1.HID通信的实现
2.使用USB外设
3.使用HID设备
4.配置时钟
5.USB中断放低点
6.生成代码,替换配置描述符
/* USB HID device Configuration Descriptor */
__ALIGN_BEGIN static uint8_t USBD_HID_CfgDesc[USB_HID_CONFIG_DESC_SIZ] __ALIGN_END =
0x09, /* bLength: Configuration Descriptor size */
USB_DESC_TYPE_CONFIGURATION, /* bDescriptorType: Configuration */
USB_HID_CONFIG_DESC_SIZ,
/* wTotalLength: Bytes returned */
0x00,
0x01, /*bNumInterfaces: 1 interface*/
0x01, /*bConfigurationValue: Configuration value*/
0x00, /*iConfiguration: Index of string descriptor describing
the configuration*/
0xE0, /*bmAttributes: bus powered and Support Remote Wake-up */
0x32, /*MaxPower 100 mA: this current is used for detecting Vbus*/
/************** Descriptor of Joystick Mouse interface ****************/
/* 09 */
0x09, /*bLength: Interface Descriptor size*/
USB_DESC_TYPE_INTERFACE,/*bDescriptorType: Interface descriptor type*/
0x00, /*bInterfaceNumber: Number of Interface*/
0x00, /*bAlternateSetting: Alternate setting*/
0x01, /*bNumEndpoints*/
0x03, /*bInterfaceClass: HID*/
0x01, /*bInterfaceSubClass : 1=BOOT, 0=no boot*/
0x01, /*nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse*/
0, /*iInterface: Index of string descriptor*/
/******************** Descriptor of Joystick Mouse HID ********************/
/* 18 */
0x09, /*bLength: HID Descriptor size*/
HID_DESCRIPTOR_TYPE, /*bDescriptorType: HID*/
0x11, /*bcdHID: HID Class Spec release number*/
0x01,
0x00, /*bCountryCode: Hardware target country*/
0x01, /*bNumDescriptors: Number of HID class descriptors to follow*/
0x22, /*bDescriptorType*/
HID_MOUSE_REPORT_DESC_SIZE,/*wItemLength: Total length of Report descriptor*/
0x00,
/******************** Descriptor of Mouse endpoint ********************/
/* 27 */
0x07, /*bLength: Endpoint Descriptor size*/
USB_DESC_TYPE_ENDPOINT, /*bDescriptorType:*/
HID_EPIN_ADDR, /*bEndpointAddress: Endpoint Address (IN)*/
0x03, /*bmAttributes: Interrupt endpoint*/
HID_EPIN_SIZE, /*wMaxPacketSize: 4 Byte max */
0x00,
HID_FS_BINTERVAL, /*bInterval: Polling Interval (10 ms)*/
/* 34 */
7.替换报告描述符
__ALIGN_BEGIN static uint8_t HID_MOUSE_ReportDesc[HID_MOUSE_REPORT_DESC_SIZE] __ALIGN_END =
0x05, 0x01,// USAGE_PAGE (Generic Desktop)
0x09, 0x06,// USAGE (Keyboard)
0xa1, 0x01,// COLLECTION (Application)
0x05, 0x07,// USAGE_PAGE (Keyboard)
0x19, 0xe0,// USAGE_MINIMUM (Keyboard LeftControl)
0x29, 0xe7,// USAGE_MAXIMUM (Keyboard Right GUI)
0x15, 0x00,// LOGICAL_MINIMUM (0)
0x25, 0x01,// LOGICAL_MAXIMUM (1)
0x75, 0x01,// REPORT_SIZE (1)
0x95, 0x08,// REPORT_COUNT (8)
0x81, 0x02,// INPUT (Data,Var,Abs)
0x95, 0x01,// REPORT_COUNT (1)
0x75, 0x08,// REPORT_SIZE (8)
0x81, 0x03,// INPUT (Cnst,Var,Abs)
0x95, 0x05,// REPORT_COUNT (5)
0x05, 0x08,// USAGE_PAGE (LEDs)
0x19, 0x01,// USAGE_MINIMUM (Num Lock)
0x29, 0x05,// USAGE_MAXIMUM (Kana)
0x91, 0x02,// OUTPUT (Data,Var,Abs)
0x75, 0x03,// REPORT_SIZE (3)
0x91, 0x03,// OUTPUT (Cnst,Var,Abs)
0x95, 0x06,// REPORT_COUNT (6)
0x25, 0xFF,// LOGICAL_MAXIMUM (255)
0x19, 0x00,// USAGE_MINIMUM (Reserved (no event indicated))
0x29, 0x65,// USAGE_MAXIMUM (Keyboard Application)
0x81, 0x00,// INPUT (Data,Ary,Abs)
0xc0
8.修改宏定义
#define HID_EPIN_ADDR 0x81
#define HID_EPIN_SIZE 0x08
#define USB_HID_CONFIG_DESC_SIZ 34
#define USB_HID_DESC_SIZ 9
#define HID_MOUSE_REPORT_DESC_SIZE 63
#define HID_DESCRIPTOR_TYPE 0x21
#define HID_REPORT_DESC 0x22
#define HID_HS_BINTERVAL 0x07
#define HID_FS_BINTERVAL 0x0A
#define HID_POLLING_INTERVAL 0x0A
#define HID_REQ_SET_PROTOCOL 0x0B
#define HID_REQ_GET_PROTOCOL 0x03
#define HID_REQ_SET_IDLE 0x0A
#define HID_REQ_GET_IDLE 0x02
#define HID_REQ_SET_REPORT 0x09
#define HID_REQ_GET_REPORT 0x01
9.通过函数发送键值,自己写(USBD_HID_SendReport)
10.通过bushound监测上传数据
键盘发送给PC的数据每次8个字节:BYTE1 BYTE2 BYTE3 BYTE4 BYTE5 BYTE6 BYTE7 BYTE8。定义分别是:
BYTE1 --
|--bit0: Left Control 是否按下,按下为1
|--bit1: Left Shift 是否按下,按下为1
|--bit2: Left Alt 是否按下,按下为1
|--bit3: Left GUI 是否按下,按下为1
|--bit4: Right Control 是否按下,按下为1
|--bit5: Right Shift 是否按下,按下为1
|--bit6: Right Alt 是否按下,按下为1
|--bit7: Right GUI 是否按下,按下为1
BYTE2 -- 暂不清楚,有的地方说是保留位
BYTE3--BYTE8 -- 这六个为普通按键
第一列10进制键值,第二列16进制键值,第四列是按键
0 00 Reserved (no event indicated)9 N/A √ √ √ 4/101/104
1 01 Keyboard ErrorRollOver9 N/A √ √ √ 4/101/104
2 02 Keyboard POSTFail9 N/A √ √ √ 4/101/104
3 03 Keyboard ErrorUndefined9 N/A √ √ √ 4/101/104
4 04 Keyboard a and A4 31 √ √ √ 4/101/104
5 05 Keyboard b and B 50 √ √ √ 4/101/104
6 06 Keyboard c and C4 48 √ √ √ 4/101/104
7 07 Keyboard d and D 33 √ √ √ 4/101/104
8 08 Keyboard e and E 19 √ √ √ 4/101/104
9 09 Keyboard f and F 34 √ √ √ 4/101/104
10 0A Keyboard g and G 35 √ √ √ 4/101/104
11 0B Keyboard h and H 36 √ √ √ 4/101/104
12 0C Keyboard i and I 24 √ √ √ 4/101/104
13 0D Keyboard j and J 37 √ √ √ 4/101/104
14 0E Keyboard k and K 38 √ √ √ 4/101/104
15 0F Keyboard l and L 39 √ √ √ 4/101/104
16 10 Keyboard m and M4 52 √ √ √ 4/101/104
17 11 Keyboard n and N 51 √ √ √ 4/101/104
18 12 Keyboard o and O4 25 √ √ √ 4/101/104
19 13 Keyboard p and P4 26 √ √ √ 4/101/104
20 14 Keyboard q and Q4 17 √ √ √ 4/101/104
21 15 Keyboard r and R 20 √ √ √ 4/101/104
22 16 Keyboard s and S4 32 √ √ √ 4/101/104
23 17 Keyboard t and T 21 √ √ √ 4/101/104
24 18 Keyboard u and U 23 √ √ √ 4/101/104
25 19 Keyboard v and V 49 √ √ √ 4/101/104
26 1A Keyboard w and W4 18 √ √ √ 4/101/104
27 1B Keyboard x and X4 47 √ √ √ 4/101/104
28 1C Keyboard y and Y4 22 √ √ √ 4/101/104
29 1D Keyboard z and Z4 46 √ √ √ 4/101/104
30 1E Keyboard 1 and !4 2 √ √ √ 4/101/104
31 1F Keyboard 2 and @4 3 √ √ √ 4/101/104
32 20 Keyboard 3 and #4 4 √ √ √ 4/101/104
33 21 Keyboard 4 and $4 5 √ √ √ 4/101/104
34 22 Keyboard 5 and %4 6 √ √ √ 4/101/104
35 23 Keyboard 6 and ^4 7 √ √ √ 4/101/104
36 24 Keyboard 7 and &4 8 √ √ √ 4/101/104
37 25 Keyboard 8 and *4 9 √ √ √ 4/101/104
38 26 Keyboard 9 and (4 10 √ √ √ 4/101/104
39 27 Keyboard 0 and )4 11 √ √ √ 4/101/104
40 28 Keyboard Return (ENTER)5 43 √ √ √ 4/101/104
41 29 Keyboard ESCAPE 110 √ √ √ 4/101/104
42 2A Keyboard DELETE (Backspace)13 15 √ √ √ 4/101/104
43 2B Keyboard Tab 16 √ √ √ 4/101/104
44 2C Keyboard Spacebar 61 √ √ √ 4/101/104
45 2D Keyboard - and (underscore)4 12 √ √ √ 4/101/104
46 2E Keyboard = and +4 13 √ √ √ 4/101/104
47 2F Keyboard [ and {4 27 √ √ √ 4/101/104
48 30 Keyboard ] and }4 28 √ √ √ 4/101/104
49 31 Keyboard and | 29 √ √ √ 4/101/104
50 32 Keyboard Non-US # and ~2 42 √ √ √ 4/101/104
51 33 Keyboard ; and :4 40 √ √ √ 4/101/104
52 34 Keyboard ‘ and “4 41 √ √ √ 4/101/104
53 35 Keyboard Grave Accent and Tilde4 1 √ √ √ 4/101/104
54 36 Keyboard, and <4 53 √ √ √ 4/101/104
55 37 Keyboard . and >4 54 √ √ √ 4/101/104
56 38 Keyboard / and ?4 55 √ √ √ 4/101/104
57 39 Keyboard Caps Lock11 30 √ √ √ 4/101/104
58 3A Keyboard F1 112 √ √ √ 4/101/104
59 3B Keyboard F2 113 √ √ √ 4/101/104
60 3C Keyboard F3 114 √ √ √ 4/101/104
61 3D Keyboard F4 115 √ √ √ 4/101/104
62 3E Keyboard F5 116 √ √ √ 4/101/104
63 3F Keyboard F6 117 √ √ √ 4/101/104
64 40 Keyboard F7
