电路原理图如下:
制作出来的实物图如下:
单片机源程序如下:
#include
#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
sbit DATA=P1^0;
sbit MOTOR_A_1=P2^5; //电机控制脚
sbit MOTOR_A_2=P2^6; //电机控制脚
sbit EN_MOTOR_A =P2^7; //电机控制脚
sbit k1=P3^2; //按键
sbit k2=P3^3; //按键
sbit k3=P3^4; //按键
sbit k4=P3^5; //按键
sbit k5=P3^6;
sbit CS = P1^2;
sbit Clk = P1^3;
sbit DATI = P1^4;
sbit DATO = P1^4;
unsigned char dat = 0x00;
unsigned char count = 0x00;
unsigned char CH;
uchar mode=0;
sbit LED0=P2^3;
sbit LED1=P2^4;
uchar temp,humi;
uchar error; //用于检验是否出现错误
uchar checksum,nn; //CRC
uchar nn; //蜂鸣器
uchar TEMP_data[6]; //用于记录实测的温度
uchar CO2_data[6]; //用于记录实测的温度
uchar U8FLAG,k;
uchar U8count,U8temp;
uchar U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
uchar U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
uchar U8comdata;
uchar count, count_r=0;
void Delay1(uint );
void Delay_10us(void);
void COM(void);
uchar RH(void);
unsigned char adc0832(unsigned char CH)
unsigned char i,test,adval;
adval = 0x00;
test = 0x00;
Clk = 0;
DATI = 1;
_nop_();
CS = 0;
_nop_();
Clk = 1;
_nop_();
if ( CH == 0x00 )
Clk = 0;
DATI = 1;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
DATI = 0;
_nop_();
Clk = 1;
_nop_();
else
Clk = 0;
DATI = 1;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
DATI = 1;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
DATI = 1;
for( i = 0;i < 8;i++ )
_nop_();
adval <<= 1;
Clk = 1;
_nop_();
Clk = 0;
if (DATO)
adval |= 0x01;
else
adval |= 0x00;
for (i = 0; i < 8; i++)
test >>= 1;
if (DATO)
test |= 0x80;
else
test |= 0x00;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
if (adval == test)
dat = test;
_nop_();
CS = 1;
DATO = 1;
Clk = 1;
return dat;
void Delay1(uint j)
uchar i;
for(;j>0;j--)
for(i=0;i<27;i++);
uchar i;
i--;
i--;
i--;
i--;
i--;
i--;
void COM(void)
uchar i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!DATA)&&U8FLAG++);
Delay_10us();
Delay_10us();
Delay_10us();
U8temp=0;
if(DATA)U8temp=1;
U8FLAG=2;
while((DATA)&&U8FLAG++);
if(U8FLAG==1)break;
//-----温湿度读取子程序 ------------
//----以下变量均为全局变量--------
//----温度高8位== U8T_data_H------
//----温度低8位== U8T_data_L------
//----湿度高8位== U8RH_data_H-----
//----湿度低8位== U8RH_data_L-----
//----校验 8位 == U8checkdata-----
//----调用相关子程序如下----------
//---- Delay();, Delay_10us();,COM();
uchar RH(void)
DATA=0; //主机拉低18ms
Delay1(180); //原来为5
DATA=1; //总线由上拉电阻拉高 主机延时20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
DATA=1; //主机设为输入 判断从机响应信号
if(!DATA) //判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行
U8FLAG=2;
while((!DATA)&&U8FLAG++); //判断从机是否发出 80us 的低电平响应信号是否结束
U8FLAG=2;
while((DATA)&&U8FLAG++); //判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
COM(); //数据接收状态
U8RH_data_H_temp=U8comdata;
COM();
U8RH_data_L_temp=U8comdata;
COM();
U8T_data_H_temp=U8comdata;
COM();
U8T_data_L_temp=U8comdata;
COM();
U8checkdata_temp=U8comdata;
DATA=1;
U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp); //数据校验
if(U8temp==U8checkdata_temp)
U8RH_data_H=U8RH_data_H_temp;
U8RH_data_L=U8RH_data_L_temp;
U8T_data_H=U8T_data_H_temp;
U8T_data_L=U8T_data_L_temp;
U8checkdata=U8checkdata_temp;
return 1;
else //传感器不响应
return 0;
void delay(uint z) //延时函数z为毫秒数
int a,b;
for(a=z;a>0;a--)
for(b=120;b>0;b--);
void key()
if (k1==0) //调整按键检测
delay(10);
if (k1==0)
mode=!mode;
EN_MOTOR_A=0; //电机启动,等于0停止
while(k1==0);
if (k2==0) //调整按键检测
delay(10);
if (k2==0)
if(mode==0)
EN_MOTOR_A=1; //电机启动,等于0停止
MOTOR_A_2 =0; //正转
MOTOR_A_1 =1; //反转停止
while(k2==0);
if (k3==0) //调整按键检测
delay(10);
if (k3==0)
