.
;如果再SMALL模式下使用重入则设为1
IBPSTACKTOP     EQU     0FFH+1 ; set top of stack to highest location+1.
;设置堆栈顶 最高位置+1
; Stack Space for reentrant functions in the LARGE model.
; LARGE模式下的重入函数的堆栈空间
XBPSTACK        EQU     0       ; set to 1 if large reentrant is used.
;如果再LARGE模式下使用重入则设为1
XBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
;设置堆栈顶 最高位置+1
; Stack Space for reentrant functions in the COMPACT model.
; COMPACT模式下的重入函数的堆栈空间
PBPSTACK        EQU     0       ; set to 1 if compact reentrant is used.
;如果再COMPACT模式下使用重入则设为1
PBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
;设置堆栈顶 最高位置+1
; Page Definition for Using the Compact Model with 64 KByte xdata RAM
; 使用COMPACT模式时为64KB的XDATA RAM定义页
; The following EQU statements define the xdata page used for pdata
; variables. The EQU PPAGE must conform with the PPAGE control used
; in the linker invocation.
; 下面的EQU语句定义PDATA变量的使用了XDATA页
PPAGEENABLE     EQU     0       ; set to 1 if pdata object are used.
;如果使用PDATA页则设为1
PPAGE           EQU     0       ; define PPAGE number.
;定义页号
PPAGE_SFR       DATA    0A0H    ; SFR that supplies uppermost address byte
;SFR的最高地址字节
; (most 8051 variants use P2 as uppermost address byte)
; (大多数8051变量要用P2的最高地址字节)
; Standard SFR Symbols
; 标准SFR符号
ACC     DATA    0E0H
B          DATA    0F0H
SP      DATA    81H
DPL     DATA    82H
DPH     DATA    83H
                                NAME    ?C_STARTUP
?C_C51STARTUP   SEGMENT   CODE
?STACK                  SEGMENT   IDATA
                               RSEG    ?STACK
                                 DS      1
                               EXTRN CODE (?C_START)
;外部代码(这个标号将代表用户程序的启始地址)
                                PUBLIC ?C_STARTUP
;给外部使用的符号
                                CSEG    AT      0
;在code段的0地址处放以下代码(使用AT指令进行绝对地址的定位)
?C_STARTUP:     LJMP    STARTUP1
                              RSEG    ?C_C51STARTUP
STARTUP1:
IF IDATALEN <> 0
;如果长度大于1则初始化IDATA
                MOV     R0,#IDATALEN - 1
                CLR     A
IDATALOOP:      MOV     @R0,A
                DJNZ    R0,IDATALOOP
ENDIF
IF XDATALEN <> 0
;如果长度大于1则初始化XDATA
                MOV     DPTR,#XDATASTART
                MOV     R7,#LOW (XDATALEN)
IF (LOW (XDATALEN)) <> 0
;预置初始化时的外循环次数到R6
                MOV     R6,#(HIGH (XDATALEN)) +1
ELSE
                MOV     R6,#HIGH (XDATALEN)
ENDIF
                CLR     A
XDATALOOP:      MOVX    @DPTR,A
                INC     DPTR
                DJNZ    R7,XDATALOOP
                DJNZ    R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
                MOV     PPAGE_SFR,#PPAGE
ENDIF
IF PDATALEN <> 0
;如果长度大于1则初始化PDATA
                MOV     R0,#LOW (PDATASTART)
                MOV     R7,#LOW (PDATALEN)
                CLR     A
PDATALOOP:      MOVX    @R0,A
                INC     R0
                DJNZ    R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0
;SMALL模式下使用重入函数时要设置的堆栈
EXTRN DATA (?C_IBP)
                MOV     ?C_IBP,#LOW IBPSTACKTOP
ENDIF
IF XBPSTACK <> 0
;COMPACT模式下使用重入函数时要设置的堆栈
EXTRN DATA (?C_XBP)
                MOV     ?C_XBP,#HIGH XBPSTACKTOP
                MOV     ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF
IF PBPSTACK <> 0
;LARGE模式下使用重入函数时要设置的堆栈
EXTRN DATA (?C_PBP)
                MOV     ?C_PBP,#LOW PBPSTACKTOP
ENDIF
                MOV     SP,#?STACK-1
; This code is required if you use L51_BANK.A51 with Banking Mode 4
; 如果你的程序使用了Mode 4 程序分组技术(BANKING)请启用下面的程序代码
; EXTRN CODE (?B_SWITCH0)
;               CALL    ?B_SWITCH0      ; init bank mechanism to code bank 0
;程序从第一个块(bank0)开始执行
                LJMP    ?C_START ;从这里跳到你的程序入口
                END
原来的工程中没有加入startup.A51文件,程序有时会出现乱码和指针溢出的情况导致系统异常。 加入此文件后,针对C8051F340单片机4K Xdata,我采样如下设置:
XBPSTACK        EQU     1       ; set to 1 if large reentrant is used.
XBPSTACKTOP     EQU    0FFFH+1; set top of stack to highest location+1.
;设置堆栈顶 最高位置+1
系统已可以稳定运行!
