对于从事嵌入式和硬件开发的工程师来说以下资料非常有用,从内存、USB、DMA到中断非常全。
// Memory control 13
#define rBWSCON (*(volatile unsigned *)0x48000000) //Bus width & wait status
#define rBANKCON0 (*(volatile unsigned *)0x48000004) //Boot ROM control
#define rBANKCON1 (*(volatile unsigned *)0x48000008) //BANK1 control
#define rBANKCON2 (*(volatile unsigned *)0x4800000c) //BANK2 cControl
#define rBANKCON3 (*(volatile unsigned *)0x48000010) //BANK3 control
#define rBANKCON4 (*(volatile unsigned *)0x48000014) //BANK4 control
#define rBANKCON5 (*(volatile unsigned *)0x48000018) //BANK5 control
#define rBANKCON6 (*(volatile unsigned *)0x4800001c) //BANK6 control
#define rBANKCON7 (*(volatile unsigned *)0x48000020) //BANK7 control
#define rREFRESH (*(volatile unsigned *)0x48000024) //DRAM/SDRAM refresh
#define rBANKSIZE (*(volatile unsigned *)0x48000028) //Flexible Bank Size
#define rMRSRB6 (*(volatile unsigned *)0x4800002c) //Mode register set for SDRAM
#define rMRSRB7 (*(volatile unsigned *)0x48000030) //Mode register set for SDRAM
// USB Host
// INTERRUPT 8
#define rSRCPND (*(volatile unsigned *)0x4a000000) //Interrupt request status
#define rINTMOD (*(volatile unsigned *)0x4a000004) //Interrupt mode control
#define rINTMSK (*(volatile unsigned *)0x4a000008) //Interrupt mask control
#define rPRIORITY (*(volatile unsigned *)0x4a00000a) //IRQ priority control
#define rINTPND (*(volatile unsigned *)0x4a000010) //Interrupt request status
#define rINTOFFSET (*(volatile unsigned *)0x4a000014) //Interruot request source offset
#define rSUBSRCPND (*(volatile unsigned *)0x4a000018) //Sub source pending
#define rINTSUBMSK (*(volatile unsigned *)0x4a00001c) //Interrupt sub mask
// DMA 36
#define rDISRC0 (*(volatile unsigned *)0x4b000000) //DMA 0 Initial source
#define rDISRCC0 (*(volatile unsigned *)0x4b000004) //DMA 0 Initial source control
#define rDIDST0 (*(volatile unsigned *)0x4b000008) //DMA 0 Initial Destination
#define rDIDSTC0 (*(volatile unsigned *)0x4b00000c) //DMA 0 Initial Destination control
#define rDCON0 (*(volatile unsigned *)0x4b000010) //DMA 0 Control
#define rDSTAT0 (*(volatile unsigned *)0x4b000014) //DMA 0 Status
#define rDCSRC0 (*(volatile unsigned *)0x4b000018) //DMA 0 Current source
#define rDCDST0 (*(volatile unsigned *)0x4b00001c) //DMA 0 Current destination
#define rDMASKTRIG0 (*(volatile unsigned *)0x4b000020) //DMA 0 Mask trigger
#define rDISRC1 (*(volatile unsigned *)0x4b000040) //DMA 1 Initial source
#define rDISRCC1 (*(volatile unsigned *)0x4b000044) //DMA 1 Initial source control
#define rDIDST1 (*(volatile unsigned *)0x4b000048) //DMA 1 Initial Destination
#define rDIDSTC1 (*(volatile unsigned *)0x4b00004c) //DMA 1 Initial Destination control
#define rDCON1 (*(volatile unsigned *)0x4b000050) //DMA 1 Control
#define rDSTAT1 (*(volatile unsigned *)0x4b000054) //DMA 1 Status
#define rDCSRC1 (*(volatile unsigned *)0x4b000058) //DMA 1 Current source
#define rDCDST1 (*(volatile unsigned *)0x4b00005c) //DMA 1 Current destination
#define rDMASKTRIG1 (*(volatile unsigned *)0x4b000060) //DMA 1 Mask trigger
#define rDISRC2 (*(volatile unsigned *)0x4b000080) //DMA 2 Initial source
#define rDISRCC2 (*(volatile unsigned *)0x4b000084) //DMA 2 Initial source control
#define rDIDST2 (*(volatile unsigned *)0x4b000088) //DMA 2 Initial Destination
#define rDIDSTC2 (*(volatile unsigned *)0x4b00008c) //DMA 2 Initial Destination control
#define rDCON2 (*(volatile unsigned *)0x4b000090) //DMA 2 Control
#define rDSTAT2 (*(volatile unsigned *)0x4b000094) //DMA 2 Status
#define rDCSRC2 (*(volatile unsigned *)0x4b000098) //DMA 2 Current source
#define rDCDST2 (*(volatile unsigned *)0x4b00009c) //DMA 2 Current destination
#define rDMASKTRIG2 (*(volatile unsigned *)0x4b0000a0) //DMA 2 Mask trigger
#define rDISRC3 (*(volatile unsigned *)0x4b0000c0) //DMA 3 Initial source
#define rDISRCC3 (*(volatile unsigned *)0x4b0000c4) //DMA 3 Initial source control
#define rDIDST3 (*(volatile unsigned *)0x4b0000c8) //DMA 3 Initial Destination
#define rDIDSTC3 (*(volatile unsigned *)0x4b0000cc) //DMA 3 Initial Destination control
#define rDCON3 (*(volatile unsigned *)0x4b0000d0) //DMA 3 Control
#define rDSTAT3 (*(volatile unsigned *)0x4b0000d4) //DMA 3 Status
#define rDCSRC3 (*(volatile unsigned *)0x4b0000d8) //DMA 3 Current source
#define rDCDST3 (*(volatile unsigned *)0x4b0000dc) //DMA 3 Current destination
#define rDMASKTRIG3 (*(volatile unsigned *)0x4b0000e0) //DMA 3 Mask trigger
// CLOCK & POWER MANAGEMENT 7
#define rLOCKTIME (*(volatile unsigned *)0x4c000000) //PLL lock time counter
#define rMPLLCON (*(volatile unsigned *)0x4c000004) //MPLL Control//系统主频配置寄存器基地址
#define rUPLLCON (*(volatile unsigned *)0x4c000008) //UPLL Control//USB时钟频率配置寄存器基地址
#define rCLKCON (*(volatile unsigned *)0x4c00000c) //Clock generator control
#define rCLKSLOW (*(volatile unsigned *)0x4c000010) //Slow clock control
#define rCLKDIVN (*(volatile unsigned *)0x4c000014) //Clock divider control
#define rCAMDIVN (*(volatile unsigned *)0x4c000018) //USB, CAM Clock divider control
// LCD CONTROLLER 18
#define rLCDCON1 (*(volatile unsigned *)0x4d000000) //LCD control 1
#define rLCDCON2 (*(volatile unsigned *)0x4d000004) //LCD control 2
#define rLCDCON3 (*(volatile unsigned *)0x4d000008) //LCD control 3
#define rLCDCON4 (*(volatile unsigned *)0x4d00000c) //LCD control 4
#define rLCDCON5 (*(volatile unsigned *)0x4d000010) //LCD control 5
#define rLCDSADDR1 (*(volatile unsigned *)0x4d000014) //STN/TFT Frame buffer start address 1
#define rLCDSADDR2 (*(volatile unsigned *)0x4d000018) //STN/TFT Frame buffer start address 2
#define rLCDSADDR3 (*(volatile unsigned *)0x4d00001c) //STN/TFT Virtual screen address set
#define rREDLUT (*(volatile unsigned *)0x4d000020) //STN Red lookup table
#define rGREENLUT (*(volatile unsigned *)0x4d000024) //STN Green lookup table
#define rBLUELUT (*(volatile unsigned *)0x4d000028) //STN Blue lookup table
#define rDITHMODE (*(volatile unsigned *)0x4d00004c) //STN Dithering mode
#define rTPAL (*(volatile unsigned *)0x4d000050) //TFT Temporary palette
#define rLCDINTPND (*(volatile unsigned *)0x4d000054) //LCD Interrupt pending
#define rLCDSRCPND (*(volatile unsigned *)0x4d000058) //LCD Interrupt source
#define rLCDINTMSK (*(volatile unsigned *)0x4d00005c) //LCD Interrupt mask
#define rLPCSEL (*(volatile unsigned *)0x4d000060) //LPC3600 Control
#define PALETTE 0x4d000400 //Palette start address
//Nand Flash 17
#define rNFCONF (*(volatile unsigned *)0x4E000000) //NAND Flash configuration
#define rNFCONT (*(volatile unsigned *)0x4E000004) //NAND Flash control
#define rNFCMD (*(volatile unsigned *)0x4E000008) //NAND Flash command
#define rNFADDR (*(volatile unsigned *)0x4E00000C) //NAND Flash address
#define rNFDATA (*(volatile unsigned *)0x4E000010) //NAND Flash data
#define rNFDATA8 (*(volatile unsigned char *)0x4E000010) //NAND Flash data
#define rNFMECCD0 (*(volatile unsigned *)0x4E000014) //NAND Flash ECC for Main Area
#define rNFMECCD1 (*(volatile unsigned *)0x4E000018)
#define rNFSECCD (*(volatile unsigned *)0x4E00001C) //NAND Flash ECC for Spare Area
#define rNFSTAT (*(volatile unsigned *)0x4E000020) //NAND Flash operation status
#define rNFESTAT0 (*(volatile unsigned *)0x4E000024)
#define rNFESTAT1 (*(volatile unsigned *)0x4E000028)
#define rNFMECC0 (*(volatile unsigned *)0x4E00002C)
#define rNFMECC1 (*(volatile unsigned *)0x4E000030)
#define rNFSECC (*(volatile unsigned *)0x4E000034)
#define rNFSBLK (*(volatile unsigned *)0x4E000038) //NAND Flash Start block address
#define rNFEBLK (*(volatile unsigned *)0x4E00003C) //NAND Flash End block address
// UART 45
#define rULCON0 (*(volatile unsigned *)0x50000000) //UART 0 Line control
#define rUCON0 (*(volatile unsigned *)0x50000004) //UART 0 Control
#define rUFCON0 (*(volatile unsigned *)0x50000008) //UART 0 FIFO control
#define rUMCON0 (*(volatile unsigned *)0x5000000c) //UART 0 Modem control
#define rUTRSTAT0 (*(volatile unsigned *)0x50000010) //UART 0 Tx/Rx status
#define rUERSTAT0 (*(volatile unsigned *)0x50000014) //UART 0 Rx error status
#define rUFSTAT0 (*(volatile unsigned *)0x50000018) //UART 0 FIFO status
#define rUMSTAT0 (*(volatile unsigned *)0x5000001c) //UART 0 Modem status
#define rUBRDIV0 (*(volatile unsigned *)0x50000028) //UART 0 Baud rate divisor
#define rULCON1 (*(volatile unsigned *)0x50004000) //UART 1 Line control
#define rUCON1 (*(volatile unsigned *)0x50004004) //UART 1 Control
#define rUFCON1 (*(volatile unsigned *)0x50004008) //UART 1 FIFO control
#define rUMCON1 (*(volatile unsigned *)0x5000400c) //UART 1 Modem control
#define rUTRSTAT1 (*(vo
