起因
在调试MSP430G系列的单片机的过程,发现不怎么的,时钟频率发生了变化,时间一下都对不上了。查收些资料说,DCO的值有可能被擦除了导致时钟不对的。细想一下,好像是在调试的过程中,出现调试不了的现象就在IAR里点击的“Erase memory”。把查找的资料记录下来,所以就有这篇文章。
问题描述
因为DCO校准值在MCU出厂时保存于信息段A,一般是不允许清除信息段A的。
且示例代码中,有如下语句:
if (CALBC1_1MHZ ==0xFF || CALDCO_1MHZ == 0xFF)
while(1);// If calibration constants erased
// do not load, trap CPU!!
BCSCTL1 = CALBC1_1MHZ; // Set range
DCOCTL = CALDCO_1MHZ; // Set DCO step + modulation
可以看出在启动时都先检查DCO1MHZ的校准值是否为0xFF,是则进入while(1)死循环。
正常情况下因为信息段A不清除没问题的,但是我测试BSL下载时,故意给错误的BSL密码,导致FLASH都被擦除,发现转载DCO校准值的信息段A也被清掉了,于是程序运行到上面的代码时即进入死循环。
解决办法
针对于这种DCO数据被擦除的情况,一般的解决办法是,通过利用Timer捕捉外部的32.768K晶振或是时钟源,然后得到1M,8M或是12Mhz之类的DCO的数值,然后在直接写入segment flashA里面。
有两个解决方案供选择:
1、外接晶体,用晶体配合timer校正DCO,TI的msp4300ware有源代码。如下:
* MSP430 CODE EXAMPLE DISCLAIMER
* MSP430 code examples are self-contained low-level programs that typically
* demonstrate a single peripheral function or device feature in a highly
* concise manner. For this the code may rely on the device's power-on default
* register values and settings such as the clock configuration and care must
* be taken when combining code from several examples to avoid potential side
* effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
* for an API functional library-approach to peripheral configuration.
* --/COPYRIGHT--
// MSP430G2xx1 Demo - DCO Calibration Constants Programmer
// NOTE: THIS CODE REPLACES THE TI FACTORY-PROGRAMMED DCO CALIBRATION
// CONSTANTS LOCATED IN INFOA WITH NEW VALUES. USE ONLY IF THE ORIGINAL
// CONSTANTS ACCIDENTALLY GOT CORRUPTED OR ERASED.
// Description: This code re-programs the G2xx1 DCO calibration constants.
// A software FLL mechanism is used to set the DCO based on an external
// 32kHz reference clock. After each calibration, the values from the
// clock system are read out and stored in a temporary variable. The final
// frequency the DCO is set to is 1MHz, and this frequency is also used
// during Flash programming of the constants. The program end is indicated
// by the blinking LED.
// ACLK = LFXT1/8 = 32768/8, MCLK = SMCLK = target DCO
// //* External watch crystal installed on XIN XOUT is required for ACLK *//
// MSP430G2xx1
// /|| XIN|-
// | | | 32kHz
// --|RST XOUT|-
// | P1.0|--> LED
// | P1.4|--> SMLCK = target DCO
// A. Dannenberg
// Texas Instruments Inc.
// May 2010
// Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 3.42A
#include
#define DELTA_1MHZ 244 // 244 x 4096Hz = 999.4Hz
#define DELTA_8MHZ 1953 // 1953 x 4096Hz = 7.99MHz
#define DELTA_12MHZ 2930 // 2930 x 4096Hz = 12.00MHz
#define DELTA_16MHZ 3906 // 3906 x 4096Hz = 15.99MHz
unsigned char CAL_DATA[8]; // Temp. storage for constants
volatile unsigned int i;
int j;
char *Flash_ptrA; // Segment A pointer
void Set_DCO(unsigned int Delta);
int main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
for (i = 0; i < 0xfffe; i++); // Delay for XTAL stabilization
P1OUT = 0x00; // Clear P1 output latches
P1SEL = 0x10; // P1.4 SMCLK output
P1DIR = 0x11; // P1.0,4 output
j = 0; // Reset pointer
Set_DCO(DELTA_16MHZ); // Set DCO and obtain constants
CAL_DATA[j++] = DCOCTL;
CAL_DATA[j++] = BCSCTL1;
Set_DCO(DELTA_12MHZ); // Set DCO and obtain constants
Set_DCO(DELTA_8MHZ); // Set DCO and obtain constants
Set_DCO(DELTA_1MHZ); // Set DCO and obtain constants
Flash_ptrA = (char *)0x10C0; // Point to beginning of seg A
FCTL2 = FWKEY + FSSEL0 + FN1; // MCLK/3 for Flash Timing Generator
FCTL1 = FWKEY + ERASE; // Set Erase bit
FCTL3 = FWKEY + LOCKA; // Clear LOCK & LOCKA bits
*Flash_ptrA = 0x00; // Dummy write to erase Flash seg A
FCTL1 = FWKEY + WRT; // Set WRT bit for write operation
Flash_ptrA = (char *)0x10F8; // Point to beginning of cal consts
for (j = 0; j < 8; j++)
*Flash_ptrA++ = CAL_DATA[j]; // re-flash DCO calibration data
FCTL1 = FWKEY; // Clear WRT bit
FCTL3 = FWKEY + LOCKA + LOCK; // Set LOCK & LOCKA bit
while (1)
P1OUT ^= 0x01; // Toggle LED
for (i = 0; i < 0x4000; i++); // SW Delay
void Set_DCO(unsigned int Delta) // Set DCO to selected frequency
unsigned int Compare, Oldcapture = 0;
BCSCTL1 |= DIVA_3; // ACLK = LFXT1CLK/8
TACCTL0 = CM_1 + CCIS_1 + CAP; // CAP, ACLK
TACTL = TASSEL_2 + MC_2 + TACLR; // SMCLK, cont-mode, clear
while (1)
while (!(CCIFG & TACCTL0)); // Wait until capture occured
TACCTL0 &= ~CCIFG; // Capture occured, clear flag
Compare = TACCR0; // Get current captured SMCLK
Compare = Compare - Oldcapture; // SMCLK difference
Oldcapture = TACCR0; // Save current captured SMCLK
if (Delta == Compare)
break; // If equal, leave "while(1)"
else if (Delta < Compare)
DCOCTL--; // DCO is too fast, slow it down
if (DCOCTL == 0xFF) // Did DCO roll under?
if (BCSCTL1 & 0x0f)
BCSCTL1--;
