单片机 > 单片机程序设计 > 详情
51单片机6自由度机械臂调试程序,带LCD1602PWM显示
发布时间:2021-01-20 发布时间:
以前学习51的时候为了调试机械臂角度编写的程序,用在开发板上也比较方便,但是由于是普通的舵机,不是总线的,所以需要自己洞洞板焊一个供电带电路。
单片机源程序如下:
#include
#include
#define uchar unsigned char
#define uint unsigned int
sbit duoji0=P2^0;          //PWM输出
sbit duoji1=P2^1;
sbit duoji2=P2^2;
sbit duoji3=P2^3;
sbit duoji4=P3^1;
sbit duoji5=P3^0;
#define GPIO_KEY P1
unsigned int k0;
unsigned int k1;
unsigned int k2;
unsigned int k4;
unsigned int k3;
unsigned int k5;         //定义下降沿节点
uint dsip[8]={0};
uint j=0;
unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','D',' '};
void delayms(uint xms)
  uchar j;
        uint i;
        for(i=xms;i>0;i--)
        for(j=112;j>0;j--);
void time0() interrupt 1
        static uint ii0=0;
  TH0=(65536-100)/256;      //以20ms为一个周期,以0.1ms为一个脉冲宽度
  TL0=(65536-100)%256;
  ii0++;
        if(ii0<=k0)
    duoji0=1;    //0号舵机pwm输出
  else
    duoji0=0;
        if(ii0<=k1)    //1号舵机pwm输出
    duoji1=1;
  else
    duoji1=0;
  if(ii0<=k2)    //2号舵机pwm输出
    duoji2=1;
  else
    duoji2=0;
if(ii0<=k3)     //3号舵机pwm输出
    duoji3=1;
  else
    duoji3=0;
         if(ii0<=k4)   //4号舵机pwm输出
    duoji4=1;
  else
    duoji4=0;
         if(ii0<=k5)   //5号舵机pwm输出
    duoji5=1;
  else
    duoji5=0;
        if(ii0==200)
    ii0=0;
void time0init()
  TMOD=0x01;
  TR0=1;
  ET0=1;
  EA=1;
char KeyDown()
        uchar KeyValue=20;
        uchar a=0;
        GPIO_KEY=0x0f;
        if(GPIO_KEY!=0x0f)//读取按键是否按下
                delayms(10);//延时10ms进行消抖
                if(GPIO_KEY!=0x0f)//再次检测键盘是否按下
                        //测试列
                        GPIO_KEY=0X0F;
                        switch(GPIO_KEY)
                                case(0X07):        KeyValue=0;break;
                                case(0X0b):        KeyValue=1;break;
                                case(0X0d): KeyValue=2;break;
                                case(0X0e):        KeyValue=3;break;
                        //测试行
                        GPIO_KEY=0XF0;
                        switch(GPIO_KEY)
                                case(0X70):        KeyValue=KeyValue;break;
                                case(0Xb0):        KeyValue=KeyValue+4;break;
                                case(0Xd0): KeyValue=KeyValue+8;break;
                                case(0Xe0):        KeyValue=KeyValue+12;break;
                        while((a<50)&&(GPIO_KEY!=0xf0))         //检测按键松手检测,当按键等于0xf时候跳出循环
                                delayms(100);
                                a++;
        return KeyValue;
void count()
          LcdWriteData(ASCII[0]);
          LcdWriteData(ASCII[11]);
    LcdWriteData(ASCII[k0/10]);
                LcdWriteData(ASCII[k0%10]);
          LcdWriteData(ASCII[12]);
          LcdWriteData(ASCII[1]);
                LcdWriteData(ASCII[k1/10]);
                LcdWriteData(ASCII[k1%10]);
          LcdWriteCom(0x80+0x40);
          LcdWriteData(ASCII[2]);
                LcdWriteData(ASCII[k2/10]);
                LcdWriteData(ASCII[k2%10]);
          LcdWriteData(ASCII[3]);
                LcdWriteData(ASCII[k3/10]);
                LcdWriteData(ASCII[k3%10]);
void main()
  time0init();
        k0=15;
        k1=9;
        k2=16;
        k3=14;
        k4=8;
        k5=8;
        LcdInit();
        count();
        while(1)
                uchar KeyValue1=20;
          KeyValue1=KeyDown();
                if(KeyValue1==0&&k0<=20&&k0>=8)        //0号舵机高电平时间增加
                     k0++;
                     if(k0==21)
                                         k0=20;
                                 KeyValue1=20;LcdWriteCom(0x01);        count();
if(Ke
关键字:51单片机  6自由度机械臂  LCD1602PWM显示
