只有控制16路舵机的程序,现在发上来提供参考
舵机可以通过串口控制,也可以用红外控制
单片机源程序如下:
#include "PCA9685_TJ.h"
#include
#include
/*使用说明:
在main主程序
PCA9685_init();
在main主程序的while加入
PCA9685_main(); //注: 必需放在UART1_main();的前面
#define PCA9685_adrr 0x80// 1+A5+A4+A3+A2+A1+A0+w/r
#define PCA9685_SUBADR1 0x2
#define PCA9685_SUBADR2 0x3
#define PCA9685_SUBADR3 0x4
#define PCA9685_MODE1 0x0
#define PCA9685_PRESCALE 0xFE
#define LED0_ON_L 0x6
#define LED0_ON_H 0x7
#define LED0_OFF_L 0x8
#define LED0_OFF_H 0x9
#define ALLLED_ON_L 0xFA
#define ALLLED_ON_H 0xFB
#define ALLLED_OFF_L 0xFC
#define ALLLED_OFF_H 0xFD
uchar mm,nn;
uint SERV0; //存储值
IIC初始化
void init()
sda=1; //sda scl使用前被拉高
delay100us(1);
scl=1;
delay100us(1);
IIC启动
void start()
sda=1;
delay100us(1);
scl=1; //scl高 sda拉低 IIC启动
delay100us(1);
sda=0;
delay100us(1);
scl=0;
delay100us(1);
IIC停止
void stop()
sda=0;
delay100us(1);
scl=1;
delay100us(1);
sda=1;
delay100us(1);
IIC应答
void ACK()
uchar i;
scl=1;
delay100us(1);
while((sda=1)&&(i<255)) {
i++;
scl=0;
delay100us(1);
写字节
void write_byte(uchar byte)
uchar i,temp;
temp=byte;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay100us(1);
sda=CY;
delay100us(1);
scl=1;
delay100us(1);
scl=0;
delay100us(1);
sda=1;
delay100us(1);
读字节
uchar read_byte()
uchar i,j,k;
scl=0;
delay100us(1);
sda=1;
delay100us(1);
for(i=0;i<8;i++)
delay100us(1);
scl=1;
delay100us(1);
if(sda==1)
j=1;
else j=0;
k=(k<< 1)|j;
scl=0;
delay100us(1);
return k;
PCA9685
写数据到PCA9685
void PCA9685_write(uchar address,uchar date)
start();
write_byte(PCA9685_adrr);
ACK();
write_byte(address);
ACK();
write_byte(date);
ACK();
stop();
从PCA9685读数据有返回值
uchar PCA9685_read(uchar address)
uchar date;
start();
ACK();
ACK();
start();
write_byte(PCA9685_adrr|0x01);
ACK();
date=read_byte();
stop();
return date;
PCA9685复位
void reset(void)
PCA9685_write(PCA9685_MODE1,0x0);
void begin(void)
reset();
PCA9685修改频率
void setPWMFreq(float freq)
uint prescale,oldmode,newmode;
float prescaleval;
freq *= 0.92; // Correct for overshoot in the frequency setting
prescaleval = 25000000;
prescaleval /= 4096;
prescaleval /= freq;
prescaleval -= 1;
prescale = floor(prescaleval + 0.5);
oldmode = PCA9685_read(PCA9685_MODE1);
newmode = (oldmode&0x7F) | 0x10; // sleep
PCA9685_write(PCA9685_MODE1, newmode); // go to sleep
PCA9685_write(PCA9685_PRESCALE, prescale); // set the prescaler
PCA9685_write(PCA9685_MODE1, oldmode);
delay1ms(10);
PCA9685_write(PCA9685_MODE1, oldmode | 0xa1);
void setPWM(uint num, uint on, uint off)
PCA9685_write(LED0_ON_L+4*num,on);
PCA9685_write(LED0_ON_H+4*num,on>>8);
PCA9685_write(LED0_OFF_L+4*num,off);
PCA9685_write(LED0_OFF_H+4*num,off>>8);
void PCA9685_init() {
init(); //初始化
begin(); //初始化
setPWMFreq(50);
