74HC595驱动8个数码管源程序:
/* --- STC MCU International Limited ----------------------------------*/
/* --- STC 1T Series MCU Demo Programme -------------------------------*/
/* --- Mobile: (86)13922805190 ----------------------------------------*/
/* --- Fax: 86-0513-55012956,55012947,55012969 ------------------------*/
/* --- Tel: 86-0513-55012928,55012929,55012966 ------------------------*/
/* --- QQ: 800003751 -------------------------------------------------*/
/* 如果要在程序中使用此代码,请在程序中注明使用了宏晶科技的资料及程序 */
/************* 本程序功能说明 **************
用STC的MCU的IO方式控制74HC595驱动8位数码管。
显示效果为: 数码时钟.
使用Timer0的16位自动重装来产生1ms节拍,程序运行于这个节拍下, 用户修改MCU主时钟频率时,自动定时于1ms.
#define MAIN_Fosc 22118400L //定义主时钟
#include "STC15Fxxxx.H"
/****************************** 用户定义宏 ***********************************/
#define Timer0_Reload (65536UL -(MAIN_Fosc / 1000)) //Timer 0 中断频率, 1000次/秒
#define DIS_DOT 0x20
#define DIS_BLACK 0x10
#define DIS_ 0x11
/************* 本地常量声明 **************/
u8 code t_display[]={ //标准字库
// 0 1 2 3 4 5 6 7 8 9 A B C D E F
0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,
//black - H J K L N o P U t G Q r M y
0x00,0x40,0x76,0x1E,0x70,0x38,0x37,0x5C,0x73,0x3E,0x78,0x3d,0x67,0x50,0x37,0x6e,
0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFF,0xEF,0x46}; //0. 1. 2. 3. 4. 5. 6. 7. 8. 9. -1
u8 code T_COM[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //位码
/************* IO口定义 **************/
sbit P_HC595_SER = P4^0; //pin 14 SER data input
sbit P_HC595_RCLK = P5^4; //pin 12 RCLk store (latch) clock
sbit P_HC595_SRCLK = P4^3; //pin 11 SRCLK Shift data clock
/************* 本地变量声明 **************/
u8 LED8[8]; //显示缓冲
u8 display_index; //显示位索引
bit B_1ms; //1ms标志
u8 hour,minute,second;
u16 msecond;
/************* 本地函数声明 **************/
/**************** 外部函数声明和外部变量声明 *****************/
/********************** 显示时钟函数 ************************/
void DisplayRTC(void)
if(hour >= 10) LED8[0] = hour / 10;
else LED8[0] = DIS_BLACK;
LED8[1] = hour % 10;
LED8[2] = DIS_;
LED8[3] = minute / 10;
LED8[4] = minute % 10;
LED8[5] = DIS_;
LED8[6] = second / 10;
LED8[7] = second % 10;
/********************** RTC演示函数 ************************/
void RTC(void)
if(++second >= 60)
second = 0;
if(++minute >= 60)
minute = 0;
if(++hour >= 24) hour = 0;
/********************** 主函数 ************************/
void main(void)
u8 i,k;
P0M1 = 0; P0M0 = 0; //设置为准双向口
P1M1 = 0; P1M0 = 0; //设置为准双向口
P2M1 = 0; P2M0 = 0; //设置为准双向口
P3M1 = 0; P3M0 = 0; //设置为准双向口
P4M1 = 0; P4M0 = 0; //设置为准双向口
P5M1 = 0; P5M0 = 0; //设置为准双向口
P6M1 = 0; P6M0 = 0; //设置为准双向口
P7M1 = 0; P7M0 = 0; //设置为准双向口
AUXR = 0x80; //Timer0 set as 1T, 16 bits timer auto-reload,
TH0 = (u8)(Timer0_Reload / 256);
TL0 = (u8)(Timer0_Reload % 256);
ET0 = 1; //Timer0 interrupt enable
TR0 = 1; //Tiner0 run
EA = 1; //打开总中断
display_index = 0;
hour = 11; //初始化时间值
minute = 59;
second = 58;
RTC();
DisplayRTC();
// for(i=0; i<8; i++) LED8[i] = DIS_BLACK; //上电消隐
for(i=0; i<8; i++) LED8[i] = i; //显示01234567
k = 0;
while(1)
if(B_1ms) //1ms到
B_1ms = 0;
if(++msecond >= 1000) //1秒到
msecond = 0;
RTC();
DisplayRTC();
/**************** 向HC595发送一个字节函数 ******************/
void Send_595(u8 dat)
u8 i;
for(i=0; i<8; i++)
dat <<= 1;
P_HC595_SER = CY;
