//********************written by ovie.xuan 2010.08.12---------------------
#include
#include
#include
#include
//#include
#define sce0 PORTC&=0XFd //片选
#define rst0 PORTC&=0XFb //复位
#define dc0 PORTC&=0XEF //1写数据,0写指令
#define sdin0 PORTB&=0XF7 //数据
#define sclk0 PORTB&=0XDF //时钟
#define sce1 PORTC|=0X02 //片选
#define rst1 PORTC|=0X04 //复位
#define dc1 PORTC|=0X10 //1写数据,0写指令
#define sdin1 PORTB|=0X08 //数据
#define sclk1 PORTB|=0X20 //时钟
#define hc138dis PORTB&=0XEF //g=0
#define hc138en PORTB|=0X10 //g=1
const prog_char font6x8[] =
0x00, 0x00, 0x00, 0x00, 0x00, 0x00,// sp
0x00, 0x00, 0x00, 0x2f, 0x00, 0x00,// !
0x00, 0x00, 0x07, 0x00, 0x07, 0x00,// "
0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14,// #
0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12,// $
0x00, 0x62, 0x64, 0x08, 0x13, 0x23,// %
0x00, 0x36, 0x49, 0x55, 0x22, 0x50,// &
0x00, 0x00, 0x05, 0x03, 0x00, 0x00,// '
0x00, 0x00, 0x1c, 0x22, 0x41, 0x00,// (
0x00, 0x00, 0x41, 0x22, 0x1c, 0x00,// )
0x00, 0x14, 0x08, 0x3E, 0x08, 0x14,// *
0x00, 0x08, 0x08, 0x3E, 0x08, 0x08,// +
0x00, 0x00, 0x00, 0xA0, 0x60, 0x00,// ,
0x00, 0x08, 0x08, 0x08, 0x08, 0x08,// -
0x00, 0x00, 0x60, 0x60, 0x00, 0x00,// .
0x00, 0x20, 0x10, 0x08, 0x04, 0x02,// /
0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E,// 0
0x00, 0x00, 0x42, 0x7F, 0x40, 0x00,// 1
0x00, 0x42, 0x61, 0x51, 0x49, 0x46,// 2
0x00, 0x21, 0x41, 0x45, 0x4B, 0x31,// 3
0x00, 0x18, 0x14, 0x12, 0x7F, 0x10,// 4
0x00, 0x27, 0x45, 0x45, 0x45, 0x39,// 5
0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30,// 6
0x00, 0x01, 0x71, 0x09, 0x05, 0x03,// 7
0x00, 0x36, 0x49, 0x49, 0x49, 0x36,// 8
0x00, 0x06, 0x49, 0x49, 0x29, 0x1E,// 9
0x00, 0x00, 0x36, 0x36, 0x00, 0x00,// :
0x00, 0x00, 0x56, 0x36, 0x00, 0x00,// ;
0x00, 0x08, 0x14, 0x22, 0x41, 0x00,// <
0x00, 0x14, 0x14, 0x14, 0x14, 0x14,// =
0x00, 0x00, 0x41, 0x22, 0x14, 0x08,// >
0x00, 0x02, 0x01, 0x51, 0x09, 0x06,// ?
0x00, 0x32, 0x49, 0x59, 0x51, 0x3E,// @
0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C,// A
0x00, 0x7F, 0x49, 0x49, 0x49, 0x36,// B
0x00, 0x3E, 0x41, 0x41, 0x41, 0x22,// C
0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C,// D
0x00, 0x7F, 0x49, 0x49, 0x49, 0x41,// E
0x00, 0x7F, 0x09, 0x09, 0x09, 0x01,// F
0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A,// G
0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F,// H
0x00, 0x00, 0x41, 0x7F, 0x41, 0x00,// I
0x00, 0x20, 0x40, 0x41, 0x3F, 0x01,// J
0x00, 0x7F, 0x08, 0x14, 0x22, 0x41,// K
0x00, 0x7F, 0x40, 0x40, 0x40, 0x40,// L
0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F,// M
0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F,// N
0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E,// O
0x00, 0x7F, 0x09, 0x09, 0x09, 0x06,// P
0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E,// Q
0x00, 0x7F, 0x09, 0x19, 0x29, 0x46,// R
0x00, 0x46, 0x49, 0x49, 0x49, 0x31,// S
0x00, 0x01, 0x01, 0x7F, 0x01, 0x01,// T
0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F,// U
0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F,// V
0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F,// W
0x00, 0x63, 0x14, 0x08, 0x14, 0x63,// X
0x00, 0x07, 0x08, 0x70, 0x08, 0x07,// Y
0x00, 0x61, 0x51, 0x49, 0x45, 0x43,// Z
0x00, 0x00, 0x7F, 0x41, 0x41, 0x00,// [
0x00, 0x55, 0x2A, 0x55, 0x2A, 0x55,// 55
0x00, 0x00, 0x41, 0x41, 0x7F, 0x00,// ]
0x00, 0x04, 0x02, 0x01, 0x02, 0x04,// ^
0x00, 0x40, 0x40, 0x40, 0x40, 0x40,// _
0x00, 0x00, 0x01, 0x02, 0x04, 0x00,// '
0x00, 0x20, 0x54, 0x54, 0x54, 0x78,// a
0x00, 0x7F, 0x48, 0x44, 0x44, 0x38,// b
0x00, 0x38, 0x44, 0x44, 0x44, 0x20,// c
0x00, 0x38, 0x44, 0x44, 0x48, 0x7F,// d
0x00, 0x38, 0x54, 0x54, 0x54, 0x18,// e
0x00, 0x08, 0x7E, 0x09, 0x01, 0x02,// f
0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C,// g
0x00, 0x7F, 0x08, 0x04, 0x04, 0x78,// h
0x00, 0x00, 0x44, 0x7D, 0x40, 0x00,// i
0x00, 0x40, 0x80, 0x84, 0x7D, 0x00,// j
0x00, 0x7F, 0x10, 0x28, 0x44, 0x00,// k
0x00, 0x00, 0x41, 0x7F, 0x40, 0x00,// l
0x00, 0x7C, 0x04, 0x18, 0x04, 0x78,// m
0x00, 0x7C, 0x08, 0x04, 0x04, 0x78,// n
0x00, 0x38, 0x44, 0x44, 0x44, 0x38,// o
0x00, 0xFC, 0x24, 0x24, 0x24, 0x18,// p
0x00, 0x18, 0x24, 0x24, 0x18, 0xFC,// q
0x00, 0x7C, 0x08, 0x04, 0x04, 0x08,// r
0x00, 0x48, 0x54, 0x54, 0x54, 0x20,// s
0x00, 0x04, 0x3F, 0x44, 0x40, 0x20,// t
0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C,// u
0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C,// v
0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C,// w
0x00, 0x44, 0x28, 0x10, 0x28, 0x44,// x
0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C,// y
0x00, 0x44, 0x64, 0x54, 0x4C, 0x44,// z
0x14, 0x14, 0x14, 0x14, 0x14, 0x14// horiz lines
//****write data to lcd via spi module******************
void LCD_write_byte(unsigned char dt, unsigned char command)
SPCR=0b01010000;//unable spi interrupt,enable spi,send MSB firetly,
//主机模式,空闲时SCK位低电平,起始沿采样SCK频率fosc/4,
sce0;
if(command)
dc1;
else
dc0;
SPDR=dt; //开始发送数据
while((SPSR>>7)==0); //等待发送接收结束
//---------------initial lcd--------------
void LCD_init(void)
LCD_write_byte(0x21,0);//LCD功能设置:芯片活动,水平寻址,使用扩展指令
LCD_write_byte(0xc0,0);//设置VOP值
LCD_write_byte(0x20,0);//LCD功能设置:芯片活动,水平寻址,使用基本指令
LCD_write_byte(0x0C,0);//设定显示配置:普通模式
sce1;
//-------set XY coordinate----------------
void LCD_set_XY(unsigned char X, unsigned char Y)
LCD_write_byte(0x40 | Y, 0);// column
LCD_write_byte(0x80 | X, 0);// row
sce1;
//-------clear lcd---------------
void LCD_clear(void)
unsigned char t;
unsigned char k;
LCD_set_XY(0,0);
for(t=0;t<6;t++)
for(k=0;k<84;k++)
LCD_write_byte(0x00,1);
sce1;
//-----display english char-----------------
void LCD_write_char(unsigned char c)
unsigned char line;
c-=32;
for (line=0; line<6; line++)
LCD_write_byte(pgm_read_byte(font6x8+c*6+line), 1);
//------display english char string-----------
void LCD_write_String(unsigned char X,unsigned char Y,char *s)
LCD_set_XY(X,Y);
while (*s)
LCD_write_char(*s);
s++;
int main(void)
DDRC=0x16;
DDRB=0x3a;
_delay_ms(100);
rst0;
_delay_ms(10);
rst1;//复位的正边缘之后sce为低,串行接口准备接收命令、数据的位7,数据传送依次从最高位到最低位。
LCD_init();
LCD_clear();
LCD_write_String(1,0,"Ovie is num1 !");
LCD_write_String(1,1,"Sorry,I cannot");
LCD_write_String(1,2,"tell you anyt");
LCD_write_String(1,3,"hing about her ");
LCD_write_String(1,4,"and me,it is");
LCD_write_String(1,5,"private thing.");
hc138dis;
//wdt_enable(WDTO_2S); //enable wdt,2秒复位
while(1)
//wdt_reset(); //喂狗指令
